[GRASS-SVN] r42410 - grass/trunk/raster/r.out.png
svn_grass at osgeo.org
Mon May 31 22:54:14 EDT 2010
Author: hamish
Date: 2010-05-31 22:54:13 -0400 (Mon, 31 May 2010)
New Revision: 42410
grass/trunk/raster/r.out.png/main.c
grass/trunk/raster/r.out.png/r.out.png.html
add flag to export a world file; rename some variables (wish #1077)
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c 2010-05-31 14:08:29 UTC (rev 42409)
+++ grass/trunk/raster/r.out.png/main.c 2010-06-01 02:54:13 UTC (rev 42410)
@@ -26,6 +26,7 @@
#include <string.h>
#include <stdlib.h>
+#include <float.h>
#ifndef _MYINCLUDE_H
#define _MYINCLUDE_H
@@ -42,13 +43,17 @@
typedef int FILEDESC;
+/* global functions */
+static int write_wld(const char *, const struct Cell_head *);
int main(int argc, char *argv[])
struct GModule *module;
struct Option *rast, *png_file, *compr; /* , *bgcolor; */
- struct Flag *alpha;
+ struct Flag *alpha, *wld_flag;
char *rastermap;
- char *basename = NULL, *ofile;
+ char *basename = NULL, *outfile = NULL;
unsigned char *set, *ored, *ogrn, *oblu;
int def_red, def_grn, def_blu;
CELL *cell_buf;
@@ -58,28 +63,28 @@
int rtype, row, col, do_stdout = 0;
size_t rsize;
int png_compr, ret, do_alpha;
- struct Cell_head w;
+ struct Cell_head win;
FILEDESC cellfile = 0;
FILE *fp;
/* now goes from pnmtopng.c* -A.Sh */
- * * pnmtopng.c -
- * * read a portable anymap and produce a Portable Network Graphics file
- * * derived from pnmtorast.c (c) 1990,1991 by Jef Poskanzer and some
- * * parts derived from ppmtogif.c by Marcel Wijkstra <wijkstra at fwi.uva.nl>
- * * thanks to Greg Roelofs <newt at pobox.com> for contributions and bug-fixes
- * * Copyright (C) 1995-1998 by Alexander Lehmann <alex at hal.rhein-main.de>
- * * and Willem van Schaik <willem at schaik.com>
- * * Permission to use, copy, modify, and distribute this software and its
- * * documentation for any purpose and without fee is hereby granted, provided
- * * that the above copyright notice appear in all copies and that both that
- * * copyright notice and this permission notice appear in supporting
- * * documentation. This software is provided "as is" without express or
- * * implied warranty.
+ * pnmtopng.c -
+ * read a portable anymap and produce a Portable Network Graphics file
+ * derived from pnmtorast.c (c) 1990,1991 by Jef Poskanzer and some
+ * parts derived from ppmtogif.c by Marcel Wijkstra <wijkstra at fwi.uva.nl>
+ * thanks to Greg Roelofs <newt at pobox.com> for contributions and bug-fixes
+ * Copyright (C) 1995-1998 by Alexander Lehmann <alex at hal.rhein-main.de>
+ * and Willem van Schaik <willem at schaik.com>
+ * Permission to use, copy, modify, and distribute this software and its
+ * documentation for any purpose and without fee is hereby granted, provided
+ * that the above copyright notice appear in all copies and that both that
+ * copyright notice and this permission notice appear in supporting
+ * documentation. This software is provided "as is" without express or
+ * implied warranty.
png_struct *png_ptr;
@@ -132,6 +137,10 @@
alpha->key = 't';
alpha->description = _("Make NULL cells transparent");
+ wld_flag = G_define_flag();
+ wld_flag->key = 'w';
+ wld_flag->description = _("Output world file");
/* see what can be done to convert'em -A.Sh.
* gscale = G_define_flag ();
* gscale->key = 'g';
@@ -153,9 +162,8 @@
if (basename) {
G_basename(basename, "png");
- ofile = G_malloc(strlen(basename) + 5);
- sprintf(ofile, "%s.png", basename);
- G_free(basename);
+ outfile = G_malloc(strlen(basename) + 5);
+ sprintf(outfile, "%s.png", basename);
png_compr = atoi(compr->answer);
@@ -173,10 +181,10 @@
ret = G_str_to_color(DEFAULT_BG_COLOR, &def_red, &def_grn, &def_blu);
#endif
- /*G_get_set_window (&w); *//* 10/99 MN: check for current region */
- G_get_window(&w);
+ /*G_get_set_window (&win); *//* 10/99 MN: check for current region */
+ G_get_window(&win);
- G_debug(1, "rows = %d, cols = %d", w.rows, w.cols);
+ G_debug(1, "rows = %d, cols = %d", win.rows, win.cols);
/* open raster map for reading */
cellfile = Rast_open_old(rast->answer, "");
@@ -185,21 +193,18 @@
fcell_buf = Rast_allocate_f_buf();
dcell_buf = Rast_allocate_d_buf();
- ored = G_malloc(w.cols);
- ogrn = G_malloc(w.cols);
- oblu = G_malloc(w.cols);
- set = G_malloc(w.cols);
+ ored = G_malloc(win.cols);
+ ogrn = G_malloc(win.cols);
+ oblu = G_malloc(win.cols);
+ set = G_malloc(win.cols);
/* open png file for writing */
- if (do_stdout)
- fp = stdout;
- else if (NULL == (fp = fopen(ofile, "w")))
- G_fatal_error(_("Unable to open output file <%s>"), ofile);
- else
- G_free(ofile);
+ if (do_stdout)
+ fp = stdout;
+ else if (NULL == (fp = fopen(outfile, "w")))
+ G_fatal_error(_("Unable to open output file <%s>"), outfile);
png_ptr = png_create_write_struct(PNG_LIBPNG_VER_STRING,
&pnmtopng_jmpbuf_struct,
pnmtopng_error_handler, NULL);
@@ -228,8 +233,8 @@
png_info_init(info_ptr);
#endif
png_init_io(png_ptr, fp);
- info_ptr->width = w.cols;
- info_ptr->height = w.rows;
+ info_ptr->width = win.cols;
+ info_ptr->height = win.rows;
info_ptr->bit_depth = depth;
/* explicit filter-type (or none) required */
@@ -281,18 +286,18 @@
png_set_packing(png_ptr);
/* max: 3 color channels, one alpha channel, 16-bit */
- line = (png_byte *) G_malloc(w.cols * 8 * sizeof(char));
+ line = (png_byte *) G_malloc(win.cols * 8 * sizeof(char));
- for (row = 0; row < w.rows; row++) {
+ for (row = 0; row < win.rows; row++) {
- G_percent(row, w.rows, 5);
+ G_percent(row, win.rows, 5);
Rast_get_row(cellfile, (void *)voidc, row, rtype);
Rast_lookup_colors((void *)voidc, ored, ogrn, oblu, set,
- w.cols, &colors, rtype);
+ win.cols, &colors, rtype);
pp = line;
- for (col = 0; col < w.cols; col++) {
+ for (col = 0; col < win.cols; col++) {
if (set[col]) {
*pp++ = ored[col];
@@ -324,7 +329,7 @@
png_write_row(png_ptr, line);
- G_percent(row, w.rows, 5); /* finish it off */
+ G_percent(row, win.rows, 5); /* finish it off */
else { /* GREYSCALE IMAGE */
@@ -341,6 +346,7 @@
Rast_free_colors(&colors);
G_free(cell_buf);
G_free(fcell_buf);
G_free(dcell_buf);
@@ -350,19 +356,32 @@
G_free(set);
Rast_close(cellfile);
png_write_end(png_ptr, info_ptr);
/* png_write_destroy (png_ptr); this is no longer supported with libpng, al 11/2000 */
/* flush first because G_free (png_ptr) can segfault due to jmpbuf problems
* in png_write_destroy */
fflush(stdout);
/* G_free (png_ptr); */
/* G_free (info_ptr); */
png_destroy_write_struct(&png_ptr, &info_ptr); /* al 11/2000 */
fclose(fp);
+ if (wld_flag->answer) {
+ if(do_stdout)
+ outfile = G_store("png_map.wld");
+ else
+ sprintf(outfile, "%s.wld", basename);
+ write_wld(outfile, &win);
+ if(basename)
+ G_free(basename);
+ if(outfile)
+ G_free(outfile);
exit(EXIT_SUCCESS);
@@ -396,3 +415,29 @@
longjmp(jmpbuf_ptr->jmpbuf, 1);
+static int write_wld(const char *fname, const struct Cell_head *win)
+ int width = DBL_DIG;
+ FILE *ofile;
+ G_verbose_message(_("Writing world file"));
+ if (fname == NULL)
+ G_fatal_error(_("Got null file name"));
+ if (win == NULL)
+ G_fatal_error(_("Got null region struct"));
+ if ((ofile = fopen(fname, "w")) == NULL)
+ G_fatal_error(_("Unable to open world file for writing"));
+ fprintf(ofile, "%36.*f \n", width, win->ew_res);
+ fprintf(ofile, "%36.*f \n", width, 0.0);
+ fprintf(ofile, "%36.*f \n", width, -1 * win->ns_res);
+ fprintf(ofile, "%36.*f \n", width, win->west + win->ew_res / 2.0);
+ fprintf(ofile, "%36.*f \n", width, win->north - win->ns_res / 2.0);
+ fclose(ofile);
+ return 0;
Modified: grass/trunk/raster/r.out.png/r.out.png.html
--- grass/trunk/raster/r.out.png/r.out.png.html 2010-05-31 14:08:29 UTC (rev 42409)
+++ grass/trunk/raster/r.out.png/r.out.png.html 2010-06-01 02:54:13 UTC (rev 42410)
@@ -3,19 +3,27 @@
<em>r.out.png</em> exports a GRASS raster map in non-georeferenced PNG image
format, respecting the current region resolution and bounds.
+<p>
+Optionally the user can choose to export a World File to provide basic
+georeferencing support. When used with the transparency flag this can
+create images useful for KML, TMS, or WMS overlays. (e.g. for use in
+Google Earth or as OpenLayers tiles)
<h2>SEE ALSO</h2>
<em>
<a href="r.out.gdal.html">r.out.gdal</a>,
+<a href="r.out.ppm.html">r.out.ppm</a>,
<a href="r.out.tiff.html">r.out.tiff</a>,
<a href="r.out.ascii.html">r.out.ascii</a>
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-Alex Shevlakov
+Alex Shevlakov<BR>
+Hamish Bowman
<p>
<i>Last changed: $Date$</i>
