[GRASS-SVN] r44133 - in grass/trunk: include lib/raster
raster/r.colors
svn_grass at osgeo.org
Mon Nov 1 03:23:49 EDT 2010
Author: martinl
Date: 2010-11-01 00:23:49 -0700 (Mon, 01 Nov 2010)
New Revision: 44133
Removed:
grass/trunk/lib/raster/color_print.c
grass/trunk/include/rasterdefs.h
grass/trunk/raster/r.colors/main.c
r.colors: remove `-p` (there is already r.colors.out)
clean up raster library (no need for Rast_print_colors())
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2010-10-31 17:38:43 UTC (rev 44132)
+++ grass/trunk/include/rasterdefs.h 2010-11-01 07:23:49 UTC (rev 44133)
@@ -174,9 +174,6 @@
/* color_org.c */
void Rast__organize_colors(struct Colors *);
-/* color_print.c */
-int Rast_print_colors(const char *, const char *, FILE *);
/* color_rand.c */
void Rast_make_random_colors(struct Colors *, CELL, CELL);
Deleted: grass/trunk/lib/raster/color_print.c
--- grass/trunk/lib/raster/color_print.c 2010-10-31 17:38:43 UTC (rev 44132)
+++ grass/trunk/lib/raster/color_print.c 2010-11-01 07:23:49 UTC (rev 44133)
@@ -1,70 +0,0 @@
- * \file lib/gis/color_print.c
- * \brief GIS Library - Print color table of raster map
- * (C) 2010 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Martin Landa <landa.martin gmail.com>
-#include <stdio.h>
-#include <string.h>
-#include <grass/gis.h>
-static int print_color_table(const char *, const char *, const char *, FILE *);
- \brief Print current color table of raster map to file
- \param name name of raster map
- \param mapset mapset of raster map
- \param file file where to print color table
- \return -1 on error (raster map not found)
- \return -2 on error (reading color table failed)
- \return 0 on success
-int Rast_print_colors(const char *name, const char *mapset, FILE *file)
- char element[512];
- char xname[GNAME_MAX];
- strcpy(xname, name);
- mapset = G_find_raster(xname, mapset);
- if (!mapset)
- return -1;
- name = xname;
- /* first look for secondary color table in current mapset */
- sprintf(element, "colr2/%s", mapset);
- if (print_color_table(element, name, G_mapset(), file) < 0)
- /* now look for the regular color table */
- if (print_color_table("colr", name, mapset, file) < 0)
- return -2;
- return 0;
-int print_color_table(const char *element, const char *name,
- const char *mapset, FILE *file)
- FILE *fd;
- char buf[4096];
- fd = G_fopen_old(element, name, mapset);
- if (!fd)
- return -1;
- while(fgets(buf, sizeof(buf), fd)) {
- fwrite(buf, strlen(buf), 1, file);
- fclose(fd);
- return 0;
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c 2010-10-31 17:38:43 UTC (rev 44132)
+++ grass/trunk/raster/r.colors/main.c 2010-11-01 07:23:49 UTC (rev 44133)
@@ -4,7 +4,6 @@
* AUTHOR(S): Michael Shapiro - CERL
* David Johnson
- * Print color table by Martin Landa <landa.martin gmail.com>
* PURPOSE: Allows creation and/or modification of the color table
* for a raster map layer.
@@ -28,6 +27,14 @@
static char **rules;
static int nrules;
+static int cmp(const void *aa, const void *bb)
+ char *const *a = (char *const *)aa;
+ char *const *b = (char *const *)bb;
+ return strcmp(*a, *b);
static void scan_rules(void)
char path[GPATH_MAX];
@@ -41,6 +48,8 @@
rules[nrules++] = G_store("random");
rules[nrules++] = G_store("grey.eq");
rules[nrules++] = G_store("grey.log");
+ qsort(rules, nrules, sizeof(char *), cmp);
static char *rules_list(void)
@@ -131,7 +140,7 @@
int overwrite;
int is_from_stdin;
- int remove, print;
+ int remove;
int have_colors;
struct Colors colors, colors_tmp;
struct Cell_stats statf;
@@ -145,7 +154,7 @@
struct GModule *module;
struct
- struct Flag *r, *w, *l, *g, *a, *e, *n, *p;
+ struct Flag *r, *w, *l, *g, *a, *e, *n;
} flag;
struct
@@ -204,8 +213,7 @@
flag.l = G_define_flag();
flag.l->key = 'l';
flag.l->description = _("List available rules then exit");
- flag.l->guisection = _("Print");
flag.n = G_define_flag();
flag.n->key = 'n';
flag.n->description = _("Invert colors");
@@ -226,11 +234,6 @@
flag.e->description = _("Histogram equalization");
flag.e->guisection = _("Define");
- flag.p = G_define_flag();
- flag.p->key = 'p';
- flag.p->description = _("Print current color table and exit");
- flag.p->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -241,7 +244,6 @@
overwrite = !flag.w->answer;
remove = flag.r->answer;
- print = flag.p->answer;
name = opt.map->answer;
style = opt.colr->answer;
@@ -251,8 +253,8 @@
if (!name)
G_fatal_error(_("No raster map specified"));
- if (!cmap && !style && !rules && !remove && !print)
- G_fatal_error(_("One of \"-r\", \"-p\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
+ if (!cmap && !style && !rules && !remove)
+ G_fatal_error(_("One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
if (!!style + !!cmap + !!rules > 1)
G_fatal_error(_("\"color\", \"rules\", and \"raster\" options are mutually exclusive"));
@@ -268,11 +270,6 @@
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), name);
- if (print) {
- Rast_print_colors(name, mapset, stdout);
- return EXIT_SUCCESS;
if (remove) {
int stat = Rast_remove_colors(name, mapset);
