[GRASS-SVN] r44142 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Nov 1 06:17:59 EDT 2010
Author: martinl
Date: 2010-11-01 03:17:59 -0700 (Mon, 01 Nov 2010)
New Revision: 44142
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI/colortable: use r.colors.out instead of `r.colors -p`
various minor fixes
(merge r44141 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2010-11-01 10:16:42 UTC (rev 44141)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2010-11-01 10:17:59 UTC (rev 44142)
@@ -25,7 +25,7 @@
import wx.lib.colourselect as csel
import wx.lib.scrolledpanel as scrolled
-from grass.script import core as grass
+import grass.script as grass
import dbm
import gcmd
@@ -306,13 +306,13 @@
def AddRules(self, nrules):
"""!Add rules"""
snum = len(self.ruleslines.keys())
- for num in range(snum, snum+nrules):
+ for num in range(snum, snum + nrules):
# enable
enable = wx.CheckBox(parent=self.cr_panel, id=num)
enable.SetValue(True)
self.Bind(wx.EVT_CHECKBOX, self.OnRuleEnable, enable)
# value
- txt_ctrl = wx.TextCtrl(parent=self.cr_panel, id=1000+num, value='',
+ txt_ctrl = wx.TextCtrl(parent=self.cr_panel, id=1000 + num,
size=(100,-1),
style=wx.TE_NOHIDESEL)
self.Bind(wx.EVT_TEXT, self.OnRuleValue, txt_ctrl)
@@ -355,26 +355,28 @@
"""!Raster/vector map selected"""
if event:
self.inmap = event.GetString()
+ if self.inmap:
+ if self.raster:
+ mapType = 'cell'
+ else:
+ mapType = 'vector'
+ if not grass.find_file(name = self.inmap, element = mapType)['file']:
+ self.inmap = None
if not self.inmap:
self.btnPreview.Enable(False)
self.btnOK.Enable(False)
self.btnApply.Enable(False)
+ self.OnLoadTable(event)
return
if self.raster:
- info = gcmd.RunCommand('r.info',
- parent = self,
- read = True,
- flags = 'r',
- map = self.inmap)
+ info = grass.raster_info(map = self.inmap)
if info:
- for line in info.splitlines():
- if 'min' in line:
- self.properties['min'] = float(line.split('=')[1])
- elif 'max' in line:
- self.properties['max'] = float(line.split('=')[1])
+ self.properties['min'] = info['min']
+ self.properties['max'] = info['max']
else:
self.inmap = ''
@@ -386,8 +388,13 @@
self.cr_label.SetLabel(_('Enter raster category values or percents'))
return
- self.cr_label.SetLabel(_('Enter raster category values or percents (range = %(min)d-%(max)d)') %
- { 'min' : self.properties['min'],
+ if info['datatype'] == 'CELL':
+ mapRange = _('range')
+ else:
+ mapRange = _('fp range')
+ self.cr_label.SetLabel(_('Enter raster category values or percents (%(range)s = %(min)d-%(max)d)') %
+ { 'range' : mapRange,
+ 'min' : self.properties['min'],
'max' : self.properties['max'] })
else:
@@ -440,31 +447,21 @@
"""!Rule value changed"""
num = event.GetId()
vals = event.GetString().strip()
if vals == '':
return
tc = self.FindWindowById(num)
if self.raster:
- try:
- if vals != '-' and \
- vals[-1] != '%':
- float(vals)
- except (IndexError, ValueError):
- tc.SetValue('')
- self.ruleslines[num-1000]['value'] = ''
- return
self.ruleslines[num-1000]['value'] = vals
else:
if self.properties['column'] == '' or self.properties['rgb'] == '':
tc.SetValue('')
- wx.MessageBox(parent=self,
+ gcmd.GMessage(parent=self,
message=_("Please select attribute column "
- "and RGB color column first"),
- style=wx.CENTRE)
+ "and RGB color column first"))
else:
try:
self.ruleslines[num-1000]['value'] = self.SQLConvert(vals)
@@ -499,34 +496,33 @@
return sqlrule
def OnLoadTable(self, event):
- """!Load current color table (using `r.colors -p`)"""
- ctable = gcmd.RunCommand('r.colors',
- parent = self,
- read = True,
- flags = 'p',
- map = self.inmap)
+ """!Load current color table (using `r.colors.out`)"""
self.ruleslines.clear()
self.cr_panel.DestroyChildren()
+ if self.inmap:
+ ctable = gcmd.RunCommand('r.colors.out',
+ parent = self,
+ read = True,
+ map = self.inmap,
+ rules = '-')
+ else:
+ self.OnPreview(event)
+ return
rulesNumber = len(ctable.splitlines())
self.AddRules(rulesNumber)
count = 0
- for line in ctable.splitlines()[1:]:
- item = line.split()
- for part in range(0, 2):
- itemSplit = item[part].split(':', 1)
- self.ruleslines[count]['value'] = itemSplit[0]
- if ':' not in itemSplit[1]:
- itemSplit[1] += (':' + itemSplit[1]) * 2
- self.ruleslines[count]['color'] = itemSplit[1]
- self.FindWindowById(count + 1000).SetValue(itemSplit[0])
- rgb = list()
- for color in itemSplit[1].split(':'):
- rgb.append(int(color))
- self.FindWindowById(count + 2000).SetColour(rgb)
- count += 1
- if count < rulesNumber - 1:
- break
+ for line in ctable.splitlines():
+ value, color = map(lambda x: x.strip(), line.split(' '))
+ self.ruleslines[count]['value'] = value
+ self.ruleslines[count]['color'] = color
+ self.FindWindowById(count + 1000).SetValue(value)
+ rgb = list()
+ for c in color.split(':'):
+ rgb.append(int(c))
+ self.FindWindowById(count + 2000).SetColour(rgb)
+ count += 1
self.OnPreview(tmp = False)
@@ -575,6 +571,10 @@
def OnPreview(self, event = None, tmp = True):
"""!Update preview (based on computational region)"""
+ if not self.inmap:
+ self.preview.EraseMap()
+ return
# raster
if self.raster:
cmdlist = ['d.rast',
@@ -633,6 +633,14 @@
parent = self,
entry = cmd)
+ def _IsNumber(self, s):
+ """!Check if 's' is a number"""
+ try:
+ float(s)
+ return True
+ except ValueError:
+ return False
def CreateColorTable(self, force = False):
"""!Creates color table
@@ -644,6 +652,12 @@
for rule in self.ruleslines.itervalues():
if not rule['value']: # skip empty rules
continue
+ if rule['value'] not in ('nv', 'default') and \
+ rule['value'][-1] != '%' and \
+ not self._IsNumber(rule['value']):
+ gcmd.GError(_("Invalid rule value '%s'. Unable to apply color table.") % rule['value'],
+ parent = self)
+ return False
if self.raster:
rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
@@ -690,13 +704,11 @@
class BufferedWindow(wx.Window):
"""!A Buffered window class"""
def __init__(self, parent, id,
- pos = wx.DefaultPosition,
- size = wx.DefaultSize,
style=wx.NO_FULL_REPAINT_ON_RESIZE,
- Map=None):
+ Map=None, **kwargs):
+ wx.Window.__init__(self, parent, id, style = style, **kwargs)
- wx.Window.__init__(self, parent, id, pos, size, style)
self.parent = parent
self.Map = Map
@@ -819,7 +831,7 @@
Debug.msg (2, "BufferedWindow.UpdatePreview(%s): render=%s" % (img, self.render))
oldfont = ""
oldencoding = ""
if self.render:
# make sure that extents are updated
self.Map.region = self.Map.GetRegion()
@@ -829,7 +841,7 @@
self.mapfile = self.Map.Render(force=self.render)
self.img = self.GetImage()
self.resize = False
if not self.img:
return
@@ -838,7 +850,7 @@
self.pdc.RemoveAll()
# draw map image background
self.Draw(self.pdc, self.img, pdctype='image')
self.resize = False
def EraseMap(self):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-11-01 10:16:42 UTC (rev 44141)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-11-01 10:17:59 UTC (rev 44142)
@@ -1237,10 +1237,12 @@
def Clean(self):
"""!Clean layer stack - go trough all layers and remove them
- from layer list Removes also l_mapfile and l_maskfile
+ from layer list.
+ Removes also l_mapfile and l_maskfile
- @return 1 on faulure
- @return None on success
+ @return False on failure
+ @return True on success
try:
dir = os.path.dirname(self.mapfile)
@@ -1265,11 +1267,11 @@
for f in glob.glob(removepath):
os.remove(f)
self.overlays.remove(overlay)
- return None
except:
- return 1
- self.layers = []
+ return False
+ return True
def ReverseListOfLayers(self):
"""!Reverse list of layers"""
return self.layers.reverse()
