[GRASS-SVN] r44172 - in grass/trunk/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Tue Nov 2 10:53:56 EDT 2010
Author: martinl
Date: 2010-11-02 07:53:55 -0700 (Tue, 02 Nov 2010)
New Revision: 44172
Removed:
grass/trunk/gui/wxpython/gui_modules/georect.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: georect replaced by gcpmanager
(merge r44168 from devbr6)
Deleted: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2010-11-02 14:53:07 UTC (rev 44171)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2010-11-02 14:53:55 UTC (rev 44172)
@@ -1,1796 +0,0 @@
- at package georect.py
- at brief Georectification module for GRASS GIS. Includes ground control
-point management and interactive point and click GCP creation
-Classes:
- - GeorectWizard
- - LocationPage
- - GroupPage
- - DispMapPage
- - GCP
- - GCPList
- - VectGroup
- - EditGCP
- - GrSettingsDialog
-(C) 2006-2010 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Michael Barton
- at author Updated by Martin Landa <landa.martin gmail.com>
-import os
-import sys
-import tempfile
-import shutil
-import time
-import wx
-from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin, TextEditMixin
-import wx.lib.colourselect as csel
-import wx.wizard as wiz
-import grass.script as grass
-import globalvar
-import mapdisp
-import render
-import toolbars
-import menuform
-import gselect
-import gcmd
-import utils
-from debug import Debug as Debug
-from icon import Icons as Icons
-from location_wizard import TitledPage as TitledPage
-from preferences import globalSettings as UserSettings
-try:
- import subprocess # Not needed if GRASS commands could actually be quiet
-except:
- CompatPath = globalvar.ETCWXDIR
- sys.path.append(CompatPath)
- from compat import subprocess
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
-# global variables
-global xy_map
-global maptype
-xy_map = ''
-maptype = 'cell'
-class GeorectWizard(object):
- Start wizard here and finish wizard here
- def __init__(self, parent):
- self.parent = parent # GMFrame
- # get environmental variables
- self.grassdatabase = grass.gisenv()['GISDBASE']
- # read original environment settings
- self.orig_gisrc = os.environ['GISRC']
- self.gisrc_dict = {}
- try:
- f = open(self.orig_gisrc, 'r')
- for line in f.readlines():
- line = line.replace('\n', '').strip()
- if len(line) < 1:
- continue
- key, value = line.split(':', 1)
- self.gisrc_dict[key.strip()] = value.strip()
- finally:
- f.close()
- self.currentlocation = self.gisrc_dict['LOCATION_NAME']
- self.currentmapset = self.gisrc_dict['MAPSET']
- # location for xy map to georectify
- self.newlocation = ''
- # mapset for xy map to georectify
- self.newmapset = ''
- # GISRC file for source location/mapset of map(s) to georectify
- self.new_gisrc = ''
- # define wizard pages
- self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Setup for georectification"))
- self.startpage = LocationPage(self.wizard, self)
- self.grouppage = GroupPage(self.wizard, self)
- self.mappage = DispMapPage(self.wizard, self)
- # set the initial order of the pages
- self.startpage.SetNext(self.grouppage)
- self.grouppage.SetPrev(self.startpage)
- self.grouppage.SetNext(self.mappage)
- self.mappage.SetPrev(self.grouppage)
- # do pages layout
- self.startpage.DoLayout()
- self.grouppage.DoLayout()
- self.mappage.DoLayout()
- self.wizard.FitToPage(self.startpage)
- # self.Bind(wx.EVT_CLOSE, self.Cleanup)
- # self.parent.Bind(wx.EVT_ACTIVATE, self.OnGLMFocus)
- success = False
- # run wizard
- if self.wizard.RunWizard(self.startpage):
- success = self.OnWizFinished()
- if success == False:
- wx.MessageBox(parent=self.parent,
- message=_("Georectifying setup canceled."),
- caption=_("Georectify"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- self.Cleanup()
- else:
- self.Cleanup()
- # start display showing xymap
- if success != False:
- # instance of render.Map to be associated with display
- self.Map = render.Map(gisrc=self.new_gisrc)
- global maptype
- global xy_map
- # add layer to map
- if maptype == 'cell':
- rendertype = 'raster'
- cmdlist = ['d.rast', 'map=%s' % xy_map]
- else: # -> vector layer
- rendertype = 'vector'
- cmdlist = ['d.vect', 'map=%s' % xy_map]
- self.Map.AddLayer(type=rendertype, command=cmdlist, l_active=True,
- name=utils.GetLayerNameFromCmd(cmdlist),
- l_hidden=False, l_opacity=1.0, l_render=False)
- # start GCP form
- self.gcpmgr = GCP(self.parent, grwiz=self)
- self.gcpmgr.Show()
- # start map display
- self.xy_mapdisp = mapdisp.MapFrame(self.gcpmgr, name = "GRMapWindow",
- size=globalvar.MAP_WINDOW_SIZE,
- toolbars=["georect"],
- Map=self.Map, lmgr=self.parent)
- self.xy_mapdisp.SetTitle(_("GRASS GIS Map Display: 1" +
- " - Location: " + self.newlocation +
- " (source location)"))
- self.xy_mapdisp.GetWindow().ResetZoomHistory()
- self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
- self.mapwin = self.xy_mapdisp.MapWindow
- # set mouse characteristics
- self.mapwin.mouse['box'] = 'point'
- self.mapwin.mouse["use"] == "pointer"
- self.mapwin.zoomtype = 0
- self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
- self.mapwin.SetCursor(self.xy_mapdisp.cursors["cross"])
- # show new display & draw map
- self.xy_mapdisp.toolbars['georect'].OnZoomMap(None)
- self.xy_mapdisp.CenterOnScreen()
- self.xy_mapdisp.Show()
- self.gcpmgr.Centre()
- self.gcpmgr.Raise()
- else:
- self.Cleanup()
- def SetSrcEnv(self, location, mapset):
- """!Create environment to use for location and mapset
- that are the source of the file(s) to georectify
- @param location source location
- @param mapset source mapset
- @return False on error
- @return True on success
- self.newlocation = location
- self.newmapset = mapset
- # check to see if we are georectifying map in current working location/mapset
- if self.newlocation == self.currentlocation and self.newmapset == self.currentmapset:
- return False
- self.gisrc_dict['LOCATION_NAME'] = location
- self.gisrc_dict['MAPSET'] = mapset
- self.new_gisrc = utils.GetTempfile()
- try:
- f = open(self.new_gisrc, mode='w')
- for line in self.gisrc_dict.items():
- f.write(line[0] + ": " + line[1] + "\n")
- finally:
- f.close()
- return True
- def SwitchEnv(self, grc):
- Switches between original working location/mapset and
- location/mapset that is source of file(s) to georectify
- return False
- if grc == 'original':
- os.environ["GISRC"] = str(self.orig_gisrc)
- elif grc == 'new':
- os.environ["GISRC"] = str(self.new_gisrc)
- return True
- def OnWizFinished(self):
- # self.Cleanup()
- return True
- def OnGLMFocus(self, event):
- """!Layer Manager focus"""
- # self.SwitchEnv('original')
- event.Skip()
- def Cleanup(self):
- """!Return to current location and mapset"""
- self.SwitchEnv('original')
- self.parent.georectifying = None
- if hasattr(self, "xy_mapdisp") and \
- self.xy_mapdisp:
- self.xy_mapdisp.Close()
- self.xy_mapdisp = None
- self.wizard.Destroy()
- # clear GCPs from target display
- self.parent.curr_page.maptree.mapdisplay.MapWindow.UpdateMap(render=False)
-class LocationPage(TitledPage):
- Set map type (raster or vector) to georectify and
- select location/mapset of map(s) to georectify.
- def __init__(self, wizard, parent):
- TitledPage.__init__(self, wizard, _("Select map type and location/mapset"))
- self.grassdatabase = self.parent.grassdatabase
- self.xylocation = ''
- self.xymapset = ''
- # layout
- self.sizer.AddGrowableCol(2)
- # map type
- self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY,
- label=' %s ' % _("Map type to georectify"),
- choices=[_('raster'), _('vector')],
- majorDimension=wx.RA_SPECIFY_COLS)
- self.sizer.Add(item=self.rb_maptype,
- flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
- pos=(1, 1), span=(1, 2))
- # location
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source location:')),
- flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
- pos=(2, 1))
- self.cb_location = gselect.LocationSelect(parent = self, gisdbase = self.grassdatabase)
- self.sizer.Add(item=self.cb_location,
- pos=(2, 2))
- # mapset
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source mapset:')),
- pos=(3, 1))
- self.cb_mapset = gselect.MapsetSelect(parent = self, gisdbase = self.grassdatabase,
- setItems = False)
- self.sizer.Add(item=self.cb_mapset,
- pos=(3,2))
- # bindings
- self.Bind(wx.EVT_RADIOBOX, self.OnMaptype, self.rb_maptype)
- self.Bind(wx.EVT_COMBOBOX, self.OnLocation, self.cb_location)
- self.Bind(wx.EVT_COMBOBOX, self.OnMapset, self.cb_mapset)
- self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
- self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
- # self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
- def OnMaptype(self,event):
- """!Change map type"""
- global maptype
- if event.GetInt() == 0:
- maptype = 'cell'
- else:
- maptype = 'vector'
- def OnLocation(self, event):
- """!Sets source location for map(s) to georectify"""
- self.xylocation = event.GetString()
- #create a list of valid mapsets
- tmplist = os.listdir(os.path.join(self.grassdatabase, self.xylocation))
- self.mapsetList = []
- for item in tmplist:
- if os.path.isdir(os.path.join(self.grassdatabase, self.xylocation, item)) and \
- os.path.exists(os.path.join(self.grassdatabase, self.xylocation, item, 'WIND')):
- if item != 'PERMANENT':
- self.mapsetList.append(item)
- self.xymapset = 'PERMANENT'
- utils.ListSortLower(self.mapsetList)
- self.mapsetList.insert(0, 'PERMANENT')
- self.cb_mapset.SetItems(self.mapsetList)
- self.cb_mapset.SetStringSelection(self.xymapset)
- if not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
- wx.FindWindowById(wx.ID_FORWARD).Enable(True)
- def OnMapset(self, event):
- """!Sets source mapset for map(s) to georectify"""
- if self.xylocation == '':
- wx.MessageBox(_('You must select a valid location before selecting a mapset'))
- return
- self.xymapset = event.GetString()
- def OnPageChanging(self, event=None):
- if event.GetDirection() and \
- (self.xylocation == '' or self.xymapset == ''):
- wx.MessageBox(_('You must select a valid location and mapset in order to continue'))
- event.Veto()
- return
- self.parent.SetSrcEnv(self.xylocation, self.xymapset)
- def OnEnterPage(self, event=None):
- if self.xylocation == '' or self.xymapset == '':
- wx.FindWindowById(wx.ID_FORWARD).Enable(False)
- else:
-class GroupPage(TitledPage):
- Set group to georectify. Create group if desired.
- TitledPage.__init__(self, wizard, _("Select image/map group to georectify"))
- self.groupList = []
- self.xygroup = ''
- # default extension
- self.extension = 'georect' + str(os.getpid())
- # layout
- # group
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select group:')),
- pos=(1, 1))
- self.cb_group = wx.ComboBox(parent=self, id=wx.ID_ANY,
- choices=self.groupList, size=(350, -1),
- style=wx.CB_DROPDOWN | wx.CB_READONLY)
- self.sizer.Add(item=self.cb_group,
- pos=(1, 2))
- # create group
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Create group if none exists')),
- pos=(2, 1))
- btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- self.btn_mkgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Create/edit group..."))
- self.btn_vgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Add vector map to group..."))
- btnSizer.Add(item=self.btn_mkgroup,
- flag=wx.RIGHT, border=5)
- btnSizer.Add(item=self.btn_vgroup,
- flag=wx.LEFT, border=5)
- self.sizer.Add(item=btnSizer,
- pos=(2, 2))
- # extension
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Extension for output maps:')),
- pos=(3, 1))
- self.ext_txt = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(350,-1))
- self.ext_txt.SetValue(self.extension)
- self.sizer.Add(item=self.ext_txt,
- pos=(3, 2))
- # bindings
- self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
- self.Bind(wx.EVT_TEXT, self.OnExtension, self.ext_txt)
- self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
- # hide vector group button by default
- self.btn_vgroup.Hide()
- def OnGroup(self, event):
- self.xygroup = event.GetString()
- def OnMkGroup(self, event):
- """!Create new group in source location/mapset"""
- menuform.GUI().ParseCommand(['i.group'],
- completed=(self.GetOptData, None, ''),
- parentframe=self.parent.parent, modal=True)
- def OnVGroup(self, event):
- """!Add vector maps to group"""
- dlg = VectGroup(parent = self,
- id = wx.ID_ANY,
- grassdb = self.grassdatabase,
- location = self.xylocation,
- mapset = self.xymapset,
- group = self.xygroup)
- if dlg.ShowModal() != wx.ID_OK:
- return
- dlg.MakeVGroup()
- self.OnEnterPage()
- def GetOptData(self, dcmd, layer, params, propwin):
- """!Process i.group"""
- # update the page
- if dcmd:
- gcmd.Command(dcmd)
- self.Update()
- def OnExtension(self, event):
- self.extension = event.GetString()
- if event.GetDirection() and self.xygroup == '':
- wx.MessageBox(_('You must select a valid image/map group in order to continue'))
- event.Veto()
- return
- if event.GetDirection() and self.extension == '':
- wx.MessageBox(_('You must enter an map name extension in order to continue'))
- event.Veto()
- return
- global maptype
- self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
- self.xymapset = self.parent.gisrc_dict['MAPSET']
- # create a list of groups in selected mapset
- self.xylocation,
- self.xymapset,
- 'group')):
- self.xylocation,
- self.xymapset,
- 'group'))
- self.xylocation,
- self.xymapset,
- 'group',
- item)):
- self.groupList.append(item)
- self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
- elif maptype == 'vector':
- self.btn_vgroup.Show()
- self.Bind(wx.EVT_BUTTON, self.OnVGroup, self.btn_vgroup)
- utils.ListSortLower(self.groupList)
- self.cb_group.SetItems(self.groupList)
- if len(self.groupList) > 0 and \
- self.xygroup == '':
- self.cb_group.SetSelection(0)
- self.xygroup = self.groupList[0]
- if self.xygroup == '' or \
- self.extension == '':
- else:
- # switch to source
- self.parent.SwitchEnv('new')
-class DispMapPage(TitledPage):
- Select ungeoreferenced map to display for interactively
- setting ground control points (GCPs).
- _("Select image/map to display for ground control point (GCP) creation"))
- global maptype
- # layout
- self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select display image/map:')),
- pos=(1, 1))
- self.selection = gselect.Select(self, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE, type='cell')
- self.sizer.Add(item=self.selection,
- pos=(1, 2))
- # bindings
- self.selection.Bind(wx.EVT_TEXT, self.OnSelection)
- def OnSelection(self,event):
- """!Map to display selected"""
- global xy_map
- global maptype
- xy_map = event.GetString()
- if xy_map == '':
- else:
- try:
- # set computational region to match selected map and zoom display to region
- p = gcmd.Command(['g.region', 'rast=xy_map'])
- p = gcmd.Command(['g.region', 'vect=xy_map'])
- if p.returncode == 0:
- print 'returncode = ', str(p.returncode)
- self.parent.Map.region = self.parent.Map.GetRegion()
- except:
- pass
- global xy_map
- if event.GetDirection() and xy_map == '':
- wx.MessageBox(_('You must select a valid image/map in order to continue'))
- event.Veto()
- return
- self.parent.SwitchEnv('original')
- global maptype
- global xy_map
- self.selection.SetElementList(maptype,
- mapsets = [self.parent.newmapset, ])
- if xy_map == '':
- else:
-class GCP(wx.Frame):
- Manages ground control points for georectifying. Calculates RMS statics.
- Calls i.rectify or v.transform to georectify map.
- def __init__(self, parent, grwiz, mapdisp = None, id = wx.ID_ANY,
- title = _("Define/manage ground control points"),
- size = (625, 300)):
- wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
- # init variables
- self.parent.georectifying = self
- self.mapdisp = mapdisp # XY-location Map Display
- self.grwiz = grwiz # GR Wizard
- self.grassdatabase = self.grwiz.grassdatabase
- self.currentlocation = self.grwiz.currentlocation
- self.currentmapset = self.grwiz.currentmapset
- self.newlocation = self.grwiz.newlocation
- self.newmapset = self.grwiz.newmapset
- self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
- self.xymapset = self.grwiz.gisrc_dict['MAPSET']
- self.xygroup = self.grwiz.grouppage.xygroup
- self.extension = self.grwiz.grouppage.extension
- self.outname = ''
- self.VectGRList = []
- self.file = {
- 'points' : os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'group',
- self.xygroup,
- 'POINTS'),
- 'rgrp' : os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'group',
- self.xygroup,
- 'REF'),
- 'vgrp' : os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'group',
- self.xygroup,
- 'VREF'),
- 'target' : os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'group',
- self.xygroup,
- 'TARGET'),
- # polynomial order transformation for georectification
- self.gr_order = 1
- # number of GCPs selected to be used for georectification (checked)
- self.GCPcount = 0
- # forward RMS error
- self.fwd_rmserror = 0.0
- # backward RMS error
- self.bkw_rmserror = 0.0
- # list map coords and ID of map display they came from
- self.mapcoordlist = []
- # region clipping for georectified map
- self.clip_to_region = False
- self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
- # toolbar and display for xy map
- self.toolbar = toolbars.GCPToolbar(parent=self)
- self.SetToolBar(self.toolbar)
- self.SetMapDisplay(self.mapdisp)
- # statusbar
- self.CreateStatusBar(number=1)
- # can put guage into custom statusbar for progress if can figure out how to get progress text from i.rectify
- # self.gr_gauge = wx.Gauge(self, -1, 100, (-1,-1), (100, 25))
- # self.gr_guage.Pulse()
- panel = wx.Panel(parent=self)
- # do layout
- sizer = wx.BoxSizer(wx.VERTICAL)
- self.rb_grmethod = wx.RadioBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Select rectification method for rasters"),
- choices=[_('1st order'), _('2nd order'), _('3rd order')],
- sizer.Add(item=self.rb_grmethod, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=5)
- self.check = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("clip to computational region in target location"))
- sizer.Add(item=self.check, proportion=0,
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Ground Control Points"))
- boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- # initialize list control for GCP management
- self.list = GCPList(parent=panel, gcp=self)
- boxSizer.Add(item=self.list, proportion=1,
- flag=wx.EXPAND | wx.ALL, border=3)
- sizer.Add(item=boxSizer, proportion=1,
- flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
- # bindigs
- self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
- self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
- self.Bind(wx.EVT_CLOSE, self.OnQuit)
- self.Bind(wx.EVT_CHECKBOX, self.ClipRegion, self.check)
- panel.SetSizer(sizer)
- # sizer.Fit(self)
- def __del__(self):
- """!Disable georectification mode"""
- def ClipRegion(self, event):
- self.clip_to_region = event.IsChecked()
- def SetMapDisplay(self, win):
- self.mapdisp = win
- if self.mapdisp:
- self.list.LoadData()
- def SetTarget(self, tgroup, tlocation, tmapset):
- Sets rectification target to current location and mapset
- gcmd.RunCommand('i.target',
- parent = self,
- flags = 'c',
- group = tgroup)
- else:
- self.grwiz.SwitchEnv('new')
- parent = self,
- group = tgroup,
- location = tlocation,
- mapset = tmapset)
- self.grwiz.SwitchEnv('original')
- def AddGCP(self, event):
- Appends an item to GCP list
- self.list.AddGCPItem()
- # x, y, MapWindow instance
- self.mapcoordlist.append({ 'gcpcoord' : (0.0, 0.0, None),
- 'mapcoord' : (0.0, 0.0, None) })
- def DeleteGCP(self, event):
- Deletes selected item in GCP list
- minNumOfItems = self.OnGRMethod(None)
- if self.list.GetItemCount() <= minNumOfItems:
- wx.MessageBox(parent=self, message=_("At least %d GCPs required. Operation cancelled.") % minNumOfItems,
- caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
- return
- item = self.list.DeleteGCPItem()
- del self.mapcoordlist[item]
- def ClearGCP(self, event):
- Clears all values in selected item of GCP list and unchecks it
- index = self.list.GetSelected()
- for i in range(4):
- self.list.SetStringItem(index, i, '0.0')
- self.list.SetStringItem(index, 4, '')
- self.list.SetStringItem(index, 5, '')
- self.list.CheckItem(index, False)
- self.mapcoordlist[index] = { 'gcpcoord' : (0.0, 0.0, None),
- def DrawGCP(self, coordtype):
- Updates GCP and map coord maps and redraws
- active (checked) GCP markers
- col = UserSettings.Get(group='georect', key='symbol', subkey='color')
- wxCol = wx.Colour(col[0], col[1], col[2], 255)
- wpx = UserSettings.Get(group='georect', key='symbol', subkey='width')
- font = self.GetFont()
- penOrig = polypenOrig = None
- idx = 0
- for gcp in self.mapcoordlist:
- mapWin = gcp[coordtype][2]
- if not self.list.IsChecked(idx) or not mapWin:
- idx += 1
- continue
- if not penOrig:
- penOrig = mapWin.pen
- polypenOrig = mapWin.polypen
- mapWin.pen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID)
- mapWin.polypen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID) # ?
- coord = mapWin.Cell2Pixel((gcp[coordtype][0], gcp[coordtype][1]))
- mapWin.DrawCross(pdc=mapWin.pdcTmp, coords=coord,
- size=5, text={ 'text' : '%s' % str(idx + 1),
- 'active' : True,
- 'font' : font,
- 'color': wxCol,
- 'coords': [coord[0] + 5,
- coord[1] + 5,
- 5,
- 5]})
- idx += 1
- if penOrig:
- mapWin.pen = penOrig
- mapWin.polypen = polypenOrig
- def SetGCPData(self, coordtype, coord, mapdisp=None, check=True):
- Inserts coordinates from mouse click on map
- into selected item of GCP list and checks it for use
- if index == wx.NOT_FOUND:
- return
- coord0 = str(coord[0])
- coord1 = str(coord[1])
- if coordtype == 'gcpcoord':
- self.list.SetStringItem(index, 0, coord0)
- self.list.SetStringItem(index, 1, coord1)
- self.mapcoordlist[index]['gcpcoord'] = (coord[0], coord[1], mapdisp)
- elif coordtype == 'mapcoord':
- self.list.SetStringItem(index, 2, coord0)
- self.list.SetStringItem(index, 3, coord1)
- self.mapcoordlist[index][coordtype] = (coord[0], coord[1], mapdisp)
- self.list.CheckItem(index, check)
- # self.list.ResizeColumns()
- def SaveGCPs(self, event):
- Make a POINTS file or save GCP coordinates to existing POINTS file
- self.GCPcount = 0
- try:
- f = open(self.file['points'], mode='w')
- # use os.linesep or '\n' here ???
- f.write('# Ground Control Points File\n')
- f.write("# \n")
- f.write("# target location: " + self.currentlocation + '\n')
- f.write("# target mapset: " + self.currentmapset + '\n')
- f.write("#unrectified xy georectified east north 1=use gcp point\n")
- f.write("#-------------- ----------------------- ---------------\n")
- for index in range(self.list.GetItemCount()):
- if self.list.IsChecked(index) == True:
- check = "1"
- self.GCPcount += 1
- else:
- check = "0"
- coord0 = self.list.GetItem(index, 0).GetText()
- coord1 = self.list.GetItem(index, 1).GetText()
- coord2 = self.list.GetItem(index, 2).GetText()
- coord3 = self.list.GetItem(index, 3).GetText()
- f.write(coord0 + ' ' + coord1 + ' ' + coord2 + ' ' + coord3 + ' ' + check + '\n')
- self.parent.goutput.WriteLog(_('POINTS file <%s> saved') % self.file['points'])
- self.SetStatusText(_('POINTS file saved'))
- except IOError, err:
- message="%s <%s>. %s%s" % (_("Writing POINTS file failed"),
- self.file['points'], os.linesep, err),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- return
- f.close()
- def ReadGCPs(self):
- Reads GCPs and georectified coordinates from POINTS file
- self.GCPcount = 0
- sourceMapWin = self.mapdisp.MapWindow
- targetMapWin = self.parent.curr_page.maptree.mapdisplay.MapWindow
- try:
- f = open(self.file['points'], 'r')
- GCPcnt = 0
- if line[0] == '#' or line =='':
- continue
- coords = map(float, line.split())
- if coords[4] == 1:
- check = True
- self.GCPcount +=1
- else:
- check = False
- index = self.AddGCP(event=None)
- self.SetGCPData('gcpcoord', (coords[0], coords[1]), sourceMapWin, check)
- self.SetGCPData('mapcoord', (coords[2], coords[3]), targetMapWin, check)
- message="%s <%s>. %s%s" % (_("Reading POINTS file failed"),
- return
- f.close()
- # draw GCPs (source and target)
- sourceMapWin.UpdateMap(render=False, renderVector=False)
- if targetMapWin:
- targetMapWin.UpdateMap(render=False, renderVector=False)
- # calculate RMS
- # FIXME auto calculation on load is not working
- #if self.CheckGCPcount():
- # self.RMSError(self.xygroup, self.gr_order)
- def ReloadGCPs(self, event):
- """!Reload data from file"""
- # delete all items in mapcoordlist
- def OnFocus(self, event):
- # self.grwiz.SwitchEnv('new')
- pass
- def OnRMS(self, event):
- RMS button handler
- self.RMSError(self.xygroup,self.gr_order)
- def CheckGCPcount(self, msg=False):
- Checks to make sure that the minimum number of GCPs have been defined and
- are active for the selected transformation order
- if (self.GCPcount < 3 and self.gr_order == 1) or \
- (self.GCPcount < 6 and self.gr_order == 2) or \
- (self.GCPcount < 10 and self.gr_order == 3):
- if msg:
- caption=_("RMS Error"),
- message=_('Insufficient points defined and active (checked) '
- 'for selected rectification method.\n'
- '3+ points needed for 1st order,\n'
- '6+ points for 2nd order, and\n'
- '10+ points for 3rd order.'),
- style=wx.ICON_INFORMATION | wx.ID_OK | wx.CENTRE)
- return False
- else:
- return True
- def OnGeorect(self, event):
- Georectifies map(s) in group using i.rectify or v.transform
- global maptype
- self.SaveGCPs(None)
- if self.CheckGCPcount(msg=True) == False:
- return
- cmdlist = ['i.rectify','-a','group=%s' % self.xygroup,
- 'extension=%s' % self.extension,'order=%s' % self.gr_order]
- if self.clip_to_region:
- cmdlist.append('-c')
- self.parent.goutput.RunCmd(cmdlist, compReg=False,
- switchPage=True)
- time.sleep(.1)
- outmsg = ''
- # loop through all vectors in VREF
- # and move resulting vector to target location
- # make sure current mapset has a vector folder
- if not os.path.isdir(os.path.join(self.grassdatabase,
- self.currentlocation,
- self.currentmapset,
- 'vector')):
- os.mkdir(os.path.join(self.grassdatabase,
- 'vector'))
- # make list of vectors to georectify from VREF
- f = open(self.file['vgrp'])
- vectlist = []
- try:
- for vect in f.readlines():
- vect = vect.strip('\n')
- if len(vect) < 1:
- continue
- vectlist.append(vect)
- finally:
- f.close()
- # georectify each vector in VREF using v.transform
- for vect in vectlist:
- self.outname = vect + '_' + self.extension
- self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
- switchPage = True)
- msg = err = ''
- ret, out, err = gcmd.RunCommand('v.transform',
- flags = '-o',
- input=vect,
- output=self.outname,
- pointsfile=self.file['points'],
- getErrorMsg=True, read=True)
- if ret == 0:
- self.VectGRList.append(self.outname)
- print err
- # note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
-# self.parent.goutput.WriteLog(text = _(err), switchPage = True)
- self.parent.goutput.WriteLog(text = _(out), switchPage = True)
- else:
- self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
- self.outname)
- self.parent.goutput.WriteError(_(err))
- # FIXME
- # Copying database information not working.
- # Does not copy from xy location to current location
-# xyLayer = []
-# for layer in grass.vector_db(map = vect).itervalues():
-# xyLayer.append((layer['driver'],
-# layer['database'],
-# layer['table']))
-# dbConnect = grass.db_connection()
-# print 'db connection =', dbConnect
-# for layer in xyLayer:
-# self.parent.goutput.RunCmd(['db.copy',
-# '--q',
-# '--o',
-# 'from_driver=%s' % layer[0],
-# 'from_database=%s' % layer[1],
-# 'from_table=%s' % layer[2],
-# 'to_driver=%s' % dbConnect['driver'],
-# 'to_database=%s' % dbConnect['database'],
-# 'to_table=%s' % layer[2] + '_' + self.extension])
- # copy all georectified vectors from source location to current location
- for name in self.VectGRList:
- xyvpath = os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'vector',
- name)
- vpath = os.path.join(self.grassdatabase,
- 'vector',
- name)
- if os.path.isdir(vpath):
- self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
- 'Change extension name and '
- 'georectify again.') % self.outname)
- break
- else:
- shutil.move(xyvpath, vpath)
- wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
- 'you will need to copy any attribute tables' + '\n' +
- 'and reconnect them to the georectified vectors')
- def OnGeorectDone(self, **kargs):
- """!Print final message"""
- global maptype
- return
- returncode = kargs['returncode']
- if returncode == 0:
- print '*****vector list = ' + str(self.VectGRList)
- else:
- self.outname)
- def OnSettings(self, event):
- """!Georectifier settings"""
- dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('Georectifier settings'))
- if dlg.ShowModal() == wx.ID_OK:
- pass
- dlg.Destroy()
- def OnQuit(self, event):
- """!Quit georectifier"""
- self.grwiz.Cleanup()
- self.Destroy()
- event.Skip()
- def OnGRMethod(self, event):
- sets transformation order for georectifying
- if event:
- self.gr_order = event.GetInt() + 1
- numOfItems = self.list.GetItemCount()
- minNumOfItems = numOfItems
- if self.gr_order == 1:
- minNumOfItems = 3
- # self.SetStatusText(_('Insufficient points, 3+ points needed for 1st order'))
- elif self.gr_order == 2:
- minNumOfItems = 6
- diff = 6 - numOfItems
- # self.SetStatusText(_('Insufficient points, 6+ points needed for 2nd order'))
- elif self.gr_order == 3:
- minNumOfItems = 10
- # self.SetStatusText(_('Insufficient points, 10+ points needed for 3rd order'))
- for i in range(minNumOfItems - numOfItems):
- self.AddGCP(None)
- return minNumOfItems
- def RMSError(self, xygroup, order):
- Uses g.transform to calculate forward and backward error for each used GCP
- in POINTS file and insert error values into GCP list.
- Calculates total forward and backward RMS error for all used points
- # save GCPs to points file to make sure that all checked GCPs are used
- return
- # get list of forward and reverse rms error values for each point
- ret = gcmd.RunCommand('g.transform',
- parent = self,
- read = True,
- group = xygroup,
- order = order)
- if ret:
- errlist = ret.splitlines()
- if errlist == []:
- return
- # insert error values into GCP list for checked items
- i = 0
- sumsq_fwd_err = 0.0
- sumsq_bkw_err = 0.0
- if self.list.IsChecked(index):
- fwd_err, bkw_err = errlist[i].split()
- self.list.SetStringItem(index, 4, fwd_err)
- self.list.SetStringItem(index, 5, bkw_err)
- sumsq_fwd_err += float(fwd_err)**2
- sumsq_bkw_err += float(bkw_err)**2
- i += 1
- else:
- # calculate RMS error
- self.fwd_rmserror = round((sumsq_fwd_err/i)**0.5,4)
- self.bkw_rmserror = round((sumsq_bkw_err/i)**0.5,4)
- self.list.ResizeColumns()
- self.SetStatusText(_('RMS error for selected points forward: %(fwd)s backward: %(bkw)s') % \
- { 'fwd' : self.fwd_rmserror, 'bkw' : self.bkw_rmserror })
-class GCPList(wx.ListCtrl,
- CheckListCtrlMixin,
- ListCtrlAutoWidthMixin):
- def __init__(self, parent, gcp, id=wx.ID_ANY,
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES |
- wx.LC_SINGLE_SEL):
- wx.ListCtrl.__init__(self, parent, id, pos, size, style)
- # Mixin settings
- CheckListCtrlMixin.__init__(self)
- ListCtrlAutoWidthMixin.__init__(self)
- # TextEditMixin.__init__(self)
- self.gcp = gcp # GCP class
- # tracks whether list items are checked or not
- self.CheckList = []
- self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
- self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
- self._Create()
- self.selected = wx.NOT_FOUND
- def _Create(self):
- idx_col = 0
- for col in (_('use| X coord'),
- _('Y coord'),
- _('E coord'),
- _('N coord'),
- _('Forward error'),
- _('Backward error')):
- self.InsertColumn(idx_col, col)
- idx_col += 1
- def LoadData(self):
- """!Load data into list"""
- self.DeleteAllItems()
- if os.path.isfile(self.gcp.file['points']):
- self.gcp.ReadGCPs()
- else:
- # 3 gcp is minimum
- for i in range(3):
- self.gcp.AddGCP(None)
- # select first point by default
- self.selected = 0
- self.SetItemState(self.selected,
- wx.LIST_STATE_SELECTED,
- wx.LIST_STATE_SELECTED)
- self.ResizeColumns()
- def OnCheckItem(self, index, flag):
- """!Item is checked/unchecked"""
- pass
- def AddGCPItem(self):
- self.Append(['0.0',
- '0.0',
- '0.0',
- '0.0',
- self.selected = self.GetItemCount() - 1
- return self.selected
- def DeleteGCPItem(self):
- if self.selected == wx.NOT_FOUND:
- return
- self.DeleteItem(self.selected)
- if self.GetItemCount() > 0:
- else:
- def ResizeColumns(self):
- """!Resize columns"""
- minWidth = 90
- for i in range(self.GetColumnCount()):
- self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
- if self.GetColumnWidth(i) < minWidth:
- self.SetColumnWidth(i, minWidth)
- self.SendSizeEvent()
- def GetSelected(self):
- """!Get index of selected item"""
- def OnItemSelected(self, event):
- self.selected = event.GetIndex()
- def OnItemActivated(self, event):
- When item double clicked, open editor to update coordinate values
- coords = []
- index = event.GetIndex()
- coords.append(self.GetItem(index, i).GetText())
- dlg = EditGPC(parent=self, id=wx.ID_ANY, data=coords)
- values = dlg.GetValues() # string
- if len(values) == 0:
- caption=_("Edit GCP"),
- message=_("Invalid coordinate value. Operation cancelled."),
- style=wx.CENTRE | wx.ICON_ERROR | wx.ID_OK)
- else:
- for i in range(len(values)):
- if values[i] != coords[i]:
- self.SetStringItem(index, i, values[i])
- mapdisp = self.gcp.mapcoordlist[index]['gcpcoord'][2]
- self.gcp.mapcoordlist[index]['gcpcoord'] = (float(values[0]), float(values[1]), mapdisp)
- mapdisp = self.gcp.mapcoordlist[index]['mapcoord'][2]
- self.gcp.mapcoordlist[index]['mapcoord'] = (float(values[0]), float(values[1]), mapdisp)
-class VectGroup(wx.Dialog):
- Dialog to create a vector group (VREF file) for georectifying
- @todo Replace by g.group
- def __init__(self, parent, id, grassdb, location, mapset, group,
- style=wx.DEFAULT_DIALOG_STYLE):
- wx.Dialog.__init__(self, parent, id, style=style,
- title = _("Create vector map group"))
- self.grassdatabase = grassdb
- self.xylocation = location
- self.xymapset = mapset
- self.xygroup = group
- # get list of valid vector directories
- vectlist = os.listdir(os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'vector'))
- for dir in vectlist:
- if not os.path.isfile(os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'vector',
- dir,
- 'coor')):
- vectlist.remove(dir)
- utils.ListSortLower(vectlist)
- # path to vref file
- self.vgrpfile = os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'group',
- self.xygroup,
- 'VREF')
- # buttons
- self.btnCancel = wx.Button(parent = self,
- id = wx.ID_CANCEL)
- self.btnOK = wx.Button(parent = self,
- id = wx.ID_OK)
- self.btnOK.SetDefault()
- # list of vector maps
- self.listMap = wx.CheckListBox(parent = self, id = wx.ID_ANY,
- choices = vectlist)
- if os.path.isfile(self.vgrpfile):
- f = open(self.vgrpfile)
- try:
- checked = []
- if len(line) < 1:
- continue
- checked.append(line)
- self.listMap.SetCheckedStrings(checked)
- finally:
- f.close()
- line = wx.StaticLine(parent = self,
- id = wx.ID_ANY, size = (20, -1),
- style = wx.LI_HORIZONTAL)
- # layout
- box = wx.BoxSizer(wx.HORIZONTAL)
- box.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('Select vector map(s) to add to group:')),
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
- border = 5)
- box.Add(item = self.listMap,
- border = 5)
- sizer.Add(box, flag = wx.ALIGN_RIGHT | wx.ALL,
- border = 3)
- sizer.Add(item = line, proportion = 0,
- flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
- border = 5)
- # buttons
- btnSizer = wx.StdDialogButtonSizer()
- btnSizer.AddButton(self.btnCancel)
- btnSizer.AddButton(self.btnOK)
- btnSizer.Realize()
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER,
- border = 5)
- self.SetSizer(sizer)
- sizer.Fit(self)
- self.Layout()
- def MakeVGroup(self):
- """!Create VREF file"""
- vgrouplist = []
- for item in range(self.listMap.GetCount()):
- if not self.listMap.IsChecked(item):
- continue
- vgrouplist.append(self.listMap.GetString(item))
- f = open(self.vgrpfile, mode='w')
- try:
- for vect in vgrouplist:
- f.write(vect + '\n')
- finally:
- f.close()
-class EditGPC(wx.Dialog):
- def __init__(self, parent, data, id=wx.ID_ANY,
- title=_("Edit GCP"),
- """!Dialog for editing GPC and map coordinates in list control"""
- wx.Dialog.__init__(self, parent, id, title=title, style=style)
- label=" %s " % _("Ground Control Point"))
- # source coordinates
- gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
- self.xcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
- self.ycoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
- self.ncoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
- self.ecoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
- row = 0
- col = 0
- idx = 0
- for label, win in ((_("X:"), self.xcoord),
- (_("Y:"), self.ycoord),
- (_("E:"), self.ecoord),
- (_("N:"), self.ncoord)):
- label = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=label)
- gridSizer.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(row, col))
- col += 1
- win.SetValue(str(data[idx]))
- gridSizer.Add(item=win,
- pos=(row, col))
- col += 1
- idx += 1
- if col > 3:
- row += 1
- col = 0
- boxSizer.Add(item=gridSizer, proportion=1,
- # buttons
- self.btnCancel = wx.Button(panel, wx.ID_CANCEL)
- self.btnOk = wx.Button(panel, wx.ID_OK)
- self.btnOk.SetDefault()
- btnSizer.AddButton(self.btnOk)
- sizer.Add(item=btnSizer, proportion=0,
- flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
- sizer.Fit(self)
- def GetValues(self, columns=None):
- """!Return list of values (as strings).
- valuelist = []
- try:
- float(self.xcoord.GetValue())
- float(self.ycoord.GetValue())
- float(self.ecoord.GetValue())
- float(self.ncoord.GetValue())
- except ValueError:
- return valuelist
- valuelist.append(self.xcoord.GetValue())
- valuelist.append(self.ycoord.GetValue())
- valuelist.append(self.ecoord.GetValue())
- valuelist.append(self.ncoord.GetValue())
- return valuelist
-class GrSettingsDialog(wx.Dialog):
- def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
- wx.Dialog.__init__(self, parent, id, title, pos, size, style)
- Dialog to set profile text options: font, title
- and font size, axis labels and font size
- # initialize variables
- self.symbol = {}
- self._do_layout()
- def _do_layout(self):
- """!Do layout"""
- # dialog layout
- box = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Symbol settings"))
- gridSizer.AddGrowableCol(1)
- # symbol color
- row = 0
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Color:"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- colWin = csel.ColourSelect(parent=self, id=wx.ID_ANY,
- colour=wx.Colour(col[0],
- col[1],
- col[2],
- 255))
- self.symbol['color'] = colWin.GetId()
- gridSizer.Add(item=colWin,
- flag=wx.ALIGN_RIGHT,
- pos=(row, 1))
- # symbol width
- row += 1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Width:"))
- width = int(UserSettings.Get(group='georect', key='symbol', subkey='width'))
- widWin = wx.SpinCtrl(parent=self, id=wx.ID_ANY,
- min=1, max=10)
- widWin.SetValue(width)
- self.symbol['width'] = widWin.GetId()
- gridSizer.Add(item=widWin,
- pos=(row, 1))
- boxSizer.Add(item=gridSizer, flag=wx.EXPAND)
- sizer.Add(item=boxSizer, flag=wx.EXPAND | wx.ALL, border=5)
- line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20, -1), style=wx.LI_HORIZONTAL)
- sizer.Add(item=line, proportion=0,
- flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=3)
- # buttons
- btnSave = wx.Button(self, wx.ID_SAVE)
- btnApply = wx.Button(self, wx.ID_APPLY)
- btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnSave.SetDefault()
- # bindigs
- btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- btnApply.SetToolTipString(_("Apply changes for the current session"))
- btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
- btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
- btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
- btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
- # sizers
- btnStdSizer = wx.StdDialogButtonSizer()
- btnStdSizer.AddButton(btnCancel)
- btnStdSizer.AddButton(btnSave)
- btnStdSizer.AddButton(btnApply)
- btnStdSizer.Realize()
- sizer.Add(item=btnStdSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
- sizer.Fit(self)
- def UpdateSettings(self):
- UserSettings.Set(group='georect', key='symbol', subkey='color',
- value=tuple(wx.FindWindowById(self.symbol['color']).GetColour()))
- UserSettings.Set(group='georect', key='symbol', subkey='width',
- value=wx.FindWindowById(self.symbol['width']).GetValue())
- def OnSave(self, event):
- """!Button 'Save' pressed"""
- self.UpdateSettings()
- fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['georect'] = UserSettings.Get(group='georect')
- file = UserSettings.SaveToFile(fileSettings)
- self.parent.parent.goutput.WriteLog(_('Georectifier settings saved to file \'%s\'.') % file)
- self.Close()
- def OnApply(self, event):
- """!Button 'Apply' pressed"""
- self.Close()
- def OnCancel(self, event):
- """!Button 'Cancel' pressed"""
- self.Close()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2010-11-02 14:53:07 UTC (rev 44171)
+++ grass/trunk/gui/wxpython/wxgui.py 2010-11-02 14:53:55 UTC (rev 44172)
@@ -70,7 +70,6 @@
import gui_modules.profile as profile
import gui_modules.mcalc_builder as mapcalculator
import gui_modules.gcmd as gcmd
-import gui_modules.georect as georect
import gui_modules.dbm as dbm
import gui_modules.workspace as workspace
import gui_modules.goutput as goutput
@@ -248,11 +247,6 @@
if self.workspaceFile:
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.workspaceFile) + '*')
- def OnGeorectify(self, event):
- """!Launch georectifier module
- georect.GeorectWizard(self)
def OnGCPManager(self, event):
@@ -942,7 +936,6 @@
def OnMapCalculator(self, event, cmd = ''):
"""!Init map calculator for interactive creation of mapcalc statements
if event:
cmd = self.GetMenuCmd(event)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-11-02 14:53:07 UTC (rev 44171)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-11-02 14:53:55 UTC (rev 44172)
@@ -614,15 +614,10 @@
</menu>
<separator />
<menuitem>
- <label>Manage Ground Control Points</label>
+ <label>Georectify</label>
<help>Manage Ground Control Points for Georectification</help>
<handler>OnGCPManager</handler>
</menuitem>
- <menuitem>
- <label>Georectify</label>
- <help>Georectify raster and vector maps</help>
- <handler>OnGeorectify</handler>
- </menuitem>
<separator />
<menuitem>
<label>Graphical modeler</label>
