[GRASS-SVN] r44180 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Sat Nov 6 06:42:45 EDT 2010
Author: martinl
Date: 2010-11-06 03:42:45 -0700 (Sat, 06 Nov 2010)
New Revision: 44180
grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: set default position of windows (when .grasswx6 file is not available)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-11-06 10:37:10 UTC (rev 44179)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-11-06 10:42:45 UTC (rev 44180)
@@ -114,8 +114,9 @@
DIALOG_LAYER_SIZE = (100, -1)
DIALOG_COLOR_SIZE = (30, 30)
-MAP_WINDOW_SIZE = (770, 570)
+MAP_WINDOW_SIZE = (700, 500)
HIST_WINDOW_SIZE = (500, 350)
+GM_WINDOW_SIZE = (575, 500)
MAP_DISPLAY_STATUSBAR_MODE = [_("Coordinates"),
_("Extent"),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2010-11-06 10:37:10 UTC (rev 44179)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2010-11-06 10:42:45 UTC (rev 44180)
@@ -78,8 +78,13 @@
'general': {
# use default window layout (layer manager, displays, ...)
'defWindowPos' : {
- 'enabled' : False,
- 'dim' : ''
+ 'enabled' : True,
+ 'dim' : '%d,0,%d,%d,0,0,%d,%d' % \
+ (globalvar.MAP_WINDOW_SIZE[0],
+ globalvar.GM_WINDOW_SIZE[0],
+ globalvar.GM_WINDOW_SIZE[1],
+ globalvar.MAP_WINDOW_SIZE[0],
+ globalvar.MAP_WINDOW_SIZE[1])
# expand/collapse element list
'elementListExpand' : {
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-11-06 10:37:10 UTC (rev 44179)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-11-06 10:42:45 UTC (rev 44180)
@@ -96,7 +96,7 @@
def __init__(self, parent, id = wx.ID_ANY, title = _("GRASS GIS Layer Manager"),
workspace = None,
- size = (600, 450), style = wx.DEFAULT_FRAME_STYLE, **kwargs):
+ size = globalvar.GM_WINDOW_SIZE, style = wx.DEFAULT_FRAME_STYLE, **kwargs):
self.parent = parent
self.baseTitle = title
self.iconsize = (16, 16)
@@ -1539,6 +1539,18 @@
milliseconds=2000, parent=None, id=wx.ID_ANY)
wx.Yield()
+ w, h = wx.GetDisplaySize()
+ if globalvar.MAP_WINDOW_SIZE[0] + globalvar.GM_WINDOW_SIZE[0] > w:
+ gmX = w - globalvar.GM_WINDOW_SIZE[0]
+ dim = '%d,0,%d,%d,0,0,%d,%d' % \
+ (gmX,
+ UserSettings.Set(group = 'general', key = 'defWindowPos',
+ subkey = 'dim', value = dim)
# create and show main frame
mainframe = GMFrame(parent=None, id=wx.ID_ANY,
workspace = self.workspaceFile)
