[GRASS-SVN] r44183 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sat Nov 6 09:13:35 EDT 2010
Author: martinl
Date: 2010-11-06 06:13:35 -0700 (Sat, 06 Nov 2010)
New Revision: 44183
grass/trunk/lib/gis/list.c
clean up dox string of list.c
Modified: grass/trunk/lib/gis/list.c
--- grass/trunk/lib/gis/list.c 2010-11-06 10:47:26 UTC (rev 44182)
+++ grass/trunk/lib/gis/list.c 2010-11-06 13:13:35 UTC (rev 44183)
@@ -1,16 +1,14 @@
+ \file lib/gis/list.c
- \file list.c
\brief List elements
\author Unknown (probably CERL)
- (C) 2000 by the GRASS Development Team
+ (C) 2000, 2010 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
#include <stdlib.h>
@@ -26,28 +24,28 @@
static int list_element(FILE *, const char *, const char *, const char *,
int (*)(const char *, const char *, const char *));
- \brief General purpose list function.
- Will list files from all mapsets
- in the mapset list for a specified database element.
- Note: output is to stdout piped thru the more utility
- lister (char *name char *mapset, char* buf)
- Given file 'name', and 'mapset', lister() should copy a string into 'buf'
- when called with name == "", should set buf to general title for mapset list.
- \param element Database element (eg, "cell", "cellhd", etc)
- \param desc Description for element (if NULL, element is used)
- \param mapset Mapset to be listed "" to list all mapsets in mapset search list
- "." will list current mapset
- \param lister If given will call this routine to get a list
- title. NULL if no titles desired.
- \return
+ \brief General purpose list function
+ Will list files from all mapsets in the mapset list for a specified
+ database element.
+ Note: output is to stdout piped thru the more utility
+ \code
+ lister (char *name char *mapset, char* buf)
+ \endcode
+ Given file <em>name</em>, and </em>mapset</em>, lister() should
+ copy a string into 'buf' when called with name == "", should set
+ buf to general title for mapset list.
+ \param element database element (eg, "cell", "cellhd", etc.)
+ \param desc description for element (if NULL, element is used)
+ \param mapset mapset to be listed "" to list all mapsets in mapset search list
+ "." will list current mapset
+ \param lister if given will call this routine to get a list title.
+ NULL if no titles desired.
void G_list_element(const char *element,
const char *desc,
@@ -96,9 +94,8 @@
G_close_pager(&pager);
-static int list_element(
- FILE *out, const char *element, const char *desc, const char *mapset,
- int (*lister)(const char *, const char *, const char *))
+static int list_element(FILE *out, const char *element, const char *desc, const char *mapset,
+ int (*lister)(const char *, const char *, const char *))
char path[GPATH_MAX];
int count = 0;
@@ -166,15 +163,16 @@
- * \brief List specified type of elements. Application must release
- the allocated memory.
- * \param element Element type (G_ELEMENT_RASTER, G_ELEMENT_VECTOR,
- G_ELEMENT_REGION )
- * \param gisbase Path to GISBASE
- * \param location Location name
- * \param mapset Mapset name
- * \return Zero terminated array of element names
+ \brief List specified type of elements. Application must release
+ the allocated memory.
+ \param element element type (G_ELEMENT_RASTER, G_ELEMENT_VECTOR, G_ELEMENT_REGION )
+ \param gisbase path to GISBASE
+ \param location location name
+ \param mapset mapset name
+ \return zero terminated array of element names
char **G_list(int element, const char *gisbase, const char *location,
const char *mapset)
@@ -243,12 +241,12 @@
return list;
- \brief Free list
- \param list char* array to be freed
- \return
+ \brief Free list
+ \param list char* array to be freed
+ \return
void G_free_list(char **list)
