[GRASS-SVN] r44195 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Sat Nov 6 18:19:26 EDT 2010
Author: martinl
Date: 2010-11-06 15:19:26 -0700 (Sat, 06 Nov 2010)
New Revision: 44195
grass/trunk/gui/wxpython/xml/menudata.xml
some modules added to wxGUI menu
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-11-06 22:03:09 UTC (rev 44194)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-11-06 22:19:26 UTC (rev 44195)
@@ -208,6 +208,13 @@
<handler>OnMenuCmd</handler>
<command>v.convert</command>
</menuitem>
+ <menuitem>
+ <label>Historical GRASS vector import (all maps)</label>
+ <help>Converts all older versions of GRASS vector maps in current mapset to current format.</help>
+ <keywords>vector,import,conversion</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>v.convert.all</command>
+ </menuitem>
<separator />
<menuitem>
<label>DXF import</label>
@@ -223,6 +230,14 @@
</menuitem>
<separator />
<menuitem>
+ <label>WFS</label>
+ <help>Import GetFeature from WFS.</help>
+ <keywords>vector,import,wfs</keywords>
+ <command>v.in.wfs</command>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>ESRI e00 import</label>
<help>Import E00 file into a vector map.</help>
<keywords>vector,import</keywords>
@@ -703,7 +718,9 @@
<menuitem>
<label>Mapset access</label>
<help>Set/unset access to other mapsets in current location</help>
+ <keywords>general,settings,search path</keywords>
<handler>OnMapsets</handler>
+ <command>g.mapsets</command>
</menuitem>
<menuitem>
<label>User access</label>
@@ -881,6 +898,13 @@
<command>r.resamp.bspline</command>
</menuitem>
+ <menuitem>
+ <label>Resample using analytic kernel</label>
+ <help>Resamples raster map layers using an analytic kernel.</help>
+ <keywords>raster,resample</keywords>
+ <command>r.resamp.filter</command>
+ </menuitem>
<separator />
<menuitem>
<label>Support file maintenance</label>
