[GRASS-SVN] r44204 - grass/branches/develbranch_6/vector/v.to.db
Sat Nov 6 19:06:17 EDT 2010
Author: martinl
Date: 2010-11-06 16:06:17 -0700 (Sat, 06 Nov 2010)
New Revision: 44204
   grass/branches/develbranch_6/vector/v.to.db/parse.c
v.to.db: start/end requires at least two columns - #1208
(merge r44201 from trunk)
Modified: grass/branches/develbranch_6/vector/v.to.db/parse.c
--- grass/branches/develbranch_6/vector/v.to.db/parse.c	2010-11-06 23:04:58 UTC (rev 44203)
+++ grass/branches/develbranch_6/vector/v.to.db/parse.c	2010-11-06 23:06:17 UTC (rev 44204)
@@ -145,7 +145,10 @@
     if (!options.print) {
-	if (options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD || options.option == O_PERIMETER || options.option == O_SLOPE || options.option == O_SINUOUS || options.option == O_AZIMUTH) {	/* one column required */
+	if (options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT ||
+	    options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD ||
+	    options.option == O_PERIMETER || options.option == O_SLOPE || options.option == O_SINUOUS ||
+	    options.option == O_AZIMUTH) {	/* one column required */
 	    if (ncols != 1) {
 		G_fatal_error(_("This option requires one column"));
@@ -155,7 +158,7 @@
 		G_fatal_error(_("This option requires two columns"));
-	else if (options.option == O_COOR) {
+	else if (options.option == O_COOR || options.option == O_START || options.option == O_END) {
 	    if (ncols < 2) {
 		G_fatal_error(_("This option requires at least two columns"));
