[GRASS-SVN] r44209 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Nov 7 09:09:57 EST 2010
Author: martinl
Date: 2010-11-07 06:09:57 -0800 (Sun, 07 Nov 2010)
New Revision: 44209
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
fix #626 (layers re-renamed after change properties (wxpython))
(merge r44208 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2010-11-07 14:06:58 UTC (rev 44208)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2010-11-07 14:09:57 UTC (rev 44209)
@@ -65,7 +65,7 @@
def __init__(self, parent,
id = wx.ID_ANY, style=wx.SUNKEN_BORDER,
- ctstyle=CT.TR_HAS_BUTTONS | CT.TR_HAS_VARIABLE_ROW_HEIGHT |
+ ctstyle = CT.TR_HAS_BUTTONS | CT.TR_HAS_VARIABLE_ROW_HEIGHT |
CT.TR_HIDE_ROOT | CT.TR_ROW_LINES | CT.TR_FULL_ROW_HIGHLIGHT |
CT.TR_MULTIPLE, **kwargs):
@@ -196,6 +196,7 @@
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
self.Bind(wx.EVT_TREE_END_DRAG, self.OnEndDrag)
+ self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnRenamed)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
self.Bind(wx.EVT_IDLE, self.OnIdle)
@@ -222,9 +223,10 @@
"""!Key pressed"""
key = event.GetKeyCode()
- if key == wx.WXK_DELETE and self.lmgr:
+ if key == wx.WXK_DELETE and self.lmgr and \
+ not self.GetEditControl():
self.lmgr.OnDeleteLayer(None)
event.Skip()
def OnLayerContextMenu (self, event):
@@ -266,7 +268,7 @@
if ltype != "command": # rename
self.popupMenu.Append(self.popupID2, text=_("Rename"))
- self.Bind(wx.EVT_MENU, self.RenameLayer, id=self.popupID2)
+ self.Bind(wx.EVT_MENU, self.OnRenameLayer, id=self.popupID2)
if numSelected > 1:
self.popupMenu.Enable(self.popupID2, False)
@@ -588,12 +590,7 @@
"""!Popup opacity level indicator"""
if not self.GetPyData(self.layer_selected)[0]['ctrl']:
return
- #win = self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl'])
- #type = win.GetName()
- #self.layer_selected.DeleteWindow()
maplayer = self.GetPyData(self.layer_selected)[0]['maplayer']
current_opacity = maplayer.GetOpacity()
@@ -605,11 +602,8 @@
new_opacity = dlg.GetOpacity() # string
self.Map.ChangeOpacity(maplayer, new_opacity)
maplayer.SetOpacity(new_opacity)
- opacity_pct = int(new_opacity * 100)
- layername = self.GetItemText(self.layer_selected)
- layerbase = layername.split('(')[0].strip()
self.SetItemText(self.layer_selected,
- layerbase + ' (opacity: ' + str(opacity_pct) + '%)')
+ self._getLayerName(self.layer_selected))
# vector layer currently edited
if self.mapdisplay.toolbars['vdigit'] and \
@@ -620,9 +614,6 @@
# redraw map if auto-rendering is enabled
self.rerender = True
self.reorder = True
- #if self.mapdisplay.statusbarWin['render'].GetValue():
- # print "*** Opacity OnRender *****"
- # self.mapdisplay.OnRender(None)
def OnNvizProperties(self, event):
"""!Nviz-related properties (raster/vector/volume)
@@ -638,9 +629,18 @@
elif ltype == '3d-raster':
self.lmgr.nviz.SetPage('volume')
- def RenameLayer (self, event):
+ def OnRenameLayer (self, event):
"""!Rename layer"""
self.EditLabel(self.layer_selected)
+ self.GetEditControl().SetSelection(-1, -1)
+ def OnRenamed(self, event):
+ """!Layer renamed"""
+ item = self.layer_selected
+ self.GetPyData(item)[0]['label'] = event.GetLabel()
+ self.SetItemText(item, self._getLayerName(item)) # not working, why?
+ event.Skip()
def AddLayer(self, ltype, lname=None, lchecked=None,
lopacity=1.0, lcmd=None, lgroup=None, lvdigit=None, lnviz=None, multiple = True):
@@ -810,6 +810,7 @@
self.SetPyData(layer, ({'cmd' : cmd,
'type' : ltype,
'ctrl' : ctrlId,
+ 'label' : None,
'maplayer' : None,
'vdigit' : lvdigit,
'nviz' : lnviz,
@@ -842,11 +843,12 @@
self.PropertiesDialog(layer, show=True)
else: # group
- self.SetPyData(layer, ({'cmd': None,
- 'type' : ltype,
- 'ctrl' : None,
+ self.SetPyData(layer, ({'cmd' : None,
+ 'type' : ltype,
+ 'ctrl' : None,
+ 'label' : None,
'maplayer' : None,
- 'propwin' : None},
+ 'propwin' : None},
None))
# use predefined layer name if given
@@ -856,16 +858,12 @@
elif ltype == 'command':
ctrl.SetValue(lname)
else:
- name = lname + ' (opacity: ' + \
- str(self.GetPyData(layer)[0]['maplayer'].GetOpacity()) + '%)'
- self.SetItemText(layer, name)
+ self.SetItemText(layer, self._getLayerName(layer))
# updated progress bar range (mapwindow statusbar)
if checked is True:
self.mapdisplay.statusbarWin['progress'].SetRange(len(self.Map.GetListOfLayers(l_active=True)))
- # layer.SetHeight(TREE_ITEM_HEIGHT)
return layer
def PropertiesDialog (self, layer, show=True):
@@ -1005,10 +1003,7 @@
self.reorder = True
- # print "*** Delete OnRender *****"
if self.mapdisplay.toolbars['vdigit']:
self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers (updateTool=True)
@@ -1227,17 +1222,13 @@
self.reorder = True
- # print "*** Drop OnRender *****"
# select new item
self.SelectItem(newItem)
def RecreateItem (self, dragItem, dropTarget, parent=None):
+ """!Recreate item (needed for OnEndDrag())
- Recreate item (needed for OnEndDrag())
Debug.msg (4, "LayerTree.RecreateItem(): layer=%s" % \
self.GetItemText(dragItem))
@@ -1318,26 +1309,36 @@
return newItem
+ def _getLayerName(self, item):
+ """!Get layer name string"""
+ mapLayer = self.GetPyData(item)[0]['maplayer']
+ mapname = self.GetPyData(item)[0]['label']
+ opacity = int(mapLayer.GetOpacity(float = True) * 100)
+ if not mapname:
+ dcmd = self.GetPyData(item)[0]['cmd']
+ mapname = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
+ fullyQualified = True)
+ if not mapname:
+ return None
+ return mapname + ' (%s %d' % (_('opacity:'), opacity) + '%)'
def GetOptData(self, dcmd, layer, params, propwin):
- """!Process layer data"""
+ """!Process layer data (when changes in propertiesdialog are applied)"""
# set layer text to map name
if dcmd:
- mapLayer = self.GetPyData(layer)[0]['maplayer']
- opacity = int(mapLayer.GetOpacity(float=True) * 100)
- mapname = utils.GetLayerNameFromCmd(dcmd, layerType=mapLayer.type,
- fullyQualified=True)
+ self.GetPyData(layer)[0]['cmd'] = dcmd
+ mapname = self._getLayerName(layer)
if not mapname:
- GError(parent=self,
- message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
+ GError(parent = self,
+ message = _("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
return
- self.SetItemText(layer, mapname + ' (opacity: ' + str(opacity) + '%)')
+ self.SetItemText(layer, mapname)
# update layer data
if params:
self.SetPyData(layer, (self.GetPyData(layer)[0], params))
- if dcmd:
- self.GetPyData(layer)[0]['cmd'] = dcmd
self.GetPyData(layer)[0]['propwin'] = propwin
# change parameters for item in layers list in render.Map
@@ -1453,9 +1454,6 @@
self.reorder = True
- # print "*** Change OnRender *****"
def OnCloseWindow(self, event):
pass
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2010-11-07 14:06:58 UTC (rev 44208)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2010-11-07 14:09:57 UTC (rev 44209)
@@ -72,11 +72,11 @@
@param hidden layer is hidden, won't be listed in Layer Manager if True
@param opacity layer opacity <0;1>
- self.type = type
- self.name = name
+ self.type = type
+ self.name = name
if self.type == 'command':
- self.cmd = []
+ self.cmd = list()
for c in cmd:
self.cmd.append(utils.CmdToTuple(c))
else:
@@ -215,8 +215,7 @@
return self.mapfile
def GetCmd(self, string=False):
- Get GRASS command as list of string.
+ """!Get GRASS command as list of string.
@param string get command as string if True otherwise as list
