[GRASS-SVN] r44235 -
	grass/branches/releasebranch_6_4/display/d.rast.arrow
    svn_grass at osgeo.org
    Sun Nov  7 17:55:28 EST 2010
Author: neteler
Date: 2010-11-07 14:55:28 -0800 (Sun, 07 Nov 2010)
New Revision: 44235
   grass/branches/releasebranch_6_4/display/d.rast.arrow/description.html
HTML fix
Modified: grass/branches/releasebranch_6_4/display/d.rast.arrow/description.html
--- grass/branches/releasebranch_6_4/display/d.rast.arrow/description.html	2010-11-07 22:53:02 UTC (rev 44234)
+++ grass/branches/releasebranch_6_4/display/d.rast.arrow/description.html	2010-11-07 22:55:28 UTC (rev 44235)
@@ -44,13 +44,14 @@
 <P>
 GRASS aspect maps are measured using Cartesian conventions, i.e. in degrees
 counterclockwise from east. e.g.:
-<UL>
-<pre>
+<div class="code"><pre>
 90  North
 180 West
 270 South
-0,360 East</pre>
-</UL>
+0,360 East
+</pre></div>
 <P>
 They can be created from a raster elevation map with <em>r.slope.aspect</em>.
 <P>
@@ -64,12 +65,12 @@
 Convert U,V velocity component maps into magnitide,direction maps for use
 with <em>d.rast.arrow</em>:
-<pre>
-  r.mapcalc 'magnitude = sqrt(U_map^2 + V_map^2)'
-  r.mapcalc 'direction = atan(U_map, V_map)'
-  d.rast.arrow map=direction type=grass magnitude_map=magnitude skip=3 grid=none
-</pre>
-<BR>
+r.mapcalc "magnitude = sqrt(U_map^2 + V_map^2)"
+r.mapcalc "direction = atan(U_map, V_map)"
+d.rast.arrow map=direction type=grass magnitude_map=magnitude skip=3 grid=none
+</pre></div>
 <H2>SEE ALSO</H2>
