[GRASS-SVN] r44240 - grass/branches/releasebranch_6_4/db/base
svn_grass at osgeo.org
Sun Nov 7 18:02:28 EST 2010
Author: neteler
Date: 2010-11-07 15:02:28 -0800 (Sun, 07 Nov 2010)
New Revision: 44240
grass/branches/releasebranch_6_4/db/base/db.select.html
HTML fix
Modified: grass/branches/releasebranch_6_4/db/base/db.select.html
--- grass/branches/releasebranch_6_4/db/base/db.select.html 2010-11-07 23:00:43 UTC (rev 44239)
+++ grass/branches/releasebranch_6_4/db/base/db.select.html 2010-11-07 23:02:28 UTC (rev 44240)
@@ -32,7 +32,7 @@
<em>Select some string attribute, exclude others:</em><br>
<div class="code"><pre>
-echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
+echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
</pre></div>
<P>
