[GRASS-SVN] r44258 -
grass/branches/releasebranch_6_4/raster/r.sunmask
svn_grass at osgeo.org
Mon Nov 8 16:07:45 EST 2010
Author: martinl
Date: 2010-11-08 13:07:45 -0800 (Mon, 08 Nov 2010)
New Revision: 44258
grass/branches/releasebranch_6_4/raster/r.sunmask/main.c
r.sunmask backported from devbr6
Modified: grass/branches/releasebranch_6_4/raster/r.sunmask/main.c
--- grass/branches/releasebranch_6_4/raster/r.sunmask/main.c 2010-11-08 21:05:17 UTC (rev 44257)
+++ grass/branches/releasebranch_6_4/raster/r.sunmask/main.c 2010-11-08 21:07:45 UTC (rev 44258)
@@ -6,7 +6,7 @@
* update to FP by Huidae Cho <grass4u gmail.com> 2001
* added solpos algorithm feature by Markus Neteler 2001
* Brad Douglas <rez touchofmadness.com>, Glynn Clements <glynn gclements.plus.com>,
- * Hamish Bowman <hamish_nospam yahoo.com>, Paul Kelly <paul-grass stjohnspoint.co.uk>
+ * Hamish Bowman <hamish_b yahoo.com>, Paul Kelly <paul-grass stjohnspoint.co.uk>
* PURPOSE:
* COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
@@ -112,36 +112,24 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster");
- module->description =
- _("Calculates cast shadow areas from sun position and DEM. Either "
- "A: exact sun position is specified, or B: date/time to calculate "
- "the sun position by r.sunmask itself.");
- parm.opt1 = G_define_option();
- parm.opt1->key = "elev";
- parm.opt1->type = TYPE_STRING;
- parm.opt1->required = YES;
- parm.opt1->multiple = NO;
- parm.opt1->gisprompt = "old,cell,raster";
- parm.opt1->description = _("Name of elevation raster map");
- parm.opt2 = G_define_option();
- parm.opt2->key = "output";
- parm.opt2->type = TYPE_STRING;
- parm.opt2->required = YES;
- parm.opt2->multiple = NO;
- parm.opt2->gisprompt = "new,cell,raster";
- parm.opt2->description = _("Output raster map having shadows");
+ module->keywords = _("raster, sun position");
+ module->label = _("Calculates cast shadow areas from sun position and elevation raster map.");
+ module->description = _("Either exact sun position (A) is specified, or date/time to calculate "
+ "the sun position (B) by r.sunmask itself.");
+ parm.opt1 = G_define_standard_option(G_OPT_R_ELEV);
+ parm.opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.opt2->required = NO;
parm.opt3 = G_define_option();
parm.opt3->key = "altitude";
parm.opt3->type = TYPE_DOUBLE;
parm.opt3->required = NO;
parm.opt3->options = "0-89.999";
parm.opt3->description =
- _("A: altitude of the sun above horizon, degrees");
- parm.opt3->guisection = _("By_position");
+ _("Altitude of the sun above horizon, degrees (A)");
+ parm.opt3->guisection = _("Position");
parm.opt4 = G_define_option();
parm.opt4->key = "azimuth";
@@ -149,78 +137,89 @@
parm.opt4->required = NO;
parm.opt4->options = "0-360";
parm.opt4->description =
- _("A: azimuth of the sun from the north, degrees");
- parm.opt4->guisection = _("By_position");
+ _("Azimuth of the sun from the north, degrees (A)");
+ parm.opt4->guisection = _("Position");
parm.year = G_define_option();
parm.year->key = "year";
parm.year->type = TYPE_INTEGER;
parm.year->required = NO;
- parm.year->description = _("B: year (1950..2050)");
- parm.year->guisection = _("By_time");
+ parm.year->description = _("Year (B)");
+ parm.year->options = "1950-2050";
+ parm.year->guisection = _("Time");
parm.month = G_define_option();
parm.month->key = "month";
parm.month->type = TYPE_INTEGER;
parm.month->required = NO;
- parm.month->description = _("B: month (0..12)");
- parm.month->guisection = _("By_time");
+ parm.month->description = _("Month (B)");
+ parm.month->options = "0-12";
+ parm.month->guisection = _("Time");
parm.day = G_define_option();
parm.day->key = "day";
parm.day->type = TYPE_INTEGER;
parm.day->required = NO;
- parm.day->description = _("B: day (0..31)");
- parm.day->guisection = _("By_time");
+ parm.day->description = _("Day (B)");
+ parm.day->options = "0-31";
+ parm.day->guisection = _("Time");
parm.hour = G_define_option();
parm.hour->key = "hour";
parm.hour->type = TYPE_INTEGER;
parm.hour->required = NO;
- parm.hour->description = _("B: hour (0..24)");
- parm.hour->guisection = _("By_time");
+ parm.hour->description = _("Hour (B)");
+ parm.hour->options = "0-24";
+ parm.hour->guisection = _("Time");
parm.minutes = G_define_option();
parm.minutes->key = "minute";
parm.minutes->type = TYPE_INTEGER;
parm.minutes->required = NO;
- parm.minutes->description = _("B: minutes (0..60)");
- parm.minutes->guisection = _("By_time");
+ parm.minutes->description = _("Minutes (B)");
+ parm.minutes->options = "0-60";
+ parm.minutes->guisection = _("Time");
parm.seconds = G_define_option();
parm.seconds->key = "second";
parm.seconds->type = TYPE_INTEGER;
parm.seconds->required = NO;
- parm.seconds->description = _("B: seconds (0..60)");
- parm.seconds->guisection = _("By_time");
+ parm.seconds->description = _("Seconds (B)");
+ parm.seconds->options = "0-60";
+ parm.seconds->guisection = _("Time");
parm.timezone = G_define_option();
parm.timezone->key = "timezone";
parm.timezone->type = TYPE_INTEGER;
parm.timezone->required = NO;
- parm.timezone->description =
- _("B: timezone (east positive, offset from GMT, also use to adjust daylight savings)");
- parm.timezone->guisection = _("By_time");
+ parm.timezone->label =
+ _("Timezone");
+ parm.timezone->description = _("East positive, offset from GMT, also use to adjust daylight savings");
+ parm.timezone->guisection = _("Time");
parm.east = G_define_option();
parm.east->key = "east";
parm.east->key_desc = "value";
parm.east->type = TYPE_STRING;
parm.east->required = NO;
- parm.east->description =
- _("East coordinate (point of interest, default: map center)");
+ parm.east->label =
+ _("Easting coordinate (point of interest)");
+ parm.east->description = _("Default: map center");
+ parm.east->guisection = _("Position");
parm.north = G_define_option();
parm.north->key = "north";
parm.north->key_desc = "value";
parm.north->type = TYPE_STRING;
parm.north->required = NO;
- parm.north->description =
- _("North coordinate (point of interest, default: map center)");
+ parm.north->label =
+ _("Northing coordinate (point of interest)");
+ parm.north->description = _("Default: map center");
+ parm.north->guisection = _("Position");
flag1 = G_define_flag();
flag1->key = 'z';
- flag1->description = _("Zero is a real elevation");
+ flag1->description = _("Don't ignore zero elevation");
flag2 = G_define_flag();
flag2->key = 'v';
@@ -230,11 +229,13 @@
flag3 = G_define_flag();
flag3->key = 's';
flag3->description = _("Calculate sun position only and exit");
+ flag3->guisection = _("Print");
flag4 = G_define_flag();
flag4->key = 'g';
flag4->description =
_("Print the sun position output in shell script style");
+ flag4->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -342,7 +343,7 @@
if (retval == 0) { /* error check */
if (flag2->answer || (flag3->answer && !flag2->answer)) {
if (flag4->answer) {
- fprintf(stdout, "date=%d.%02d.%02d\n", pdat->year,
+ fprintf(stdout, "date=%d/%02d/%02d\n", pdat->year,
pdat->month, pdat->day);
fprintf(stdout, "daynum=%d\n", pdat->daynum);
fprintf(stdout, "time=%02i:%02i:%02i\n", pdat->hour,
@@ -366,24 +367,24 @@
else {
- G_message(_("%d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)"),
- pdat->year, pdat->month, pdat->day,
- pdat->daynum, pdat->hour, pdat->minute,
- pdat->second,
- pdat->hour + (pdat->minute * 100.0 / 60.0 +
- pdat->second * 100.0 / 3600.0) /
- 100.);
- G_message(_("long: %f, lat: %f, timezone: %f"),
- pdat->longitude, pdat->latitude,
- pdat->timezone);
- G_message(_("Solar position: sun azimuth: %f, sun angle above horz.(refraction corrected): %f"),
- pdat->azim, pdat->elevref);
+ fprintf(stdout, "%d/%02d/%02d, daynum: %d, time: %02i:%02i:%02i (decimal time: %f)\n",
+ pdat->year, pdat->month, pdat->day,
+ pdat->daynum, pdat->hour, pdat->minute,
+ pdat->second,
+ pdat->hour + (pdat->minute * 100.0 / 60.0 +
+ pdat->second * 100.0 / 3600.0) /
+ 100.);
+ fprintf(stdout, "long: %f, lat: %f, timezone: %f\n",
+ pdat->longitude, pdat->latitude,
+ pdat->timezone);
+ fprintf(stdout, "Solar position: sun azimuth: %f, sun angle above horz. (refraction corrected): %f\n",
+ pdat->azim, pdat->elevref);
if (sretr / 60 <= 24.0) {
- G_message(_("Sunrise time (without refraction): %02d:%02d:%02d\n"),
- sretr / 60, sretr % 60, sretr_sec);
- G_message(_("Sunset time (without refraction): %02d:%02d:%02d\n"),
- ssetr / 60, ssetr % 60, ssetr_sec);
+ fprintf(stdout, "Sunrise time (without refraction): %02d:%02d:%02d\n",
+ sretr / 60, sretr % 60, sretr_sec);
+ fprintf(stdout, "Sunset time (without refraction): %02d:%02d:%02d\n",
+ ssetr / 60, ssetr % 60, ssetr_sec);
@@ -429,7 +430,6 @@
if (flag3->answer && (use_solpos == 1)) { /* we only want the sun position */
- G_message(_("No map calculation requested. Finished."));
exit(EXIT_SUCCESS);
else if (flag3->answer && (use_solpos == 0)) {
@@ -438,6 +438,9 @@
exit(EXIT_SUCCESS);
+ if (!outname)
+ G_fatal_error(_("Option <%s> required"), parm.opt2->key);
/* Search for output layer in all mapsets ? yes. */
mapset = G_find_cell2(name, "");
@@ -470,7 +473,6 @@
row1 = 0;
G_message(_("Calculating shadows from DEM..."));
while (row1 < window.rows) {
G_percent(row1, window.rows, 2);
col1 = 0;
@@ -524,6 +526,7 @@
G_put_raster_row(output_fd, outbuf.c, CELL_TYPE);
row1 += 1;
+ G_percent(1, 1, 1);
G_close_cell(output_fd);
G_close_cell(elev_fd);
