[GRASS-SVN] r44285 -
grass/branches/releasebranch_6_4/scripts/v.db.addcol
svn_grass at osgeo.org
Tue Nov 9 09:18:29 EST 2010
Author: martinl
Date: 2010-11-09 06:18:29 -0800 (Tue, 09 Nov 2010)
New Revision: 44285
grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
v.db.addcol: windows-related fix (white spaces in the path)
(merge r44284 from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
--- grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2010-11-09 14:16:10 UTC (rev 44284)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2010-11-09 14:18:29 UTC (rev 44285)
@@ -55,7 +55,7 @@
# save command line
if [ "$1" != "@ARGS_PARSED@" ] ; then
- CMDLINE="`basename $0`"
+ CMDLINE="`basename "$0"`"
for arg in "$@" ; do
CMDLINE="$CMDLINE \"$arg\""
done
@@ -63,7 +63,7 @@
exec g.parser "$0" "$@"
fi
-PROG=`basename $0`
+PROG=`basename "$0"`
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
