[GRASS-SVN] r44293 - grass/branches/develbranch_6/vector/v.in.ascii
svn_grass at osgeo.org
Thu Nov 11 03:25:48 EST 2010
Author: neteler
Date: 2010-11-11 00:25:48 -0800 (Thu, 11 Nov 2010)
New Revision: 44293
grass/branches/develbranch_6/vector/v.in.ascii/description.html
cosmetics
Modified: grass/branches/develbranch_6/vector/v.in.ascii/description.html
--- grass/branches/develbranch_6/vector/v.in.ascii/description.html 2010-11-11 08:25:39 UTC (rev 44292)
+++ grass/branches/develbranch_6/vector/v.in.ascii/description.html 2010-11-11 08:25:48 UTC (rev 44293)
@@ -71,10 +71,7 @@
<p>
A GRASS ASCII vector map (in <b>standard format</b> mode) may contain a mix
of primitives including points, lines, boundaries, centroids, areas,
-faces, and kernels.
-<!--This format is described in the
-<a HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/doc/vector/vector.html#ascii">GRASS
-Vector ASCII Format Specification</a>.--> The GRASS ASCII vector format
+faces, and kernels. The GRASS ASCII vector format
may contain a header with various metadata (see example below).
The header is not required if the <b>-n</b> flag is used.
@@ -235,7 +232,8 @@
</pre></div>
<h3>Example 1b) - standard format mode</h3>
-Sample ASCII 3D line vector map for 'standard' format mode with simplified input.
+Sample ASCII 3D line vector map for 'standard' format mode with simplified input
+(note the space field separator).
Note the <b>-z</b> flag indicating 3D vector input, and the <b>-n</b> flag
indicating no vector header should be expected from the input file.
The example can be tested in the Spearfish sample dataset:
@@ -253,7 +251,7 @@
This can be used to create a vector line of a GPS track: the GPS points have
to be stored into a file with a preceding 'L' and the number of points (per line).
-<h3>Example 2</h3>
+<h3>Example 2 - point format mode</h3>
Generate a 2D points vector map 'coords.txt' as ASCII file:
<div class="code"><pre>
@@ -272,7 +270,7 @@
As the <b>cat</b> option is set to 0 by default, an extra column 'cat'
containing the IDs will be auto-generated.
-<h3>Example 3</h3>
+<h3>Example 3 - point format mode</h3>
Generate a 2D points vector map 'points.dat' as ASCII file:
@@ -293,7 +291,7 @@
<p>
The module is reading from standard input, using the default '|' (pipe) delimiter.
-<h3>Example 4</h3>
+<h3>Example 4 - point format mode</h3>
Generating a 3D points vector map from DBMS (idcol must be an integer column):<br>
@@ -305,7 +303,7 @@
The import works for 2D maps as well (no elev column and no '-z' flag).
-<h3>Example 5</h3>
+<h3>Example 5 - point format mode</h3>
Generate a 3D points vector map 'points3d.dat' with attributes as ASCII file:
@@ -329,7 +327,7 @@
</pre></div>
-<h3>Example 6</h3>
+<h3>Example 6 - point format mode</h3>
Generate points file by clicking onto the map:
@@ -346,7 +344,7 @@
When simply piping the coordinates (and optionally height) without additional column(s)
into <em>v.in.ascii</em>, only the vector map geometry will be generated.
-<h3>Example 7</h3>
+<h3>Example 7 - point format mode</h3>
Convert ground control points from i.points into vector points:
