[GRASS-SVN] r44318 - grass-addons/vector/v.rast.stats2
svn_grass at osgeo.org
Mon Nov 15 05:55:17 EST 2010
Author: mmetz
Date: 2010-11-15 02:55:17 -0800 (Mon, 15 Nov 2010)
New Revision: 44318
grass-addons/vector/v.rast.stats2/v.rast.stats2
use r.univar if possible, avoid v.db.addcol
Modified: grass-addons/vector/v.rast.stats2/v.rast.stats2
--- grass-addons/vector/v.rast.stats2/v.rast.stats2 2010-11-15 10:16:37 UTC (rev 44317)
+++ grass-addons/vector/v.rast.stats2/v.rast.stats2 2010-11-15 10:55:17 UTC (rev 44318)
@@ -95,6 +95,21 @@
LC_NUMERIC=C
export LC_NUMERIC
+# this can surely be done in a more elegant way...
+univar_test=` r.univar --script | grep "key: zones"`
+if [ -n "$univar_test" ] ; then
+ g.message -v "using r.univar"
+ univar_cmd="r.univar"
+else
+ # check if we have r.univar.zonal
+ if [ ! -f "$GISBASE"/bin/r.univar.zonal ] ; then
+ g.message -w "r.univar.zonal is required, please install r.univar.zonal from grass-addons"
+ exit 1
+ fi
+ g.message -v "using r.univar.zonal"
+ univar_cmd="r.univar.zonal"
+fi
#### setup temporary file
TMP="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
@@ -255,8 +270,8 @@
grep "|$CURRCOLUMN|" --quiet
if [ $? -eq 0 ] ; then
if [ $GIS_FLAG_C -ne 1 ] ; then
- g.message -e "Cannot create column <$CURRCOLUMN> (already present). \
- Use -c flag to update values in this column."
+ g.message -w "Cannot create column <$CURRCOLUMN> (already present)."
+ g.message -e "Use -c flag to update values in this column."
cleanup
exit 1
fi
@@ -275,12 +290,28 @@
if [ -n "$ADDCOLS" ] ; then
g.message -v "Adding columns <$ADDCOLS>"
- v.db.addcol map="$VECTORFULL" columns="$ADDCOLS" layer="$GIS_OPT_LAYER"
- if [ $? -ne 0 ] ; then
- g.message -e "Cannot continue (problem adding columns)."
- cleanup
+# v.db.addcol map="$VECTORFULL" columns="$ADDCOLS" layer="$GIS_OPT_LAYER"
+# if [ $? -ne 0 ] ; then
+# g.message -e "Cannot continue (problem adding columns)."
+# cleanup
+# exit 1
+# fi
+ # code borrowed from v.db.addcol
+ colnum=`echo "$ADDCOLS" | awk -F, '{print NF}'`
+ n=1
+ while [ "$n" -le "$colnum" ]
+ do
+ col=`echo "$ADDCOLS" | cut -d',' -f$n`
+ echo "ALTER TABLE $TABLE ADD COLUMN $col" | db.execute database="${DB_DATABASE}" driver="${DB_SQLDRIVER}"
+ if [ $? -eq 1 ] ; then
+ g.message -e "Cannot continue (problem adding column)."
exit 1
- fi
+ fi
+ n=`expr $n + 1`
+ done
fi
# calculate statistics for zones:
@@ -292,11 +323,11 @@
# Processing statistics
unset $BASECOLS $EXTRACOLS
if [ $GIS_FLAG_E -eq 1 ] ; then
- r.univar.zonal -t -e map="$RASTER" \
+ $univar_cmd -t -e map="$RASTER" \
zones="${VECTOR}_${TMPNAME}" percentile="$GIS_OPT_PERCENTILE" | \
cut -f1,3,5-8,10-13,15-18 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
else
- r.univar.zonal -t map="$RASTER" zones="${VECTOR}_${TMPNAME}" | \
+ $univar_cmd -t map="$RASTER" zones="${VECTOR}_${TMPNAME}" | \
cut -f1,3,5-8,10-13 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
fi
