[GRASS-SVN] r44339 - in grass/branches/releasebranch_6_4: lib/gis
raster/r.mfilter
svn_grass at osgeo.org
Mon Nov 15 17:51:04 EST 2010
Author: martinl
Date: 2010-11-15 14:51:03 -0800 (Mon, 15 Nov 2010)
New Revision: 44339
grass/branches/releasebranch_6_4/lib/gis/parser.c
grass/branches/releasebranch_6_4/raster/r.mfilter/main.c
r.mfilter: cosmetics in module description
minor changes in G_OPT_F
(merge r44338 from devbr6)
Modified: grass/branches/releasebranch_6_4/lib/gis/parser.c
--- grass/branches/releasebranch_6_4/lib/gis/parser.c 2010-11-15 22:48:22 UTC (rev 44338)
+++ grass/branches/releasebranch_6_4/lib/gis/parser.c 2010-11-15 22:51:03 UTC (rev 44339)
@@ -631,18 +631,18 @@
case G_OPT_F_INPUT:
Opt->key = "input";
Opt->type = TYPE_STRING;
- Opt->key_desc = "name";
+ Opt->key_desc = "path";
Opt->required = YES;
Opt->gisprompt = "old_file,file,input";
- Opt->description = _("Name of input file");
+ Opt->description = _("Path to input file");
break;
case G_OPT_F_OUTPUT:
Opt->key = "output";
Opt->gisprompt = "new_file,file,output";
- Opt->description = _("Name for output file");
+ Opt->description = _("Path for output file");
break;
case G_OPT_F_SEP:
Opt->key = "fs";
Modified: grass/branches/releasebranch_6_4/raster/r.mfilter/main.c
--- grass/branches/releasebranch_6_4/raster/r.mfilter/main.c 2010-11-15 22:48:22 UTC (rev 44338)
+++ grass/branches/releasebranch_6_4/raster/r.mfilter/main.c 2010-11-15 22:51:03 UTC (rev 44339)
@@ -7,7 +7,7 @@
* Glynn Clements <glynn gclements.plus.com>, Jachym Cepicky <jachym les-ejk.cz>,
* Jan-Oliver Wagner <jan intevation.de>
* PURPOSE:
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -49,7 +49,7 @@
module = G_define_module();
module->keywords = _("raster, map algebra");
- module->description = _("Raster map matrix filter.");
+ module->description = _("Performs raster map matrix filter.");
/* Define the different options */
@@ -60,7 +60,7 @@
opt3 = G_define_standard_option(G_OPT_F_INPUT);
opt3->key = "filter";
opt3->required = YES;
- opt3->description = _("Name of filter file");
+ opt3->description = _("Path to filter file");
opt4 = G_define_option();
opt4->key = "repeat";
@@ -69,7 +69,8 @@
opt4->required = NO;
opt4->answer = "1";
opt4->description = _("Number of times to repeat the filter");
+ opt4->guisection = _("Filter");
opt5 = G_define_option();
opt5->key = "title";
opt5->type = TYPE_STRING;
@@ -92,6 +93,7 @@
flag2 = G_define_flag();
flag2->key = 'z';
flag2->description = _("Apply filter only to zero data values");
+ flag2->guisection = _("Filter");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
