[GRASS-SVN] r44369 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Mon Nov 22 16:57:18 EST 2010
Author: martinl
Date: 2010-11-22 13:57:18 -0800 (Mon, 22 Nov 2010)
New Revision: 44369
grass/branches/develbranch_6/lib/python/core.py
pythonlib: fns to create new location
(merge r44368 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2010-11-22 21:56:07 UTC (rev 44368)
+++ grass/branches/develbranch_6/lib/python/core.py 2010-11-22 21:57:18 UTC (rev 44369)
@@ -917,6 +917,90 @@
return mapsets.splitlines()
+# interface to `g.proj -c`
+def create_location(location, epsg = None, proj4 = None, filename = None, wkt = None, datum = None):
+ """!Create new location
+ @param location location name to create
+ @param epgs if given create new location based on EPSG code
+ @param proj4 if given create new location based on Proj4 definition
+ @param filename if given create new location based on georeferenced file
+ @param wkt if given create new location based on WKT definition (path to PRJ file)
+ @param datum datum transformation parameters (used for epsg and proj4)
+ @return True on success
+ @return False on failure
+ if epgs:
+ ret = run_command('g.proj',
+ flags = 'c',
+ epsg = epsg,
+ location = location,
+ datumtrans = datum)
+ elif proj4:
+ flags = 'c',
+ proj4 = proj4,
+ elif filename:
+ flags = 'c',
+ georef = filename,
+ location = location)
+ elif wkt:
+ flags = 'c',
+ wkt = wktfile,
+ else:
+ ret = _create_location_xy(location)
+def _create_location_xy(location):
+ """!Create unprojected location"""
+ try:
+ os.mkdir(location)
+ os.mkdir(os.path.join(location, 'PERMANENT'))
+ # create DEFAULT_WIND and WIND files
+ regioninfo = ['proj: 0',
+ 'zone: 0',
+ 'north: 1',
+ 'south: 0',
+ 'east: 1',
+ 'west: 0',
+ 'cols: 1',
+ 'rows: 1',
+ 'e-w resol: 1',
+ 'n-s resol: 1',
+ 'top: 1',
+ 'bottom: 0',
+ 'cols3: 1',
+ 'rows3: 1',
+ 'depths: 1',
+ 'e-w resol3: 1',
+ 'n-s resol3: 1',
+ 't-b resol: 1']
+ defwind = open(os.path.join(location,
+ "PERMANENT", "DEFAULT_WIND"), 'w')
+ for param in regioninfo:
+ defwind.write(param + '%s' % os.linesep)
+ defwind.close()
+ shutil.copy(os.path.join(location, "PERMANENT", "DEFAULT_WIND"),
+ os.path.join(location, "PERMANENT", "WIND"))
+ # create MYNAME file
+ myname = open(os.path.join(location, "PERMANENT",
+ "MYNAME"), 'w')
+ myname.write('%s' % os.linesep)
+ myname.close()
+ except OSError:
+ return 1
+ return 0
# get debug_level
if find_program('g.gisenv', ['--help']):
debug_level = int(gisenv().get('DEBUG', 0))
