[GRASS-SVN] r44377 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Mon Nov 22 17:59:13 EST 2010
Author: martinl
Date: 2010-11-22 14:59:12 -0800 (Mon, 22 Nov 2010)
New Revision: 44377
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
update wxGUI menu
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-11-22 22:57:17 UTC (rev 44376)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-11-22 22:59:12 UTC (rev 44377)
@@ -160,7 +160,7 @@
<menuitem>
<label>Link vector data</label>
<help>Creates a new pseudo-vector map as a link to an OGR-supported layer.</help>
- <keywords>vector,external,ogr</keywords>
+ <keywords>vector</keywords>
<handler>OnLinkOgrLayers</handler>
<command>v.external</command>
</menuitem>
@@ -197,7 +197,7 @@
<menuitem>
<label>DXF import</label>
<help>Converts files in DXF format to GRASS vector map format.</help>
- <keywords>vector,import,dxf</keywords>
+ <keywords>vector,import</keywords>
<handler>OnImportDxfFile</handler>
<command>v.in.dxf</command>
</menuitem>
@@ -1089,7 +1089,7 @@
<menuitem>
<label>Shadows map</label>
<help>Calculates cast shadow areas from sun position and elevation raster map.</help>
- <keywords>raster</keywords>
+ <keywords>raster,sun position</keywords>
<handler>OnMenuCmd</handler>
<command>r.sunmask</command>
</menuitem>
@@ -1193,8 +1193,8 @@
</menuitem>
<menuitem>
<label>Thin</label>
- <help>Thins non-zero cells that denote linear features in a raster map layer.</help>
+ <help>Thins non-zero cells that denote linear features in a raster map.</help>
+ <keywords>raster,thin</keywords>
<command>r.thin</command>
</menuitem>
@@ -2557,7 +2557,7 @@
</menuitem>
<menuitem>
<label>Matrix/convolving filter</label>
- <help>Raster map matrix filter.</help>
+ <help>Performs raster map matrix filter.</help>
<keywords>raster,map algebra</keywords>
<command>r.mfilter</command>
