[GRASS-SVN] r44398 - grass/trunk/lib/python
svn_grass at osgeo.org
Wed Nov 24 08:49:55 EST 2010
Author: martinl
Date: 2010-11-24 05:49:55 -0800 (Wed, 24 Nov 2010)
New Revision: 44398
grass/trunk/lib/python/core.py
backport r44366
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2010-11-24 13:33:15 UTC (rev 44397)
+++ grass/trunk/lib/python/core.py 2010-11-24 13:49:55 UTC (rev 44398)
@@ -447,6 +447,14 @@
"""!Returns the name of a temporary file, created with g.tempfile."""
return read_command("g.tempfile", pid = os.getpid()).strip()
+def tempdir():
+ """!Returns the name of a temporary dir, created with g.tempfile."""
+ tmp = read_command("g.tempfile", pid = os.getpid()).strip()
+ try_remove(tmp)
+ os.mkdir(tmp)
+ return tmp
# key-value parsers
def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
@@ -793,7 +801,7 @@
"""!Attempt to remove a file; no exception is generated if the
attempt fails.
- @param path path
+ @param path path to file to remove
try:
os.remove(path)
@@ -806,12 +814,12 @@
"""!Attempt to remove a directory; no exception is generated if the
attempt fails.
- @param path path
+ @param path path to directory to remove
try:
os.rmdir(path)
except:
- pass
+ shutil.rmtree(path, ignore_errors = True)
def float_or_dms(s):
"""!Convert DMS to float.
