[GRASS-SVN] r44402 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Wed Nov 24 10:00:46 EST 2010
Author: martinl
Date: 2010-11-24 07:00:46 -0800 (Wed, 24 Nov 2010)
New Revision: 44402
Added:
grass/branches/releasebranch_6_4/lib/python/setup.py.sed
grass/branches/releasebranch_6_4/lib/python/Makefile
grass/branches/releasebranch_6_4/lib/python/core.py
grass/branches/releasebranch_6_4/lib/python/db.py
grass/branches/releasebranch_6_4/lib/python/raster.py
grass/branches/releasebranch_6_4/lib/python/vector.py
fix grass.init() & separated to new module 'setup'
(merge r44396 & r44397 from trunk)
Modified: grass/branches/releasebranch_6_4/lib/python/Makefile
--- grass/branches/releasebranch_6_4/lib/python/Makefile 2010-11-24 14:01:01 UTC (rev 44401)
+++ grass/branches/releasebranch_6_4/lib/python/Makefile 2010-11-24 15:00:46 UTC (rev 44402)
@@ -9,12 +9,13 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/script
-MODULES = core db raster vector array
+MODULES = core db raster vector array setup
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
default: $(DSTDIR)
$(MAKE) $(PYFILES)
+EXTRA_CLEAN_FILES = setup.py
$(PYDIR):
test -d $@ || $(MKDIR) -p $@
@@ -29,5 +30,10 @@
$(DSTDIR)/%: %
$(INSTALL_DATA) $< $@
+setup.py: setup.py.sed
+ sed \
+ -e 's#@LD_LIBRARY_PATH_VAR@#$(LD_LIBRARY_PATH_VAR)#' \
#doxygen:
DOXNAME = python
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2010-11-24 14:01:01 UTC (rev 44401)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2010-11-24 15:00:46 UTC (rev 44402)
@@ -1,6 +1,6 @@
"""!@package grass.script.core
- at brief GRASS Python scripting module
+ at brief GRASS Python scripting module (core functions)
Core functions to be used in Python scripts.
@@ -30,7 +30,6 @@
import atexit
import subprocess
import shutil
-import tempfile as tmpfile
# i18N
import gettext
@@ -1002,22 +1001,6 @@
return 0
-def init(gisbase, dbase, location, mapset):
- os.environ['PATH'] += ':' + os.path.join(gisbase, 'bin') + ':' + \
- os.path.join(gisbase, 'scripts')
- os.environ['LD_LIBRARY_PATH'] = os.path.join(gisbase, 'lib')
- os.environ['GIS_LOCK'] = str(os.getpid())
- fd, gisrc = tmpfile.mkstemp()
- os.environ['GISRC'] = gisrc
- fd.write("GISDBASE: %s\n" % dbase)
- fd.write("LOCATION_NAME: %s\n" % location)
- fd.write("MAPSET: %s\n" % mapset)
- fd.close()
- return gisrc
# get debug_level
if find_program('g.gisenv', ['--help']):
debug_level = int(gisenv().get('DEBUG', 0))
Modified: grass/branches/releasebranch_6_4/lib/python/db.py
--- grass/branches/releasebranch_6_4/lib/python/db.py 2010-11-24 14:01:01 UTC (rev 44401)
+++ grass/branches/releasebranch_6_4/lib/python/db.py 2010-11-24 15:00:46 UTC (rev 44402)
@@ -1,6 +1,6 @@
"""!@package grass.script.db
+ at brief GRASS Python scripting module (database functions)
Database related functions to be used in Python scripts.
Modified: grass/branches/releasebranch_6_4/lib/python/raster.py
--- grass/branches/releasebranch_6_4/lib/python/raster.py 2010-11-24 14:01:01 UTC (rev 44401)
+++ grass/branches/releasebranch_6_4/lib/python/raster.py 2010-11-24 15:00:46 UTC (rev 44402)
@@ -1,6 +1,6 @@
"""!@package grass.script.raster
+ at brief GRASS Python scripting module (raster functions)
Raster related functions to be used in Python scripts.
Copied: grass/branches/releasebranch_6_4/lib/python/setup.py.sed (from rev 44399, grass/branches/develbranch_6/lib/python/setup.py.sed)
--- grass/branches/releasebranch_6_4/lib/python/setup.py.sed (rev 0)
+++ grass/branches/releasebranch_6_4/lib/python/setup.py.sed 2010-11-24 15:00:46 UTC (rev 44402)
@@ -0,0 +1,55 @@
+"""!@package grass.script.setup
+ at brief GRASS Python scripting module (setup)
+Setup functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import setup as grass
+grass.init()
+ at endcode
+(C) 2010 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import tempfile as tmpfile
+def init(gisbase, dbase, location, mapset):
+ """!Initialize system variables to run scripts without starting
+ GRASS explicitly.
+ User is resposible to delete gisrc file.
+ @param gisbase path to GRASS installation
+ @param dbase path to GRASS database
+ @param location location name
+ @param mapset mapset within given location
+ @return path to gisrc file
+ os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin') + \
+ os.pathsep + os.path.join(gisbase, 'scripts')
+ if not os.environ.has_key('LD_LIBRARY_PATH'):
+ os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
+ os.environ['@LD_LIBRARY_PATH_VAR@'] += os.path.join(gisbase, 'lib')
+ os.environ['GIS_LOCK'] = str(os.getpid())
+ fd, gisrc = tmpfile.mkstemp()
+ os.environ['GISRC'] = gisrc
+ os.write(fd, "GISDBASE: %s\n" % dbase)
+ os.write(fd, "LOCATION_NAME: %s\n" % location)
+ os.write(fd, "MAPSET: %s\n" % mapset)
+ os.close(fd)
+ return gisrc
Modified: grass/branches/releasebranch_6_4/lib/python/vector.py
--- grass/branches/releasebranch_6_4/lib/python/vector.py 2010-11-24 14:01:01 UTC (rev 44401)
+++ grass/branches/releasebranch_6_4/lib/python/vector.py 2010-11-24 15:00:46 UTC (rev 44402)
@@ -1,6 +1,6 @@
"""!@package grass.script.vector
+ at brief GRASS Python scripting module (vector functions)
Vector related functions to be used in Python scripts.
