[GRASS-SVN] r44420 - grass/trunk/lib/python
Thu Nov 25 12:26:26 EST 2010
Author: glynn
Date: 2010-11-25 09:26:26 -0800 (Thu, 25 Nov 2010)
New Revision: 44420
   grass/trunk/lib/python/setup.py.sed
Fix missing substitution
Modified: grass/trunk/lib/python/setup.py.sed
--- grass/trunk/lib/python/setup.py.sed	2010-11-25 16:10:56 UTC (rev 44419)
+++ grass/trunk/lib/python/setup.py.sed	2010-11-25 17:26:26 UTC (rev 44420)
@@ -38,7 +38,7 @@
     os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin') + \
         os.pathsep + os.path.join(gisbase, 'scripts')
-    if not os.environ.has_key('LD_LIBRARY_PATH'):
+    if not os.environ.has_key('@LD_LIBRARY_PATH_VAR@'):
         os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
     os.environ['@LD_LIBRARY_PATH_VAR@'] += os.path.join(gisbase, 'lib')
