[GRASS-SVN] r44423 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Nov 25 16:20:28 EST 2010
Author: martinl
Date: 2010-11-25 13:20:28 -0800 (Thu, 25 Nov 2010)
New Revision: 44423
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: required/multiple boolean variables
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-11-25 21:02:20 UTC (rev 44422)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-11-25 21:20:28 UTC (rev 44423)
@@ -488,7 +488,7 @@
return errorList
for p in self.params:
- if not p.get('value', '') and p.get('required', 'no') != 'no':
+ if not p.get('value', '') and p.get('required', False):
if not p.get('default', ''):
desc = p.get('label', '')
if not desc:
@@ -515,7 +515,7 @@
else:
cmd += [ '-' + flag['name'] ]
- if p.get('value','') == '' and p.get('required','no') != 'no':
+ if p.get('value','') == '' and p.get('required', False):
if p.get('default', '') != '':
cmd += [ '%s=%s' % ( p['name'], p['default'] ) ]
elif ignoreErrors is False:
@@ -549,7 +549,7 @@
def has_required(self):
"""!Check if command has at least one required paramater"""
- if p.get('required', 'no') == 'yes':
+ if p.get('required', False):
return True
return False
@@ -617,11 +617,20 @@
for ki in node_key_desc.findall('item'):
key_desc.append(ki.text)
+ if p.get('multiple', 'no') == 'yes':
+ multiple = True
+ else:
+ multiple = False
+ if p.get('required', 'no') == 'yes':
+ required = True
+ else:
+ required = False
self.task.params.append( {
"name" : p.get('name'),
"type" : p.get('type'),
- "required" : p.get('required'),
- "multiple" : p.get('multiple'),
+ "required" : required,
+ "multiple" : multiple,
"label" : self._getNodeText(p, 'label'),
"description" : self._getNodeText(p, 'description'),
'gisprompt' : gisprompt,
@@ -1087,7 +1096,7 @@
self.Bind(wx.EVT_SIZE, self.OnSize)
for task in not_hidden:
- if task.get( 'required','no' ) == 'yes':
+ if task.get( 'required', False):
# All required go into Main, even if they had defined another guisection
task['guisection'] = _( 'Required' )
if task.get( 'guisection','' ) == '':
@@ -1228,14 +1237,14 @@
txt = None
# text style (required -> bold)
- if p.get('required','no') == 'no':
+ if not p.get('required', False):
text_style = wx.FONTWEIGHT_NORMAL
else:
text_style = wx.FONTWEIGHT_BOLD
# title sizer (description, name, type)
if (len(p.get('values', []) ) > 0) and \
- p.get('multiple', 'no') == 'yes' and \
+ p.get('multiple', False) and \
p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
title_txt = wx.StaticBox (parent=which_panel, id=wx.ID_ANY)
@@ -1257,7 +1266,7 @@
self.label_id.append(title_txt.GetId())
# title expansion
- if p.get('multiple','no') == 'yes' and len( p.get('values','') ) == 0:
+ if p.get('multiple', False) and len( p.get('values','') ) == 0:
title = _("[multiple]") + " " + title
if p.get('value','') == '' :
p['value'] = p.get('default','')
@@ -1266,7 +1275,7 @@
valuelist = map(str, p.get('values',[]))
valuelist_desc = map(unicode, p.get('values_desc',[]))
- if p.get('multiple', 'no') == 'yes' and \
+ if p.get('multiple', False) and \
title_txt.SetLabel(" %s: (%s, %s) " % (title, p['name'], p['type']))
@@ -1310,7 +1319,7 @@
str(valuelist[0])))
if p.get('type', '') == 'integer' and \
- p.get('multiple','no') == 'no':
+ not p.get('multiple', False):
# for multiple integers use textctrl instead of spinsctrl
try:
@@ -1362,7 +1371,7 @@
and p.get('prompt','') != 'color'):
title_txt.SetLabel(title + ':' )
- if p.get('multiple','yes') == 'yes' or \
+ if p.get('multiple', False) or \
p.get('type', 'string') == 'string' or \
len(p.get('key_desc', [])) > 1:
txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''))
@@ -2413,7 +2422,7 @@
"name" : "plain_color",
"description" : "This is a plain color, and it is a compulsory parameter",
- "required" : "yes",
+ "required" : False,
"gisprompt" : True,
"prompt" : "color"
@@ -2455,7 +2464,7 @@
"name" : "a",
"description" : "Some flag, will appear in Main since it is required",
+ "required" : True
"name" : "b",
"description" : "pre-filled flag, will appear in options since it is not required",
