[GRASS-SVN] r44426 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Thu Nov 25 16:37:46 EST 2010
Author: martinl
Date: 2010-11-25 13:37:46 -0800 (Thu, 25 Nov 2010)
New Revision: 44426
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: use suppress_required
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2010-11-25 21:25:44 UTC (rev 44425)
+++ grass/trunk/raster/r.in.gdal/main.c 2010-11-25 21:37:46 UTC (rev 44426)
@@ -80,20 +80,15 @@
G_add_keyword(_("raster"));
G_add_keyword(_("import"));
module->description =
- _("Import raster data into a GRASS map layer using GDAL.");
+ _("Imports raster data into a GRASS raster map using GDAL library.");
/* Setup and fetch parameters. */
- parm.input = G_define_standard_option(G_OPT_R_INPUT);
+ parm.input = G_define_standard_option(G_OPT_F_INPUT);
parm.input->description = _("Raster file to be imported");
- parm.input->gisprompt = "old_file,file,input";
- parm.input->required = NO; /* not required because of -f flag */
- parm.input->guisection = _("Required");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.output->required = NO; /* not required because of -f flag */
- parm.output->guisection = _("Required");
parm.band = G_define_option();
parm.band->key = "band";
@@ -113,6 +108,7 @@
parm.target->required = NO;
parm.target->description =
_("Name of location to read projection from for GCPs transformation");
+ parm.target->key_desc = "name";
parm.title = G_define_option();
parm.title->key = "title";
@@ -127,6 +123,7 @@
parm.outloc->type = TYPE_STRING;
parm.outloc->required = NO;
parm.outloc->description = _("Name for new location to create");
+ parm.outloc->key_desc = "name";
flag_o = G_define_flag();
flag_o->key = 'o';
@@ -141,7 +138,8 @@
flag_f->key = 'f';
flag_f->description = _("List supported formats and exit");
flag_f->guisection = _("Print");
+ flag_f->suppress_required = 1;
flag_l = G_define_flag();
flag_l->key = 'l';
flag_l->description =
@@ -222,13 +220,6 @@
exit(EXIT_SUCCESS);
- if (!input)
- G_fatal_error(_("Required parameter <%s> not set"), parm.input->key);
- if (!output)
- G_fatal_error(_("Name for output raster map not specified"));
if (!parm.outloc->answer) { /* Check if the map exists */
if (G_find_raster2(output, G_mapset())) {
if (overwrite)
