[GRASS-SVN] r44433 - grass/trunk/lib/gis
Fri Nov 26 12:34:46 EST 2010
Author: martinl
Date: 2010-11-26 09:34:46 -0800 (Fri, 26 Nov 2010)
New Revision: 44433
   grass/trunk/lib/gis/parser.c
call G_usage() when level is verbose
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2010-11-26 14:15:35 UTC (rev 44432)
+++ grass/trunk/lib/gis/parser.c	2010-11-26 17:34:46 UTC (rev 44433)
@@ -421,7 +421,7 @@
 	return -1;
     else if (argc < 2 && st->has_required && isatty(0)) {
-	G_usage();
+      	G_usage();
 	return -1;
     else if (argc >= 2) {
@@ -559,7 +559,7 @@
 	error += check_required();
     if (error) {
-	if (G_verbose() > G_verbose_min())
+	if (G_verbose() > G_verbose_std())
 	    G_usage();
 	return -1;
@@ -1140,7 +1140,7 @@
     while (opt) {
 	if (opt->required && !opt->answer) {
 	    fprintf(stderr,
-		    _("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
+		    _("ERROR: Required parameter <%s> not set:\n\t(%s)\n"),
 		    opt->key, (opt->label ? opt->label : opt->description) );
 	    err++;
