[GRASS-SVN] r44436 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Fri Nov 26 13:23:07 EST 2010
Author: martinl
Date: 2010-11-26 10:23:07 -0800 (Fri, 26 Nov 2010)
New Revision: 44436
grass/trunk/raster/r.out.gdal/main.c
r.out.gdal: suppress required for -l
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2010-11-26 17:41:46 UTC (rev 44435)
+++ grass/trunk/raster/r.out.gdal/main.c 2010-11-26 18:23:07 UTC (rev 44436)
@@ -133,6 +133,7 @@
flag_l->key = 'l';
flag_l->description = _("List supported output formats");
flag_l->guisection = _("Print");
+ flag_l->suppress_required = TRUE;
flag_c = G_define_flag();
flag_c->key = 'c';
@@ -145,10 +146,11 @@
flag_f->description = _("Overrides nodata safety check.");
input = G_define_standard_option(G_OPT_R_INPUT);
- input->required = NO;
input->description = _("Name of raster map (or group) to export");
- input->guisection = _("Required");
+ output = G_define_standard_option(G_OPT_F_OUTPUT);
+ output->description = _("Name for output raster file");
format = G_define_option();
format->key = "format";
format->type = TYPE_STRING;
@@ -170,7 +172,8 @@
#endif
format->answer = "GTiff";
format->required = NO;
+ format->guisection = _("Format");
type = G_define_option();
type->key = "type";
type->type = TYPE_STRING;
@@ -178,13 +181,8 @@
type->options =
"Byte,Int16,UInt16,Int32,UInt32,Float32,Float64,CInt16,CInt32,CFloat32,CFloat64";
type->required = NO;
+ type->guisection = _("Format");
- output = G_define_standard_option(G_OPT_R_OUTPUT);
- output->required = NO;
- output->gisprompt = "new_file,file,output";
- output->description = _("Name for output raster file");
- output->guisection = _("Required");
createopt = G_define_option();
createopt->key = "createopt";
createopt->type = TYPE_STRING;
@@ -227,10 +225,7 @@
supported_formats(&gdal_formats);
exit(EXIT_SUCCESS);
- if (!input->answer)
- G_fatal_error(_("Required parameter <%s> not set"), input->key);
/* Try to open input GRASS raster.. */
mapset = G_find_raster2(input->answer, "");
@@ -408,8 +403,8 @@
/* got a GDAL datatype, report to user */
- G_message(_("Exporting to GDAL data type: %s"),
- GDALGetDataTypeName(datatype));
+ G_verbose_message(_("Exporting to GDAL data type: %s"),
+ GDALGetDataTypeName(datatype));
G_debug(3, "Input map datatype=%s\n",
(maptype == CELL_TYPE ? "CELL" :
@@ -488,7 +483,7 @@
/* exact range and nodata checks for each band */
- G_message(_("Checking GDAL data type and nodata value"));
+ G_message(_("Checking GDAL data type and nodata value..."));
for (band = 0; band < ref.nfiles; band++) {
if (ref.nfiles > 1) {
G_verbose_message(_("Checking options for raster map <%s> (band %d)..."),
@@ -531,8 +526,6 @@
GDALDatasetH hCurrDS = NULL, hMEMDS = NULL, hDstDS = NULL;
- if (!output->answer)
- G_fatal_error(_("Output file name not specified"));
if (hMEMDriver) {
hMEMDS =
GDALCreate(hMEMDriver, "", cellhead.cols, cellhead.rows,
@@ -576,7 +569,7 @@
AttachMetadata(hCurrDS, metaopt->answers);
/* Export to GDAL raster */
- G_message(_("Exporting to GDAL raster"));
+ G_message(_("Exporting raster data to %s format..."), format->answer);
G_verbose_message(_("Exporting raster map <%s> (band %d)..."),
@@ -615,7 +608,7 @@
CSLDestroy(papszOptions);
- G_done_msg(" ");
+ G_done_msg("File <%s> created.", output->answer);
exit(EXIT_SUCCESS);
