[GRASS-SVN] r44454 - grass/trunk/raster/r.external
svn_grass at osgeo.org
Sat Nov 27 16:48:00 EST 2010
Author: martinl
Date: 2010-11-27 13:48:00 -0800 (Sat, 27 Nov 2010)
New Revision: 44454
grass/trunk/raster/r.external/main.c
r.external: use suppress_required
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c 2010-11-27 21:44:04 UTC (rev 44453)
+++ grass/trunk/raster/r.external/main.c 2010-11-27 21:48:00 UTC (rev 44454)
@@ -7,7 +7,7 @@
* PURPOSE: Link raster map into GRASS utilizing the GDAL library.
- * COPYRIGHT: (C) 2008 by Glynn Clements and the GRASS Development Team
+ * COPYRIGHT: (C) 2008, 2010 by Glynn Clements and the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -522,14 +522,13 @@
module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("import"));
+ G_add_keyword(_("external"));
module->description =
- _("Link GDAL supported raster data as a pseudo GRASS raster map layer.");
+ _("Link GDAL supported raster data as a pseudo GRASS raster map.");
parm.input = G_define_standard_option(G_OPT_F_INPUT);
parm.input->description = _("Raster file to be linked");
- parm.input->required = NO;
- parm.input->guisection = _("Required");
parm.source = G_define_option();
parm.source->key = "source";
parm.source->description = _("Name of non-file GDAL data source");
@@ -537,9 +536,7 @@
parm.source->type = TYPE_STRING;
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.output->required = NO; /* not required because of -f flag */
- parm.output->guisection = _("Required");
parm.band = G_define_option();
parm.band->key = "band";
parm.band->type = TYPE_INTEGER;
@@ -571,7 +568,8 @@
flag_f->key = 'f';
flag_f->description = _("List supported formats and exit");
flag_f->guisection = _("Print");
+ flag_f->suppress_required = TRUE;
flag_h = G_define_flag();
flag_h->key = 'h';
flag_h->description = _("Flip horizontally");
