[GRASS-SVN] r44457 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Sun Nov 28 11:16:29 EST 2010
Author: mmetz
Date: 2010-11-28 08:16:29 -0800 (Sun, 28 Nov 2010)
New Revision: 44457
grass/trunk/vector/v.in.ogr/main.c
cosmetics, be a bit more user-friendly
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2010-11-28 12:53:53 UTC (rev 44456)
+++ grass/trunk/vector/v.in.ogr/main.c 2010-11-28 16:16:29 UTC (rev 44457)
@@ -96,6 +96,7 @@
char **available_layer_names; /* names of layers to be imported */
int navailable_layers;
int layer_id;
+ unsigned int n_features, feature_count;
int overwrite;
double area_size = 0.;
@@ -615,14 +616,8 @@
G_find_vector(buf, G_mapset());
sprintf(tempvect, "%s_tmp", buf);
G_verbose_message(_("Using temporary vector <%s>"), tempvect);
- if (z_flag->answer) {
- Vect_open_new(&Map, out_opt->answer, 1);
- Vect_open_new(&Tmp, tempvect, 1);
- else {
- Vect_open_new(&Map, out_opt->answer, 0);
- Vect_open_new(&Tmp, tempvect, 0);
+ Vect_open_new(&Map, out_opt->answer, z_flag->answer != 0);
+ Vect_open_new(&Tmp, tempvect, z_flag->answer != 0);
Vect_hist_command(&Map);
@@ -815,7 +810,7 @@
cat = 1;
nogeom = 0;
OGR_L_ResetReading(Ogr_layer);
- unsigned int n_features = 0, feature_count = 0;
+ n_features = feature_count = 0;
n_polygon_boundaries = 0;
n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
@@ -998,7 +993,7 @@
G_message(_("Remove duplicates:"));
Vect_remove_duplicates(&Tmp, GV_BOUNDARY | GV_CENTROID, NULL);
- /* split boundaries here ? */
+ /* in non-pathological cases, the bulk of the cleaning is now done */
/* Vect_clean_small_angles_at_nodes() can change the geometry so that new intersections
* are created. We must call Vect_break_lines(), Vect_remove_duplicates()
@@ -1024,7 +1019,7 @@
Vect_chtype_dangles(&Tmp, -1.0, NULL);
else {
- G_message(_("Change dangles to lines:"));
+ G_message(_("Remove dangles:"));
Vect_remove_dangles(&Tmp, GV_BOUNDARY, -1.0, NULL);
@@ -1077,11 +1072,14 @@
G_message(_("Find centroids for layer: %s"), layer_names[layer]);
layer_id = layers[layer];
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
+ n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
cat = 0; /* field = layer + 1 */
+ G_percent(cat, n_features, 2);
while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
cat++;
/* Geometry */
Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
if (Ogr_geometry != NULL) {
@@ -1137,13 +1135,6 @@
Vect_spatial_index_destroy(&si);
- /* G_message("%s", separator); */
- /* Vect_build_partial(&Map, GV_BUILD_NONE); */
- /* not needed */
- Vect_build(&Map); */
if (n_overlaps > 0) {
G_warning(_("%d areas represent more (overlapping) features, because polygons overlap "
"in input layer(s). Such areas are linked to more than 1 row in attribute table. "
@@ -1183,6 +1174,8 @@
/* Copy temporary vector to output vector */
Vect_copy_map_lines(&Tmp, &Map);
+ /* release memory occupied by topo, we may need that memory for main output */
+ Vect_set_release_support(&Tmp);
Vect_close(&Tmp);
Vect_delete(tempvect);
