[GRASS-SVN] r44460 - grass/trunk/lib/vector/Vlib
Sun Nov 28 11:23:44 EST 2010
Author: mmetz
Date: 2010-11-28 08:23:44 -0800 (Sun, 28 Nov 2010)
New Revision: 44460
   grass/trunk/lib/vector/Vlib/remove_areas.c
adjusted progress report
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2010-11-28 16:22:35 UTC (rev 44459)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2010-11-28 16:23:44 UTC (rev 44460)
@@ -50,12 +50,11 @@
     Cats = Vect_new_cats_struct();
     nareas = Vect_get_num_areas(Map);
-    for (area = 1; area <= Vect_get_num_areas(Map); area++) {
+    for (area = 1; area <= nareas; area++) {
 	int i, j, centroid, dissolve_neighbour;
 	double length, size;
-	if (area <= nareas)
-	    G_percent(area, nareas, 1);
+	G_percent(area, nareas, 1);
 	G_debug(3, "area = %d", area);
 	if (!Vect_area_alive(Map, area))
 	    continue;
@@ -170,6 +169,7 @@
 	nremoved++;
+	nareas = Vect_get_num_areas(Map);
     if (removed_area)
