[GRASS-SVN] r44463 - grass/branches/develbranch_6/vector/v.out.ogr
svn_grass at osgeo.org
Sun Nov 28 12:40:34 EST 2010
Author: mmetz
Date: 2010-11-28 09:40:34 -0800 (Sun, 28 Nov 2010)
New Revision: 44463
grass/branches/develbranch_6/vector/v.out.ogr/main.c
format code
Modified: grass/branches/develbranch_6/vector/v.out.ogr/main.c
--- grass/branches/develbranch_6/vector/v.out.ogr/main.c 2010-11-28 17:33:42 UTC (rev 44462)
+++ grass/branches/develbranch_6/vector/v.out.ogr/main.c 2010-11-28 17:40:34 UTC (rev 44463)
@@ -155,7 +155,8 @@
nocat_flag = G_define_flag();
nocat_flag->key = 's';
- nocat_flag->description = _("Skip export of GRASS category ID ('cat') attribute");
+ nocat_flag->description =
+ _("Skip export of GRASS category ID ('cat') attribute");
cat_flag->key = 'c';
@@ -174,7 +175,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* read options */
field = atoi(field_opt->answer);
@@ -187,78 +187,78 @@
Vect_open_old(&In, in_opt->answer, "");
- If no output type specified: determine one automatically.
- Centroids, Boundaries and Kernels always have to be
- exported explicitely, using the "type=" option.
- if (!strcmp(type_opt->answer, "auto" )) {
- G_debug(2, "Automatic type determination." );
+ If no output type specified: determine one automatically.
+ Centroids, Boundaries and Kernels always have to be
+ exported explicitely, using the "type=" option.
+ if (!strcmp(type_opt->answer, "auto")) {
+ G_debug(2, "Automatic type determination.");
- type_opt->answers = G_malloc (sizeof(char*) * 100); /* should be big enough forever ;) */
- for (i=0;i<100;i++) {
- type_opt->answers[i] = NULL;
- num_types = 0;
+ type_opt->answers = G_malloc(sizeof(char *) * 100); /* should be big enough forever ;) */
+ for (i = 0; i < 100; i++) {
+ type_opt->answers[i] = NULL;
+ num_types = 0;
- if ( Vect_get_num_primitives ( &In, GV_POINT ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "point" );
- G_debug(3, "Adding points to export list." );
- num_types ++;
+ if (Vect_get_num_primitives(&In, GV_POINT) > 0) {
+ type_opt->answers[num_types] = strdup("point");
+ G_debug(3, "Adding points to export list.");
+ num_types++;
- if ( Vect_get_num_primitives ( &In, GV_LINE ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "line" );
- G_debug(3, "Adding lines to export list." );
- num_types ++;
+ if (Vect_get_num_primitives(&In, GV_LINE) > 0) {
+ type_opt->answers[num_types] = strdup("line");
+ G_debug(3, "Adding lines to export list.");
+ num_types++;
- if ( Vect_get_num_primitives ( &In, GV_BOUNDARY ) !=
- Vect_get_num_areas ( &In ) )
- G_warning(_("Skipping all boundaries that are not part of an area."));
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) !=
+ Vect_get_num_areas(&In)) {
+ G_warning(_("Skipping all boundaries that are not part of an area."));
- if ( Vect_get_num_areas ( &In ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "area" );
- G_debug(3, "Adding areas to export list." );
- num_types ++;
+ if (Vect_get_num_areas(&In) > 0) {
+ type_opt->answers[num_types] = strdup("area");
+ G_debug(3, "Adding areas to export list.");
+ num_types++;
- /* Faces and volumes:
- For now, volumes will just be exported as sets of faces.
- if ( Vect_get_num_primitives ( &In, GV_FACE ) > 0 ) {
- type_opt->answers[num_types] = strdup ( "face" );
- G_debug(3, "Adding faces to export list." );
- num_types ++;
- /* this check HAS TO FOLLOW RIGHT AFTER check for GV_FACE! */
- if ( Vect_get_num_volumes ( &In ) > 0 ) {
- G_warning(_("Volumes will be exported as sets of faces."));
- if ( num_types == 0 ) {
- /* no other types yet? */
- type_opt->answers[num_types] = strdup ( "volume" );
- G_debug(3, "Adding volumes to export list." );
- num_types ++;
- } else {
- if ( strcmp ( type_opt->answers[num_types-1], "face" ) ) {
- /* only put faces on export list if that's not the case already */
- num_types ++;
+ /* Faces and volumes:
+ For now, volumes will just be exported as sets of faces.
+ if (Vect_get_num_primitives(&In, GV_FACE) > 0) {
+ type_opt->answers[num_types] = strdup("face");
+ G_debug(3, "Adding faces to export list.");
+ num_types++;
+ /* this check HAS TO FOLLOW RIGHT AFTER check for GV_FACE! */
+ if (Vect_get_num_volumes(&In) > 0) {
+ G_warning(_("Volumes will be exported as sets of faces."));
+ if (num_types == 0) {
+ /* no other types yet? */
+ type_opt->answers[num_types] = strdup("volume");
+ G_debug(3, "Adding volumes to export list.");
+ num_types++;
+ else {
+ if (strcmp(type_opt->answers[num_types - 1], "face")) {
+ /* only put faces on export list if that's not the case already */
+ num_types++;
- G_fatal_error(_("Could not determine input map's feature type(s)."));
+ G_fatal_error(_("Could not determine input map's feature type(s)."));
/* Check output type */
otype = Vect_option_to_types(type_opt);
if (!layer_opt->answer) {
- char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
if (G__name_is_fully_qualified(in_opt->answer, xname, xmapset))
layer_opt->answer = G_store(xname);
@@ -353,13 +353,15 @@
i++;
- if (update_flag->answer) {
- G_debug(1, "Update OGR data source");
+ if (update_flag->answer) {
+ G_debug(1, "Update OGR data source");
Ogr_ds = OGR_Dr_Open(Ogr_driver, dsn_opt->answer, TRUE);
- } else {
- G_debug(1, "Create OGR data source");
- Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
+ else {
+ G_debug(1, "Create OGR data source");
+ Ogr_ds =
+ OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
CSLDestroy(papszDSCO);
if (Ogr_ds == NULL)
@@ -418,8 +420,8 @@
/* if we have no more than a 'cat' column, then that has to
be exported in any case */
if (nocat_flag->answer) {
- G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
- nocat_flag->answer=0;
+ G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
+ nocat_flag->answer = 0;
Ogr_field = OGR_Fld_Create("cat", OFTInteger);
OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
@@ -479,14 +481,16 @@
if (!nocat_flag->answer) {
Ogr_field =
- OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
+ OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
OGR_Fld_Destroy(Ogr_field);
- } else {
+ else {
/* skip export of 'cat' field */
- if (strcmp (Fi->key,db_get_column_name(Column)) != 0) {
+ if (strcmp(Fi->key, db_get_column_name(Column)) != 0) {
Ogr_field =
+ ogr_ftype);
@@ -495,7 +499,6 @@
if (keycol == -1)
G_fatal_error(_("Key column '%s' not found"), Fi->key);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
@@ -522,8 +525,8 @@
if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
!(otype & GV_CENTROID) && !(otype & GV_AREA))
G_warning(_("%d centroid(s) found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_primitives(&In,
- GV_CENTROID));
+ "Verify 'type' parameter."), Vect_get_num_primitives(&In,
+ GV_CENTROID));
if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
G_warning(_("%d areas found, but not requested to be exported. "
@@ -537,8 +540,8 @@
if (Vect_get_num_primitives(&In, GV_KERNEL) > 0 &&
!(otype & GV_KERNEL) && !(otype & GV_VOLUME))
G_warning(_("%d kernel(s) found, but not requested to be exported. "
- GV_KERNEL));
+ GV_KERNEL));
if (Vect_get_num_volumes(&In) > 0 && !(otype & GV_VOLUME))
G_warning(_("%d volume(s) found, but not requested to be exported. "
@@ -547,73 +550,89 @@
/* warn and eventually abort if there is nothing to be exported */
num_to_export = 0;
if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
- G_warning(_("No points found, but requested to be exported. "
+ G_warning(_("No points found, but requested to be exported. "
"Will skip this geometry type."));
- } else {
- if (otype & GV_POINT)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+ else {
+ if (otype & GV_POINT)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_POINT);
if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
- G_warning(_("No lines found, but requested to be exported. "
+ G_warning(_("No lines found, but requested to be exported. "
- } else {
- if (otype & GV_LINE)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+ else {
+ if (otype & GV_LINE)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_LINE);
- if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 && (otype & GV_BOUNDARY)) {
- G_warning(_("No boundaries found, but requested to be exported. "
- "Will skip this geometry type."));
- } else {
- if (otype & GV_BOUNDARY)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
+ (otype & GV_BOUNDARY)) {
+ G_warning(_("No boundaries found, but requested to be exported. "
+ "Will skip this geometry type."));
+ else {
+ if (otype & GV_BOUNDARY)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
- G_warning(_("No areas found, but requested to be exported. "
+ G_warning(_("No areas found, but requested to be exported. "
- } else {
- if (otype & GV_AREA)
- num_to_export = num_to_export + Vect_get_num_areas(&In);
+ else {
+ if (otype & GV_AREA)
+ num_to_export = num_to_export + Vect_get_num_areas(&In);
- if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 && (otype & GV_CENTROID)) {
- G_warning(_("No centroids found, but requested to be exported. "
- } else {
- if (otype & GV_CENTROID)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+ if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
+ (otype & GV_CENTROID)) {
+ G_warning(_("No centroids found, but requested to be exported. "
+ else {
+ if (otype & GV_CENTROID)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
- G_warning(_("No faces found, but requested to be exported. "
+ G_warning(_("No faces found, but requested to be exported. "
- } else {
- if (otype & GV_FACE)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+ else {
+ if (otype & GV_FACE)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_FACE);
if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
- G_warning(_("No kernels found, but requested to be exported. "
+ G_warning(_("No kernels found, but requested to be exported. "
- } else {
- if (otype & GV_KERNEL)
- num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+ else {
+ if (otype & GV_KERNEL)
+ num_to_export =
+ num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
- G_warning(_("No volumes found, but requested to be exported. "
+ G_warning(_("No volumes found, but requested to be exported. "
- } else {
- if (otype & GV_VOLUME)
- num_to_export = num_to_export + Vect_get_num_volumes(&In);
+ else {
+ if (otype & GV_VOLUME)
+ num_to_export = num_to_export + Vect_get_num_volumes(&In);
G_debug(1, "Requested to export %d geometries", num_to_export);
if (num_to_export < 1) {
- G_warning(_("Nothing to export"));
+ G_warning(_("Nothing to export"));
exit(EXIT_SUCCESS);
@@ -638,7 +657,6 @@
continue;
/* Geometry */
if (type == GV_LINE && poly_flag->answer) {
OGRGeometryH ring;
@@ -660,7 +678,8 @@
OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
- else if ((type == GV_POINT) || ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
+ else if ((type == GV_POINT) ||
+ ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
Points->z[0]);
@@ -690,7 +709,8 @@
continue;
- mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer, Ogr_feature);
+ mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer,
+ Ogr_feature);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
@@ -764,7 +784,8 @@
continue;
+ Ogr_feature);
@@ -795,7 +816,7 @@
if (type & GV_FACE) {
- Ogr_feature = OGR_F_Create(Ogr_featuredefn);
+ Ogr_feature = OGR_F_Create(Ogr_featuredefn);
/* Geometry */
Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
@@ -824,14 +845,14 @@
continue;
+ Ogr_feature);
OGR_F_Destroy(Ogr_feature);
} /* if type & GV_FACE */
} /* for */
@@ -856,48 +877,48 @@
continue;
/* Geometry */
if (type == GV_KERNEL) {
- Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
- OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
- Points->z[0]);
+ Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
+ OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+ Points->z[0]);
- OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
+ OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
- /* Output one feature for each category */
- for (j = -1; j < Cats->n_cats; j++) {
- if (j == -1) {
- if (cat >= 0)
- continue; /* cat(s) exists */
- else {
- if (Cats->field[j] == field)
- cat = Cats->cat[j];
- else
- continue;
+ /* Output one feature for each category */
+ for (j = -1; j < Cats->n_cats; j++) {
+ if (j == -1) {
+ if (cat >= 0)
+ continue; /* cat(s) exists */
+ else {
+ if (Cats->field[j] == field)
+ cat = Cats->cat[j];
+ else
+ continue;
- OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
- OGR_G_DestroyGeometry(Ogr_geometry);
- OGR_F_Destroy(Ogr_feature);
+ Ogr_feature);
+ OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
+ OGR_G_DestroyGeometry(Ogr_geometry);
+ OGR_F_Destroy(Ogr_feature);
- TODO: Volumes. Do not export kernels here, that's already done.
- We do need to worry about holes, though.
- NOTE: We can probably just merge this with faces export function.
- Except for GRASS, which output format would know the difference?
+ TODO: Volumes. Do not export kernels here, that's already done.
+ We do need to worry about holes, though.
+ NOTE: We can probably just merge this with faces export function.
+ Except for GRASS, which output format would know the difference?
if ((otype & GV_VOLUME)) {
- G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
- G_warning(_("Export of volumes not implemented yet. Skipping."));
+ G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
+ G_warning(_("Export of volumes not implemented yet. Skipping."));
OGR_DS_Destroy(Ogr_ds);
@@ -917,7 +938,7 @@
G_warning(_("%d features without attributes were written"), noatt);
if (nocatskip > 0)
G_warning(_("%d features found without category were skipped"),
- nocatskip);
+ nocatskip);
/* Enable this? May be confusing that for area type are not reported
* all boundaries/centroids.
@@ -932,7 +953,7 @@
int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
- int doatt, int nocat, OGRFeatureH Ogr_feature)
+ int doatt, int nocat, OGRFeatureH Ogr_feature)
int j, ogrfieldnum;
char buf[2000];
@@ -951,8 +972,8 @@
if (!doatt) {
ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, "cat");
OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
- /* doatt reset moved into have cat loop as the table needs to be
- open to know the OGR field ID. Hopefully this has no ill consequences */
+ /* doatt reset moved into have cat loop as the table needs to be
+ open to know the OGR field ID. Hopefully this has no ill consequences */
/* Read & set attributes */
@@ -974,13 +995,15 @@
/* G_warning ("No database record for cat = %d", cat); */
/* Set at least key column to category */
if (!nocat) {
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
+ ogrfieldnum =
+ OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
noatt++;
- } else {
- G_fatal_error (_("No database record for cat = %d and export of 'cat' disabled"),
- cat);
+ else {
+ G_fatal_error(_("No database record for cat = %d and export of 'cat' disabled"),
+ cat);
else {
Table = db_get_cursor_table(&cursor);
@@ -996,39 +1019,44 @@
G_debug(2, " colctype = %d", colctype);
- db_get_column_name(Column));
+ db_get_column_name
+ (Column));
/* Reset */
/* prevent writing NULL values */
if (!db_test_value_isnull(Value)) {
- switch (colctype) {
- case DB_C_TYPE_INT:
- OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum,
- db_get_value_int(Value));
- break;
- case DB_C_TYPE_DOUBLE:
- OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
- db_get_value_double(Value));
- break;
- case DB_C_TYPE_STRING:
- OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
- db_get_value_string(Value));
- break;
- case DB_C_TYPE_DATETIME:
- db_convert_column_value_to_string(Column,
- &dbstring);
- db_get_string(&dbstring));
- break;
+ switch (colctype) {
+ case DB_C_TYPE_INT:
+ OGR_F_SetFieldInteger(Ogr_feature,
+ ogrfieldnum,
+ db_get_value_int
+ (Value));
+ break;
+ case DB_C_TYPE_DOUBLE:
+ OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
+ db_get_value_double
+ (Value));
+ break;
+ case DB_C_TYPE_STRING:
+ OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
+ db_get_value_string
+ (Value));
+ break;
+ case DB_C_TYPE_DATETIME:
+ db_convert_column_value_to_string(Column,
+ &dbstring);
+ db_get_string
+ (&dbstring));
+ break;
- db_close_cursor (&cursor);
+ db_close_cursor(&cursor);
else { /* Use cat only */
