[GRASS-SVN] r44467 - grass/trunk/scripts/v.rast.stats
svn_grass at osgeo.org
Sun Nov 28 14:28:25 EST 2010
Author: martinl
Date: 2010-11-28 11:28:25 -0800 (Sun, 28 Nov 2010)
New Revision: 44467
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: description cosmetics
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2010-11-28 17:55:27 UTC (rev 44466)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2010-11-28 19:28:25 UTC (rev 44467)
@@ -16,20 +16,20 @@
-#%Module
-#% description: Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns.
-#% keywords: vector
-#% keywords: raster
-#% keywords: statistics
-#%End
+#%module
+#% description: Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns.
+#% keywords: vector
+#% keywords: raster
+#% keywords: statistics
+#%end
#%flag
-#% key: c
-#% description: Continue if upload column(s) already exist
-#%END
+#% key: c
+#% description: Continue if upload column(s) already exist
+#%end
#%flag
-#% key: e
-#% description: Calculate extended statistics
-#%END
+#% key: e
+#% description: Calculate extended statistics
+#%end
#%option
#% key: vector
#% type: string
@@ -38,13 +38,13 @@
#% label: Name of input vector polygon map
#% description: Data source for OGR access
#% required : yes
-#%End
+#%end
#%option
#% key: layer
#% type: integer
#% label: Layer number or name
#% description: A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access.
-#% gisprompt: old_layer,layer,layer
+#% gisprompt: old,layer,layer
#% answer: 1
#% required : no
#%end
@@ -55,9 +55,9 @@
#% gisprompt: old,cell,raster
#% description: Name of input raster map to calculate statistics from
#% required : yes
-#%END
+#%end
#%option
-#% key: colprefix
+#% key: column_prefix
#% type: string
#% description: Column prefix for new attribute columns
#% required : yes
