[GRASS-SVN] r44487 - grass/branches/releasebranch_6_4/imagery/i.pca
svn_grass at osgeo.org
Mon Nov 29 15:20:50 EST 2010
Author: martinl
Date: 2010-11-29 12:20:50 -0800 (Mon, 29 Nov 2010)
New Revision: 44487
grass/branches/releasebranch_6_4/imagery/i.pca/main.c
i.pca: output->output_prefix
(merge r44486 from devbr6)
Modified: grass/branches/releasebranch_6_4/imagery/i.pca/main.c
--- grass/branches/releasebranch_6_4/imagery/i.pca/main.c 2010-11-29 20:18:22 UTC (rev 44486)
+++ grass/branches/releasebranch_6_4/imagery/i.pca/main.c 2010-11-29 20:20:50 UTC (rev 44487)
@@ -61,17 +61,21 @@
module = G_define_module();
module->keywords = _("imagery, image transformation, PCA");
- module->description = _("Principal components analysis (pca) program "
+ module->description = _("Principal components analysis (PCA) "
"for image processing.");
/* Define options */
opt_in = G_define_standard_option(G_OPT_R_INPUTS);
opt_in->description = _("Name of two or more input raster maps");
- opt_out = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt_out = G_define_option();
opt_out->label = _("Base name for output raster maps");
opt_out->description =
_("A numerical suffix will be added for each component map");
+ opt_out->key = "output_prefix";
+ opt_out->type = TYPE_STRING;
+ opt_out->key_desc = "string";
+ opt_out->required = YES;
opt_scale = G_define_option();
opt_scale->key = "rescale";
@@ -79,9 +83,12 @@
opt_scale->key_desc = "min,max";
opt_scale->required = NO;
opt_scale->answer = "0,255";
+ opt_scale->label =
+ _("Rescaling range for output maps");
opt_scale->description =
- _("Rescaling range for output maps (for no rescaling use 0,0)");
+ _("For no rescaling use 0,0");
+ opt_scale->guisection = _("Rescale");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
