[GRASS-SVN] r44489 - in grass/branches/develbranch_6: gui/wxpython/gui_modules lib/python
Mon Nov 29 16:01:42 EST 2010
Author: martinl
Date: 2010-11-29 13:01:42 -0800 (Mon, 29 Nov 2010)
New Revision: 44489
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/develbranch_6/lib/python/core.py
pythonlib: define mlist()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2010-11-29 20:23:17 UTC (rev 44488)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2010-11-29 21:01:42 UTC (rev 44489)
@@ -828,11 +828,7 @@
         @param type layer type ('raster' or 'vector')
         @param mapset mapset name
-        try:
-            self.map_layers = grass.mlist_grouped(type=type, mapset=mapset)[mapset]
-        except KeyError:
-            self.map_layers = []
+        self.map_layers = grass.mlist(type = type, mapset = mapset)
         self.layers.Set(self.map_layers)
         # check all items by default
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2010-11-29 20:23:17 UTC (rev 44488)
+++ grass/branches/develbranch_6/lib/python/core.py	2010-11-29 21:01:42 UTC (rev 44489)
@@ -613,40 +613,6 @@
     return result
-def mlist_grouped(type, pattern = None):
-    """!List of elements grouped by mapsets.
-    Returns the output from running g.mlist, as a dictionary where the
-    keys are mapset names and the values are lists of maps in that
-    mapset. Example:
-    @code
-    >>> grass.mlist_grouped('rast', pattern='r*')['PERMANENT']
-    ['railroads', 'roads', 'rstrct.areas', 'rushmore']
-    @endcode
-    @param type element type (rast, vect, rast3d, region, ...)
-    @param pattern pattern string
-    @return directory of mapsets/elements
-    result = {}
-    mapset_element = None
-    for line in read_command("g.mlist", flags="m",
-                             type = type, pattern = pattern).splitlines():
-        try:
-            map, mapset_element = line.split('@')
-        except ValueError:
-            print >> sys.stderr, "Invalid element '%s'" % line
-            continue
-        if result.has_key(mapset_element):
-            result[mapset_element].append(map)
-        else:
-	    result[mapset_element] = [map, ]
-    return result
 def _concat(xs):
     result = []
     for x in xs:
@@ -688,6 +654,60 @@
     return ["%s@%s" % pair for pair in list_pairs(type)]
+# interface to g.mlist
+def mlist(type, pattern = None, mapset = None):
+    """!List of elements
+    @param type element type (rast, vect, rast3d, region, ...)
+    @param pattern pattern string
+    @param mapset mapset name (if not given use search path)
+    @return list of elements
+    result = list()
+    for line in read_command("g.mlist",
+                             type = type,
+                             pattern = pattern,
+                             mapset = mapset).splitlines():
+        result.append(line.strip())
+    return result
+def mlist_grouped(type, pattern = None):
+    """!List of elements grouped by mapsets.
+    Returns the output from running g.mlist, as a dictionary where the
+    keys are mapset names and the values are lists of maps in that
+    mapset. Example:
+    @code
+    >>> grass.mlist_grouped('rast', pattern='r*')['PERMANENT']
+    ['railroads', 'roads', 'rstrct.areas', 'rushmore']
+    @endcode
+    @return directory of mapsets/elements
+    result = dict()
+    mapset_element = None
+    for line in read_command("g.mlist", flags = "m",
+                             type = type, pattern = pattern).splitlines():
+        try:
+            map, mapset_element = line.split('@')
+        except ValueError:
+            warning(_("Invalid element '%s'") % line)
+            continue
+        if result.has_key(mapset_element):
+            result[mapset_element].append(map)
+        else:
+	    result[mapset_element] = [map, ]
+    return result
 # color parsing
 named_colors = {
