[GRASS-SVN] r43755 - grass-addons/grass7/raster/r.stream/r.stream.slope
Fri Oct 1 07:21:19 EDT 2010
Author: jarekj71
Date: 2010-10-01 11:21:19 +0000 (Fri, 01 Oct 2010)
New Revision: 43755
Added:
   grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.slope/main.c
   grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html
files
Added: grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile
--- grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile	2010-10-01 11:21:19 UTC (rev 43755)
@@ -0,0 +1,11 @@
+MODULE_TOPDIR = ../../..
+PGM = r.stream.slope
+LIBES = $(GISLIB) $(RASTERLIB) $(SEGMENTLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(SEGMENTDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.stream/r.stream.slope/main.c
--- grass-addons/grass7/raster/r.stream/r.stream.slope/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.stream/r.stream.slope/main.c	2010-10-01 11:21:19 UTC (rev 43755)
@@ -0,0 +1,385 @@
+ * MODULE:       r.stream.slope
+ * AUTHOR(S):    Jarek Jasiewicz jarekj amu.edu.pl
+ * PURPOSE:      Suplementary module for r.stream.distance for slope subsystem,
+ * 							 calculate local downsteam elevation change
+ * 							 and local downstream minimum and maximum curvature
+ * COPYRIGHT:    (C) 2002,2010 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 	  for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#define MAIN
+#define SQRT2 1.414214
+#define NR(x) r + nextr[(x)]
+#define NC(x) c + nextc[(x)]
+#define DIAG(x) (((x) + 4) > 8 ? ((x) - 4) : ((x) + 4))
+#define NOT_IN_REGION(x) (r+nextr[(x)] < 0 || r+nextr[(x)] > 2 || c+nextc[(x)] < 0 || c+nextc[(x)] > (ncols-1))
+int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+int nrows, ncols;
+CELL** dir_rows;
+DCELL** elev_rows;
+struct Cell_head window;
+DCELL calculate_difference(int r, int c);
+DCELL calculate_gradient(int r, int c);
+DCELL calculate_max_curvature(int r, int c);
+DCELL calculate_min_curvature(int r, int c);
+int main(int argc, char *argv[])
+	struct GModule *module;
+  struct Option *in_dir_opt, /* options */
+								*in_elev_opt,
+								*out_differnce_opt,
+								*out_gradient_opt,
+								*out_max_curv_opt,
+								*out_min_curv_opt;
+	struct Cell_head cellhd;
+	struct History history;
+	int r,c, d, i, cur_row;
+	int elev_map_type, elev_data_size;
+	int gradient;
+	int in_dir_fd, in_elev_fd;
+	int out_difference_fd, out_gradient_fd, out_max_curv_fd, out_min_curv_fd;
+	double cellsize;
+	char* mapset;
+	void* tmp_buffer;
+	DCELL* tmp_elev_buf;
+	CELL* tmp_dir_buf;
+	DCELL *out_difference_buf, *out_gradient_buf, *out_max_curv_buf, *out_min_curv_buf;
+	 G_gisinit(argv[0]);
+	module = G_define_module();
+	module->description =
+	_("Calculate local parameters for slope subsystem");
+	in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
+  in_dir_opt->key = "dir";
+  in_dir_opt->description = "Name of flow direction input map";
+  in_elev_opt = G_define_standard_option(G_OPT_R_INPUT);
+  in_elev_opt->key = "elevation";
+  in_elev_opt->description = "Name of elevation map";
+  out_differnce_opt = G_define_standard_option(G_OPT_R_OUTPUT);
+  out_differnce_opt->key = "difference";
+  out_differnce_opt->required = NO;
+  out_differnce_opt->description = "Output local downstream elevation difference";
+  out_gradient_opt = G_define_standard_option(G_OPT_R_OUTPUT);
+  out_gradient_opt->key = "gradient";
+  out_gradient_opt->required = NO;
+  out_gradient_opt->description = "Output local downstream gradient";
+  out_max_curv_opt = G_define_standard_option(G_OPT_R_OUTPUT);
+  out_max_curv_opt->key = "maxcurv";
+  out_max_curv_opt->required = NO;
+  out_max_curv_opt->description = "Output local downstream maximium cuvature";
+  out_min_curv_opt = G_define_standard_option(G_OPT_R_OUTPUT);
+  out_min_curv_opt->key = "mincurv";
+  out_min_curv_opt->required = NO;
+  out_min_curv_opt->description = "Output local downstream minimum cuvature";
+      if (G_parser(argc, argv))	/* parser */
+	exit(EXIT_FAILURE);
+	/* open map */
+	mapset = (char*)G_find_raster2(in_dir_opt->answer, "");
+	    if (mapset == NULL)
+	G_fatal_error(_("Raster map <%s> not found"), in_dir_opt->answer);
+		G_get_window(&window);
+  Rast_get_cellhd(in_dir_opt->answer, mapset, &cellhd);
+		if (window.ew_res != cellhd.ew_res ||
+			window.ns_res != cellhd.ns_res)
+	G_fatal_error(_("Region resolution and map %s resolution differs. \
+		Run g.region rast=%s to set proper region resolution"),
+		in_dir_opt->answer, in_dir_opt->answer);
+			if (Rast_map_type(in_dir_opt->answer,mapset) != CELL_TYPE)
+	G_fatal_error(_("<%s> is not of type CELL"),in_dir_opt->answer);
+	in_dir_fd  = Rast_open_old(in_dir_opt->answer, mapset);
+	mapset = (char*)G_find_raster2(in_elev_opt->answer, "");
+	G_fatal_error(_("Raster map <%s> not found"), in_elev_opt->answer);
+	elev_map_type=Rast_map_type(in_elev_opt->answer,mapset);
+	elev_data_size = Rast_cell_size(elev_map_type);
+	in_elev_fd  = Rast_open_old(in_elev_opt->answer, mapset);
+	nrows = Rast_window_rows();
+  ncols = Rast_window_cols();
+  G_begin_distance_calculations();
+		if(out_differnce_opt->answer) {
+  out_difference_fd=Rast_open_new(out_differnce_opt->answer,DCELL_TYPE);
+	out_difference_buf=Rast_allocate_d_buf();
+		if(out_gradient_opt->answer) {
+  out_gradient_fd=Rast_open_new(out_gradient_opt->answer,DCELL_TYPE);
+	out_gradient_buf=Rast_allocate_d_buf();
+		if(out_max_curv_opt->answer) {
+  out_max_curv_fd=Rast_open_new(out_max_curv_opt->answer,DCELL_TYPE);
+	out_max_curv_buf=Rast_allocate_d_buf();
+		if(out_min_curv_opt->answer) {
+  out_min_curv_fd=Rast_open_new(out_min_curv_opt->answer,DCELL_TYPE);
+	out_min_curv_buf=Rast_allocate_d_buf();
+	dir_rows=(CELL**)G_malloc(3*sizeof(CELL*));
+	elev_rows=(DCELL**)G_malloc(3*sizeof(DCELL*));
+	/* init shift buffer */
+	tmp_buffer=Rast_allocate_buf(elev_map_type);
+	for(i=0;i<3;++i) {
+		dir_rows[i]=Rast_allocate_c_buf();
+		elev_rows[i]=Rast_allocate_d_buf();
+		Rast_get_row(in_dir_fd,dir_rows[i],i,CELL_TYPE);
+		Rast_get_row(in_elev_fd,tmp_buffer,i,elev_map_type);
+				for(c=0;c<ncols;++c)
+		elev_rows[i][c]=Rast_get_d_value(tmp_buffer+c*elev_data_size,elev_map_type);
+for (r=0;r<nrows;++r) { /*main loop */
+	G_percent(r, nrows, 2);
+		if (r==0)
+	cur_row=0;
+		else if (r==(nrows-1))
+	cur_row=2;
+		else
+	cur_row=1;
+	for(c=0;c<ncols;++c) {
+		out_difference_buf[c]=calculate_difference(cur_row,c);
+		out_gradient_buf[c]=calculate_gradient(cur_row,c);
+		out_max_curv_buf[c]=calculate_max_curvature(cur_row,c);
+		out_min_curv_buf[c]=calculate_min_curvature(cur_row,c);
+	Rast_put_row(out_difference_fd, out_difference_buf, DCELL_TYPE);
+	Rast_put_row(out_gradient_fd, out_gradient_buf, DCELL_TYPE);
+	Rast_put_row(out_max_curv_fd, out_max_curv_buf, DCELL_TYPE);
+	Rast_put_row(out_min_curv_fd, out_min_curv_buf, DCELL_TYPE);
+	/* shift buffer */
+	if(r!=0 && r<nrows-2) {
+		tmp_elev_buf=elev_rows[0];
+		tmp_dir_buf=dir_rows[0];
+			for (i = 1; i < 3; ++i) {
+		dir_rows[i - 1] = dir_rows[i];
+		elev_rows[i - 1] = elev_rows[i];
+		dir_rows[2]=tmp_dir_buf;
+		elev_rows[2]=tmp_elev_buf;
+		Rast_get_row(in_dir_fd,dir_rows[2],r+2,CELL_TYPE);
+		Rast_get_row(in_elev_fd,tmp_buffer,r+2,elev_map_type);
+		elev_rows[2][c]=Rast_get_d_value(tmp_buffer+c*elev_data_size,elev_map_type);
+G_percent(r, nrows, 2);
+    G_free(out_difference_buf);
+    Rast_close(out_difference_fd);
+    Rast_short_history(out_differnce_opt->answer, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(out_differnce_opt->answer, &history);
+    G_free(out_gradient_buf);
+    Rast_close(out_gradient_fd);
+    Rast_short_history(out_gradient_opt->answer, "raster", &history);
+    Rast_write_history(out_gradient_opt->answer, &history);
+    G_free(out_max_curv_buf);
+    Rast_close(out_max_curv_fd);
+    Rast_short_history(out_max_curv_opt->answer, "raster", &history);
+    Rast_write_history(out_max_curv_opt->answer, &history);
+    G_free(out_min_curv_buf);
+    Rast_close(out_min_curv_fd);
+    Rast_short_history(out_min_curv_opt->answer, "raster", &history);
+    Rast_write_history(out_min_curv_opt->answer, &history);
+exit(EXIT_SUCCESS);
+	int d;
+	d=dir_rows[r][c];
+		if(NOT_IN_REGION(d))
+	return 0.;
+	return elev_rows[r][c] - elev_rows[NR(d)][NC(d)];
+	int d;
+	double easting, northing, next_easting, next_northing;
+	double distance;
+	d=dir_rows[r][c];
+	return 0.;
+	northing = window.north - (r + .5) * window.ns_res;
+	easting =  window.west +  (c + .5) * window.ew_res;
+	next_northing = window.north - (NR(d) +.5) * window.ns_res;
+	next_easting =  window.west +  (NC(d) +.5) * window.ew_res;
+	distance=G_distance(easting,northing,next_easting,next_northing);
+	return (elev_rows[r][c] - elev_rows[NR(d)][NC(d)])/distance;
+		int i, j=0, d;
+	double elev_max=-1000;
+	double diff_up,diff_down, diff_elev, first_derivative, second_derivative;
+	double distance_up, distance_down, distance;
+	d=dir_rows[r][c];
+	return 0.;
+		for(i=1; i<9; ++i) {
+				if(NOT_IN_REGION(i))
+			continue;
+				if(dir_rows[NR(i)][NC(i)]==DIAG(i) && elev_rows[NR(i)][NC(i)]>elev_max) {
+			elev_max=elev_rows[NR(i)][NC(i)];
+			j=i;
+	diff_up=elev_max-elev_rows[r][c];
+	diff_down=elev_rows[r][c] - elev_rows[NR(d)][NC(d)];
+	diff_elev = elev_max-elev_rows[NR(d)][NC(d)];
+		if(diff_elev<0)
+	diff_elev=0;
+	next_northing = window.north - (NR(j) +.5) * window.ns_res;
+	next_easting =  window.west +  (NC(j) +.5) * window.ew_res;
+	distance_up=G_distance(easting,northing,next_easting,next_northing);
+	distance_down=G_distance(easting,northing,next_easting,next_northing);
+	distance = distance_up+distance_down;
+	first_derivative=diff_elev/distance;
+	second_derivative=(diff_up-diff_down)/distance;
+	return second_derivative/pow((1+first_derivative*first_derivative),1.5);
+	int i, j=0, d;
+	int next_r, next_c;
+	double elev_min=9999;
+	double diff_up,diff_down,diff_elev,first_derivative, second_derivative;
+	double distance_up, distance_down,distance;
+	d=dir_rows[r][c];
+	return 0.;
+			continue;
+				if(dir_rows[NR(i)][NC(i)]==DIAG(i) && elev_rows[NR(i)][NC(i)]<elev_min) {
+			elev_min=elev_rows[NR(i)][NC(i)];
+			j=i;
+	diff_up=elev_min-elev_rows[r][c];
+	diff_elev = elev_min-elev_rows[NR(d)][NC(d)];
Added: grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html
--- grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html	2010-10-01 11:21:19 UTC (rev 43755)
@@ -0,0 +1,38 @@
+<h2>OPTIONS</h2>
+<DL>
+<DT><b>dirs</b></DT>
+<DD>Flow direction: name of input direction map produced by r.watershed or r.stream.extract. If r.stream.extract output map is used, it only has non-NULL values in places where streams occur. NULL (nodata) cells are ignored, zero and negative values are valid direction data if they vary from -8 to 8 (CCW from East in steps of 45 degrees). Direction map shall be of type CELL values. Region resolution and map resoultion must be the same.</DD>
+<DT><b>elevation</b></DT>
+<DD>Elevation: name of input elevation map or any other map we want to calculate . Map can be of type CELL, FCELL or DCELL. It is not restricted to resolution of region settings like <b>dirs</b>. </DD>
+</DL>
+<h2>OUTPUTS</h2>
+<DL>
+<DT><b>difference</b></DT>
+<DD>Downstream elevation difference: Difference between elevation of current cell and downstream cell. Shall always be posivtive. Negative values show, that current cell is pit or depression cell. Module is prepared to be used with elevation but can be also used to calculate local difference of any feature along watercourses in slope subsystem. In that way elevation map must be replaced by map we want to calculate. If we use differnt map than elevation, rest of parameters have no sense to calculate</DD>
+<DT><b>gradient</b></DT>
+<DD>Downstream gradinet: Downstream elevation difference divided by distance.</DD>
+<DT><b>maxcurv</b></DT>
+<DD>Maximum linear curvature along watercourse.Calculated along watercourse between highest upstream cell, current cell and downstream cell (there can be only one or no downstream cell but more than on upstream)</DD>
+<DD>Calculated along watercourse between lowest upstream cell, current cell and downstream cell (there can be only one or no downstream cell but more than on upstream)</DD>
+</DL>
+<h2>DESCRIPTION</h2>
+<P>
+Module r.stream.local is suplementary module for r.stream to calculate local parameters of slope subsystem.
+<P>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.watershed.html">r.watershed</a>,
+<a href="r.stream.extract.html">r.stream.extract</a>,
+<a href="r.stream.order.html">r.stream.order</a>,
+<a href="r.stream.basins.html">r.stream.basins</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+</em>
+<h2>AUTHOR</h2>
+Jarek Jasiewicz, Adam Mickiewicz University, Geoecology and Geoinformation Institute.
