[GRASS-SVN] r43767 - in grass-addons/grass7/raster/r.stream: . r.stream.basins r.stream.channel r.stream.distance r.stream.order r.stream.segment r.stream.slope r.stream.stats
Sun Oct 3 00:22:16 EDT 2010
Author: hamish
Date: 2010-10-03 04:22:16 +0000 (Sun, 03 Oct 2010)
New Revision: 43767
Added:
   grass-addons/grass7/raster/r.stream/Makefile
Removed:
   grass-addons/grass7/raster/r.stream/makefile
   grass-addons/grass7/raster/r.stream/r.stream.channel/svn-commit.tmp
   grass-addons/grass7/raster/r.stream/r.stream.basins/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.basins/basins_fill.c
   grass-addons/grass7/raster/r.stream/r.stream.basins/basins_inputs.c
   grass-addons/grass7/raster/r.stream/r.stream.basins/io.c
   grass-addons/grass7/raster/r.stream/r.stream.basins/io.h
   grass-addons/grass7/raster/r.stream/r.stream.basins/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.basins/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.basins/main.c
   grass-addons/grass7/raster/r.stream/r.stream.basins/r.stream.basins.html
   grass-addons/grass7/raster/r.stream/r.stream.channel/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.channel/io.c
   grass-addons/grass7/raster/r.stream/r.stream.channel/io.h
   grass-addons/grass7/raster/r.stream/r.stream.channel/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.channel/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.channel/main.c
   grass-addons/grass7/raster/r.stream/r.stream.channel/r.stream.channel.html
   grass-addons/grass7/raster/r.stream/r.stream.channel/stream_topology.c
   grass-addons/grass7/raster/r.stream/r.stream.channel/stream_write.c
   grass-addons/grass7/raster/r.stream/r.stream.distance/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.distance/distance_calc.c
   grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c
   grass-addons/grass7/raster/r.stream/r.stream.distance/io.c
   grass-addons/grass7/raster/r.stream/r.stream.distance/io.h
   grass-addons/grass7/raster/r.stream/r.stream.distance/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.distance/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.distance/main.c
   grass-addons/grass7/raster/r.stream/r.stream.distance/r.stream.distance.html
   grass-addons/grass7/raster/r.stream/r.stream.order/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.order/io.c
   grass-addons/grass7/raster/r.stream/r.stream.order/io.h
   grass-addons/grass7/raster/r.stream/r.stream.order/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.order/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.order/main.c
   grass-addons/grass7/raster/r.stream/r.stream.order/orders.png
   grass-addons/grass7/raster/r.stream/r.stream.order/r.stream.order.html
   grass-addons/grass7/raster/r.stream/r.stream.order/stream_init.c
   grass-addons/grass7/raster/r.stream/r.stream.order/stream_order.c
   grass-addons/grass7/raster/r.stream/r.stream.order/stream_raster_close.c
   grass-addons/grass7/raster/r.stream/r.stream.order/stream_topology.c
   grass-addons/grass7/raster/r.stream/r.stream.order/stream_vector.c
   grass-addons/grass7/raster/r.stream/r.stream.segment/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.segment/dirs.png
   grass-addons/grass7/raster/r.stream/r.stream.segment/io.c
   grass-addons/grass7/raster/r.stream/r.stream.segment/io.h
   grass-addons/grass7/raster/r.stream/r.stream.segment/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.segment/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.segment/main.c
   grass-addons/grass7/raster/r.stream/r.stream.segment/r.stream.segment.html
   grass-addons/grass7/raster/r.stream/r.stream.segment/sectors.png
   grass-addons/grass7/raster/r.stream/r.stream.segment/stream_segment.c
   grass-addons/grass7/raster/r.stream/r.stream.segment/stream_topology.c
   grass-addons/grass7/raster/r.stream/r.stream.segment/stream_vector.c
   grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.slope/main.c
   grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html
   grass-addons/grass7/raster/r.stream/r.stream.stats/Makefile
   grass-addons/grass7/raster/r.stream/r.stream.stats/io.c
   grass-addons/grass7/raster/r.stream/r.stream.stats/io.h
   grass-addons/grass7/raster/r.stream/r.stream.stats/local_proto.h
   grass-addons/grass7/raster/r.stream/r.stream.stats/local_vars.h
   grass-addons/grass7/raster/r.stream/r.stream.stats/main.c
   grass-addons/grass7/raster/r.stream/r.stream.stats/r.stream.stats.html
   grass-addons/grass7/raster/r.stream/r.stream.stats/stats_calculate.c
   grass-addons/grass7/raster/r.stream/r.stream.stats/stats_prepare.c
   grass-addons/grass7/raster/r.stream/r.stream.stats/stats_print.c
run addons/tools/module_svn_propset. still needs tools/grass_indent.sh to be run on it
Copied: grass-addons/grass7/raster/r.stream/Makefile (from rev 43766, grass-addons/grass7/raster/r.stream/makefile)
--- grass-addons/grass7/raster/r.stream/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.stream/Makefile	2010-10-03 04:22:16 UTC (rev 43767)
@@ -0,0 +1,11 @@
+MODULE_TOPDIR = ../..
+SUBDIRS = \
+	r.stream.order \
+	r.stream.baisns \
+	r.stream.distance \
+	r.stream.stats
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: parsubdirs
Property changes on: grass-addons/grass7/raster/r.stream/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Deleted: grass-addons/grass7/raster/r.stream/makefile
--- grass-addons/grass7/raster/r.stream/makefile	2010-10-03 02:28:48 UTC (rev 43766)
+++ grass-addons/grass7/raster/r.stream/makefile	2010-10-03 04:22:16 UTC (rev 43767)
@@ -1,11 +0,0 @@
-MODULE_TOPDIR = ../..
-SUBDIRS = \
-	r.stream.order \
-	r.stream.baisns \
-	r.stream.distance \
-	r.stream.stats
-include $(MODULE_TOPDIR)/include/Make/Dir.make
-default: parsubdirs
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/basins_fill.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/basins_inputs.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.basins/r.stream.basins.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/r.stream.channel.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/stream_topology.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.channel/stream_write.c
   + text/x-csrc
   + native
Deleted: grass-addons/grass7/raster/r.stream/r.stream.channel/svn-commit.tmp
--- grass-addons/grass7/raster/r.stream/r.stream.channel/svn-commit.tmp	2010-10-03 02:28:48 UTC (rev 43766)
+++ grass-addons/grass7/raster/r.stream/r.stream.channel/svn-commit.tmp	2010-10-03 04:22:16 UTC (rev 43767)
@@ -1,4 +0,0 @@
-files
---Ta linia i następne zostaną zignorowane--
-A    r.stream
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/distance_calc.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.distance/r.stream.distance.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/orders.png
Modified: svn:mime-type
   - application/octet-stream
   + image/png
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/r.stream.order.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/stream_init.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/stream_order.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/stream_raster_close.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/stream_topology.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.order/stream_vector.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/dirs.png
   + image/png
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/r.stream.segment.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/sectors.png
   + image/png
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/stream_segment.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/stream_topology.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.segment/stream_vector.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.slope/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.slope/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.slope/r.stream.slope.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/io.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/io.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/local_proto.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/local_vars.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/main.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/r.stream.stats.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/stats_calculate.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/stats_prepare.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass7/raster/r.stream/r.stream.stats/stats_print.c
   + text/x-csrc
   + native
