[GRASS-SVN] r43769 - in grass-addons/HydroFOSS: . r.evapo.PM
r.interception
svn_grass at osgeo.org
Sun Oct 3 00:39:02 EDT 2010
Author: hamish
Date: 2010-10-03 04:39:02 +0000 (Sun, 03 Oct 2010)
New Revision: 43769
grass-addons/HydroFOSS/Makefile
grass-addons/HydroFOSS/README.txt
grass-addons/HydroFOSS/r.evapo.PM/Makefile
grass-addons/HydroFOSS/r.evapo.PM/description.html
grass-addons/HydroFOSS/r.evapo.PM/functions.c
grass-addons/HydroFOSS/r.evapo.PM/local_proto.h
grass-addons/HydroFOSS/r.evapo.PM/main.c
grass-addons/HydroFOSS/r.interception/Makefile
grass-addons/HydroFOSS/r.interception/description.html
grass-addons/HydroFOSS/r.interception/main.c
svn props, consistent newlines
Property changes on: grass-addons/HydroFOSS/Makefile
___________________________________________________________________
Deleted: svn:executable
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Property changes on: grass-addons/HydroFOSS/README.txt
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass-addons/HydroFOSS/r.evapo.PM/Makefile
+ text/x-makefile
+ native
Modified: grass-addons/HydroFOSS/r.evapo.PM/description.html
--- grass-addons/HydroFOSS/r.evapo.PM/description.html 2010-10-03 04:31:04 UTC (rev 43768)
+++ grass-addons/HydroFOSS/r.evapo.PM/description.html 2010-10-03 04:39:02 UTC (rev 43769)
@@ -1,168 +1,167 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>r.evapo.PM</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass.smlogo.gif" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2> <B><I>r.evapo.PM </I></B>- computation of <i>potential evapotranspiration</i> [mm/h] for hourly time step.
-<P><I>(GRASS Raster Program)</I>
-<H2>SYNOPSIS</H2>
-<B>r.evapo.PM</B>
-<BR>
-<B>r.evapo.PM</B> help</br>
-<BR>
-<B>r.evapo.PM</b> <b>[ -qzn ]</b>
-<b>DEM</b>=name
-<b>T</b>=name
-<b>RH</b>=name
-<b>WS</b>=name
-<b>NSR</b>=name
-<b>Vh</b>=name
-<b>ETP</b>=name
-<H2>DESCRIPTION</H2>
-<p><EM>r.evapo.PM</EM> given the vegetation height (hc), humidity (RU),
-wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
-and net radiation (NSR) raster input maps,
-calculates the potential evapotranspiration map (EPo).
-<p>Optionally the user can activate a flag (-z)
-that allows him setting to zero all of the negative evapotranspiration cells;
-in fact these negative values motivated by the condensation of the air water
-vapour content, are sometime undesired because they can produce computational
-problems. The usage of the flag -n detect that the module is run in night hours
-and the appropriate soil heat flux is calculated.
-<p>The algorithm implements well known approaches: the hourly Penman-Monteith method as presented in Allen et al. (1998) for land surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
-<p>Land and water surfaces are idenfyied by Vh:<br>
-- where Vh>0 vegetation is present and evapotranspiration is calculated;<br>
-- where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
-- where Vh<0 water surface is present and evaporation is calculated;<br>
-<p>For more details on the algorithms see [1,2,3].
-<H2>OPTIONS</H2>
-The program will run non-interactively if the user specifies program
-arguments and flag settings on the command line using the following
-form:
-<P><B>r.evapo.PM</b> <b>[ -qzd ]</b>
-<b>DEM</b>=name
-<b>T</b>=name
-<b>RH</b>=name
-<b>WS</b>=name
-<b>NSR</b>=name
-<b>Vh</b>=name
-<b>ETP</b>=name
-<P>Alternatively, the user can simply type <EM>r.evapo.PM</EM> on the
-command line and the program will ask for parameter values and flag
-settings interactively, using the standard GRASS parser interface.
-<H3>Flags:</H3>
-<dl>
- <dt><B>-q</B>
- <dd>Run quietly (do not display status messages). By default
- <EM>r.evapo.PM</EM> is run verbosely.
- <dt><B>-z</B>
- <dd>Set negative calculated evapotranspiration values to zero.
- <dt><B>-n</B>
- <dd>Calculate soil heat flux for night time. By default
- <EM>r.evapo.PM</EM> calculate it for day time.
-</dl>
-<H3>Parameters:</H3>
-<dl>
- <dt><B>DEM</B>=<I>name</I>
- <dd>Input elevation raster [m a.s.l.]. Required.</dd>
- <dt><b>T</b>=<I>name</I>
- <dd>Input temperature raster [°C]. Required.</dd>
- <dt><b>RH</b> =<I>name</I>
- <dd>Input relative humidity raster [%]. Required.</dd>
- <dt><b>WS</b> =<I>name</I>
- <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
- <dt><b>NSR</b> =<I>name</I>
- <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
- <dt><b>Vh</b> =<I>name</I>
- <dd>Input vegetation heigth raster [m]. Required.</dd>
- <dt><b>ETP</b> =<I>name</I>
- <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
-</dl>
-<H2>NOTES</H2>
-<p>Net solar radiation map in MJ/(m2*h) can be computed from the combination of the r.sun ,
-run in mode 1, and the r.mapcalc commands.
-<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
-multiplied by the Wh->Mj conversion factor (0.0036) and optionally by a
-clear sky factor [0-1] allows the generation of a map to be used as
-an NSR input for the <EM>r.evapo.PM</EM> command.
-<dt>example:
-<br><dd>r.sun -s elevin=dem aspin=aspect slopein=slope lin=2 albedo=alb_Mar incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
-<br><dd>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
-<H2>SEE ALSO</H2>
-<ul>
- <li>The <a href="http://istgis.ist.supsi.ch:8001/geomatica/">HydroFOSS</a>
-project at IST-SUPSI (Institute of Earth Sciences - University school of applied science for the Southern Switzerland)
- <li><a href=r.sun.html>r.sun</a>,
- <a href=r.mapcalc.html>r.mapcal</a>
-</ul>
-<H2>AUTHORS</H2>
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>r.evapo.PM</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass.smlogo.gif" alt="GRASS logo"><hr align=center size=6 noshade>
+<H2>NAME</H2> <B><I>r.evapo.PM </I></B>- computation of <i>potential evapotranspiration</i> [mm/h] for hourly time step.
+<P><I>(GRASS Raster Program)</I>
+<H2>SYNOPSIS</H2>
+<B>r.evapo.PM</B>
+<BR>
+<B>r.evapo.PM</B> help</br>
+<BR>
+<B>r.evapo.PM</b> <b>[ -qzn ]</b>
+<b>DEM</b>=name
+<b>T</b>=name
+<b>RH</b>=name
+<b>WS</b>=name
+<b>NSR</b>=name
+<b>Vh</b>=name
+<b>ETP</b>=name
+<H2>DESCRIPTION</H2>
+<p><EM>r.evapo.PM</EM> given the vegetation height (hc), humidity (RU),
+wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
+and net radiation (NSR) raster input maps,
+calculates the potential evapotranspiration map (EPo).
+<p>Optionally the user can activate a flag (-z)
+that allows him setting to zero all of the negative evapotranspiration cells;
+in fact these negative values motivated by the condensation of the air water
+vapour content, are sometime undesired because they can produce computational
+problems. The usage of the flag -n detect that the module is run in night hours
+and the appropriate soil heat flux is calculated.
+<p>The algorithm implements well known approaches: the hourly Penman-Monteith method as presented in Allen et al. (1998) for land surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
+<p>Land and water surfaces are idenfyied by Vh:<br>
+- where Vh>0 vegetation is present and evapotranspiration is calculated;<br>
+- where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
+- where Vh<0 water surface is present and evaporation is calculated;<br>
+<p>For more details on the algorithms see [1,2,3].
+<H2>OPTIONS</H2>
+The program will run non-interactively if the user specifies program
+arguments and flag settings on the command line using the following
+form:
+<P><B>r.evapo.PM</b> <b>[ -qzd ]</b>
+<b>DEM</b>=name
+<b>T</b>=name
+<b>RH</b>=name
+<b>WS</b>=name
+<b>NSR</b>=name
+<b>Vh</b>=name
+<b>ETP</b>=name
+<P>Alternatively, the user can simply type <EM>r.evapo.PM</EM> on the
+command line and the program will ask for parameter values and flag
+settings interactively, using the standard GRASS parser interface.
+<H3>Flags:</H3>
+<dl>
+ <dt><B>-q</B>
+ <dd>Run quietly (do not display status messages). By default
+ <EM>r.evapo.PM</EM> is run verbosely.
+ <dt><B>-z</B>
+ <dd>Set negative calculated evapotranspiration values to zero.
+ <dt><B>-n</B>
+ <dd>Calculate soil heat flux for night time. By default
+ <EM>r.evapo.PM</EM> calculate it for day time.
+</dl>
+<H3>Parameters:</H3>
+<dl>
+ <dt><B>DEM</B>=<I>name</I>
+ <dd>Input elevation raster [m a.s.l.]. Required.</dd>
+ <dt><b>T</b>=<I>name</I>
+ <dd>Input temperature raster [°C]. Required.</dd>
+ <dt><b>RH</b> =<I>name</I>
+ <dd>Input relative humidity raster [%]. Required.</dd>
+ <dt><b>WS</b> =<I>name</I>
+ <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
+ <dt><b>NSR</b> =<I>name</I>
+ <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
+ <dt><b>Vh</b> =<I>name</I>
+ <dd>Input vegetation heigth raster [m]. Required.</dd>
+ <dt><b>ETP</b> =<I>name</I>
+ <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
+</dl>
+<H2>NOTES</H2>
+<p>Net solar radiation map in MJ/(m2*h) can be computed from the combination of the r.sun ,
+run in mode 1, and the r.mapcalc commands.
+<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
+multiplied by the Wh->Mj conversion factor (0.0036) and optionally by a
+clear sky factor [0-1] allows the generation of a map to be used as
+an NSR input for the <EM>r.evapo.PM</EM> command.
+<dt>example:
+<br><dd>r.sun -s elevin=dem aspin=aspect slopein=slope lin=2 albedo=alb_Mar incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
+<br><dd>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
+<H2>SEE ALSO</H2>
+<ul>
+ <li>The <a href="http://istgis.ist.supsi.ch:8001/geomatica/">HydroFOSS</a>
+project at IST-SUPSI (Institute of Earth Sciences - University school of applied science for the Southern Switzerland)
+ <li><a href=r.sun.html>r.sun</a>,
+ <a href=r.mapcalc.html>r.mapcal</a>
+</ul>
+<H2>AUTHORS</H2>
<p>Original version of program: The <a href="http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1">HydroFOSS</a> project, 2006, IST-SUPSI. (http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1)
- <i>
- <br>Massimiliano Cannata, Scuola Universitaria Professionale della Svizzera Italiana - Istituto Scienze della Terra
+ <i>
+ <br>Massimiliano Cannata, Scuola Universitaria Professionale della Svizzera Italiana - Istituto Scienze della Terra
<br>Maria A. Brovelli, Politecnico di Milano - Polo regionale di Como
- </i>
- <p>Contact: <a href="mailto:massimiliano.cannata at supsi.ch"> Massimiliano Cannata</a>
-<H2>REFERENCES</H2>
- <p>[1] Cannata M., 2006. <A HREF="http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1">
+ </i>
+ <p>Contact: <a href="mailto:massimiliano.cannata at supsi.ch"> Massimiliano Cannata</a>
+<H2>REFERENCES</H2>
+ <p>[1] Cannata M., 2006. <A HREF="http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1">
GIS embedded approach for Free & Open Source Hydrological Modelling</A>. PhD thesis, Department of Geodesy and Geomatics, Polytechnic of Milan, Italy.
- <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
- Crop Evapotranspiration: Guidelines for computing crop water requirements.
- Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
- United Nations, Rome, pp. 300
- <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
- bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
-<p><i>Last changed: $Date: 2007/07/29 19:30:00 $</i>
-</body>
-</html>
+ <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
+ Crop Evapotranspiration: Guidelines for computing crop water requirements.
+ Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
+ United Nations, Rome, pp. 300
+ <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
+ bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
+<p><i>Last changed: $Date$</i>
+</body>
+</html>
Property changes on: grass-addons/HydroFOSS/r.evapo.PM/description.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass-addons/HydroFOSS/r.evapo.PM/functions.c
+ text/x-csrc
+ native
Property changes on: grass-addons/HydroFOSS/r.evapo.PM/local_proto.h
+ text/x-chdr
+ native
Modified: grass-addons/HydroFOSS/r.evapo.PM/main.c
--- grass-addons/HydroFOSS/r.evapo.PM/main.c 2010-10-03 04:31:04 UTC (rev 43768)
+++ grass-addons/HydroFOSS/r.evapo.PM/main.c 2010-10-03 04:39:02 UTC (rev 43769)
@@ -30,7 +30,7 @@
DCELL d_EPo;
int d_night;
struct History history;
struct GModule *module;
struct Option *input_DEM, *input_T, *input_RH, *input_u2, *input_Rn, *input_hc, *output;
@@ -41,7 +41,7 @@
module = G_define_module();
module->description = _("Potontial Evapotranspiration Calculation with hourly Penman-Monteith");
/* Define different options */
input_DEM = G_define_option();
input_DEM->key = "DEM";
@@ -257,9 +257,9 @@
G_close_cell (infd_hc);
G_close_cell (outfd);
- /* add command line incantation to history file */
- G_short_history(output, "raster", &history);
- G_command_history(&history);
+ /* add command line incantation to history file */
+ G_short_history(output, "raster", &history);
+ G_command_history(&history);
G_write_history(output, &history);
exit(EXIT_SUCCESS);
Property changes on: grass-addons/HydroFOSS/r.evapo.PM/main.c
+ text/x-csrc
+ native
Property changes on: grass-addons/HydroFOSS/r.interception/Makefile
+ text/x-makefile
+ native
Modified: grass-addons/HydroFOSS/r.interception/description.html
--- grass-addons/HydroFOSS/r.interception/description.html 2010-10-03 04:31:04 UTC (rev 43768)
+++ grass-addons/HydroFOSS/r.interception/description.html 2010-10-03 04:39:02 UTC (rev 43769)
@@ -1,152 +1,152 @@
-<html>
-<head>
-<title>h.interception</title>
-</head>
-<H2>NAME</H2> <B><I>h.interception </I></B>
-- computation of the water loss, drainage, and storage due
-to <i>canopy rainfall interception</i>.
-<H2>SYNOPSIS</H2>
-<B>h.interception</B><BR>
-<B>h.interception</B> help<BR>
-<B>h.interception</b>
-<b>LAI</b>=name
-<b>ETPls</b>=name
-<b>Co</b>=name
-<b>R</b>=name
-[<b>Ts</b>=name]
-<b>Vc</b>=name
-<b>IL</b>=name
-<b>D</b>=name
-<b>Ct</b>=name
-<p><EM>h.interception</EM>
-given the LAI [-], the ETPls [mm/h], the leaf storage level at
-the previous step Co [mm], the rain R [mm/h], the timestep Ts [h],
-and the vegetation density Vc [%] the command estimates the interception
-losses IL [mm], the drainage D [mm] and the canopy storage level at
-the end of the step Ct [mm].
-<p>This algorithm is a modification of the Rutter model
-in order to take into account the temporal variability of the rainfall.<br>
-<p>For more details on the algorithms see the references.
-<H2>OPTIONS</H2>
-arguments settings on the command line using the following
-form:<br>
-<b>LAI</b>=name
-<b>ETPls</b>=name
-<b>Co</b>=name
-<b>R</b>=name
-[<b>Ts</b>=name]
-<b>Vc</b>=name
-<b>IL</b>=name
-<b>D</b>=name
-<b>Ct</b>=name
-<P>Alternatively, the user can simply type <EM>h.interception</EM> on the
-<dl>
- <dt><B>LAI</B>=<I>name</I>
- <dd>Input: Leaf Area Index raster map [-]. Required.</dd>
- <dt><b>ETPls</b>=<I>name</I>
- <dd>Input: Potential Evapotranspiration for a liquid surface raster map [mm/h]. Required.</dd>
- <dt><b>Co</b> =<I>name</I>
- <dd>Input: initial canopy storage level raster map [mm]. Required.</dd>
- <dt><b>R</b> =<I>name</I>
- <dd>Input: rainfall intensity raster map [mm/h]. Required.</dd>
- <dt><b>Ts</b> =<I>name</I>
- <dd>Input: camputational time step value [h]. Optional (default 1).</dd>
- <dt><b>Vc</b> =<I>name</I>
- <dd>Input: vegetatin cover raster map [%]. Required.</dd>
- <dt><b>IL</b> =<I>name</I>
- <dd>Output: estimated interception losses raster map [mm]. Required.</dd>
- <dt><b>D</b> =<I>name</I>
- <dd>Output: estimated drained water raster map [mm]. Required.</dd>
- <dt><b>Ct</b> =<I>name</I>
- <dd>Output: estimated canopy storage level raster map [mm] at the end of the timestep. Required.</dd>
-</dl>
-<H2>NOTES</H2>
-<p>The estimated D raster map (water drained from the vegetation to the groud)
-is calculated for each cell on the basis of the vegetation cover fraction.
-In order to evaluate the total water reaching the groud, and therefore
-available for runoff and infiltration, this quantity should be sommed to
-the rain directly falling to the ground, and eventually to the water
-caming from the snowmelt.
-<p>The sum of these three components outputted can be calculated by means
- of teh r.mapcalc command.
-<dt>example:
-<br><dd>r.mapcalc 'NETrain = D + (1-Vc)*R + snowmelt';
-<H2>SEE ALSO</H2>
-<ul>
- <li><a href=r.evapo.PM.html>r.evapo.PM</a>,
- <a href=r.mapcalc.html>r.mapcal</a>,
- <a href=r.snow.html>r.snow</a>.
-</ul>
-<H2>AUTHORS</H2>
+<html>
+<head>
+<title>h.interception</title>
+</head>
+<H2>NAME</H2> <B><I>h.interception </I></B>
+- computation of the water loss, drainage, and storage due
+to <i>canopy rainfall interception</i>.
+<H2>SYNOPSIS</H2>
+<B>h.interception</B><BR>
+<B>h.interception</B> help<BR>
+<B>h.interception</b>
+<b>LAI</b>=name
+<b>ETPls</b>=name
+<b>Co</b>=name
+<b>R</b>=name
+[<b>Ts</b>=name]
+<b>Vc</b>=name
+<b>IL</b>=name
+<b>D</b>=name
+<b>Ct</b>=name
+<p><EM>h.interception</EM>
+given the LAI [-], the ETPls [mm/h], the leaf storage level at
+the previous step Co [mm], the rain R [mm/h], the timestep Ts [h],
+and the vegetation density Vc [%] the command estimates the interception
+losses IL [mm], the drainage D [mm] and the canopy storage level at
+the end of the step Ct [mm].
+<p>This algorithm is a modification of the Rutter model
+in order to take into account the temporal variability of the rainfall.<br>
+<p>For more details on the algorithms see the references.
+<H2>OPTIONS</H2>
+arguments settings on the command line using the following
+form:<br>
+<b>LAI</b>=name
+<b>ETPls</b>=name
+<b>Co</b>=name
+<b>R</b>=name
+[<b>Ts</b>=name]
+<b>Vc</b>=name
+<b>IL</b>=name
+<b>D</b>=name
+<b>Ct</b>=name
+<P>Alternatively, the user can simply type <EM>h.interception</EM> on the
+<dl>
+ <dt><B>LAI</B>=<I>name</I>
+ <dd>Input: Leaf Area Index raster map [-]. Required.</dd>
+ <dt><b>ETPls</b>=<I>name</I>
+ <dd>Input: Potential Evapotranspiration for a liquid surface raster map [mm/h]. Required.</dd>
+ <dt><b>Co</b> =<I>name</I>
+ <dd>Input: initial canopy storage level raster map [mm]. Required.</dd>
+ <dt><b>R</b> =<I>name</I>
+ <dd>Input: rainfall intensity raster map [mm/h]. Required.</dd>
+ <dt><b>Ts</b> =<I>name</I>
+ <dd>Input: camputational time step value [h]. Optional (default 1).</dd>
+ <dt><b>Vc</b> =<I>name</I>
+ <dd>Input: vegetatin cover raster map [%]. Required.</dd>
+ <dt><b>IL</b> =<I>name</I>
+ <dd>Output: estimated interception losses raster map [mm]. Required.</dd>
+ <dt><b>D</b> =<I>name</I>
+ <dd>Output: estimated drained water raster map [mm]. Required.</dd>
+ <dt><b>Ct</b> =<I>name</I>
+ <dd>Output: estimated canopy storage level raster map [mm] at the end of the timestep. Required.</dd>
+</dl>
+<H2>NOTES</H2>
+<p>The estimated D raster map (water drained from the vegetation to the groud)
+is calculated for each cell on the basis of the vegetation cover fraction.
+In order to evaluate the total water reaching the groud, and therefore
+available for runoff and infiltration, this quantity should be sommed to
+the rain directly falling to the ground, and eventually to the water
+caming from the snowmelt.
+<p>The sum of these three components outputted can be calculated by means
+ of teh r.mapcalc command.
+<dt>example:
+<br><dd>r.mapcalc 'NETrain = D + (1-Vc)*R + snowmelt';
+<H2>SEE ALSO</H2>
+<ul>
+ <li><a href=r.evapo.PM.html>r.evapo.PM</a>,
+ <a href=r.mapcalc.html>r.mapcal</a>,
+ <a href=r.snow.html>r.snow</a>.
+</ul>
+<H2>AUTHORS</H2>
- <i>
+ <i>
- </i>
- GIS embedded approach for Free & Open Source Hydrological Modelling</A>. PhD thesis, Department of Geodesy and Geomatics, Polytechnic of Milan, Italy.
- <p>Zeng, N., JW Shuttleworth, and J. Gash, 2000.
- Influence of temporal variability of rainfall on interception loss.
- J. of Hydrology, 228 3-4, 228-241.
-</body>
-</html>
+ </i>
+ GIS embedded approach for Free & Open Source Hydrological Modelling</A>. PhD thesis, Department of Geodesy and Geomatics, Polytechnic of Milan, Italy.
+ <p>Zeng, N., JW Shuttleworth, and J. Gash, 2000.
+ Influence of temporal variability of rainfall on interception loss.
+ J. of Hydrology, 228 3-4, 228-241.
+</body>
+</html>
Property changes on: grass-addons/HydroFOSS/r.interception/description.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass-addons/HydroFOSS/r.interception/main.c
+ text/x-csrc
+ native
