[GRASS-SVN] r43792 - grass/trunk/gui/wxpython/gui_modules
Tue Oct 5 08:02:41 EDT 2010
Author: martinl
Date: 2010-10-05 12:02:40 +0000 (Tue, 05 Oct 2010)
New Revision: 43792
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI:redraw display when r.colors is launched
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-10-05 11:26:21 UTC (rev 43791)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-10-05 12:02:40 UTC (rev 43792)
@@ -991,7 +991,7 @@
         if params.has_key(name):
             item.SetParams(paramsOrig)
-    def OnDone(self, returncode):
+    def OnDone(self, cmd, returncode):
         """!Computation finished"""
         self.SetStatusText('', 0)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-10-05 11:26:21 UTC (rev 43791)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-10-05 12:02:40 UTC (rev 43792)
@@ -128,7 +128,8 @@
                     self.requestCmdColor = callable(*argsColor, **kwds)
                     self.resultQ.put((requestId, self.requestCmdColor.run()))
-            event = wxCmdDone(aborted = aborted,
+            event = wxCmdDone(cmd = args[0],
+                              aborted = aborted,
                               returncode = returncode,
                               time = requestTime,
                               pid = requestId,
@@ -697,7 +698,7 @@
             self.btn_abort.Enable(False)
         if event.onDone:
-            event.onDone(returncode = event.returncode)
+            event.onDone(cmd = event.cmd, returncode = event.returncode)
         self.console_progressbar.SetValue(0) # reset progress bar on '0%'
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-10-05 11:26:21 UTC (rev 43791)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-10-05 12:02:40 UTC (rev 43792)
@@ -1337,9 +1337,9 @@
             if vectstr:
                 gcmd.RunCommand(vcmd)
-    def _QueryMapDone(self, returncode):
+    def _QueryMapDone(self, cmd, returncode):
         """!Restore settings after querying (restore GRASS_REGION)
         @param returncode command return code
         if hasattr(self, "tmpreg"):
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-10-05 11:26:21 UTC (rev 43791)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-10-05 12:02:40 UTC (rev 43792)
@@ -876,6 +876,21 @@
         event.Skip()
+        """!This function is launched from OnRun() when command is
+        finished
+        @param returncode command's return code (0 for success)
+        if self.parent.GetName() != 'LayerTree' or \
+                returncode != 0:
+            return
+        if cmd[0] in ('r.colors'):
+            display = self.parent.GetMapDisplay()
+            if display:
+                display.GetWindow().UpdateMap(render = True)
     def OnOK(self, event):
         """!OK button pressed"""
         cmd = self.OnApply(event)
@@ -916,7 +931,7 @@
             try:
                 if self.task.path:
                     cmd[0] = self.task.path # full path
-                self.goutput.RunCmd(cmd)
+                self.goutput.RunCmd(cmd, onDone = self.OnDone)
             except AttributeError, e:
                 print >> sys.stderr, "%s: Propably not running in wxgui.py session?" % (e)
                 print >> sys.stderr, "parent window is: %s" % (str(self.parent))
