[GRASS-SVN] r43812 - grass/trunk/raster/r.univar
svn_grass at osgeo.org
Thu Oct 7 06:28:04 EDT 2010
Author: mmetz
Date: 2010-10-07 10:28:04 +0000 (Thu, 07 Oct 2010)
New Revision: 43812
grass/trunk/raster/r.univar/globals.h
grass/trunk/raster/r.univar/r.univar.html
grass/trunk/raster/r.univar/r.univar_main.c
grass/trunk/raster/r.univar/r3.univar.html
grass/trunk/raster/r.univar/r3.univar_main.c
grass/trunk/raster/r.univar/stats.c
add option for zonal statistics
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/globals.h 2010-10-07 10:28:04 UTC (rev 43812)
@@ -1,10 +1,11 @@
* Calculates univariate statistics from the non-null cells
- * Copyright (C) 2004-2007 by the GRASS Development Team
+ * Copyright (C) 2004-2010 by the GRASS Development Team
* Author(s): Soeren Gebbert
* Based on r.univar from Hamish Bowman, University of Otago, New Zealand
* and Martin Landa
+ * zonal loop by Markus Metz
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -39,23 +40,35 @@
FCELL *fcell_array;
CELL *cell_array;
int map_type;
+ void *nextp;
+ int n_alloc;
+ int first;
} univar_stat;
+typedef struct
+ CELL min, max, n_zones;
+ struct Categories cats;
+ char *sep;
+} zone_type;
/* command line options are the same for raster and raster3d maps */
typedef struct
- struct Option *inputfile, *percentile;
- struct Flag *shell_style, *extended;
+ struct Option *inputfile, *zonefile, *percentile, *output_file, *separator;
+ struct Flag *shell_style, *extended, *table;
} param_type;
extern param_type param;
+extern zone_type zone_info;
/* fn prototypes */
void heapsort_double(double *data, int n);
void heapsort_float(float *data, int n);
void heapsort_int(int *data, int n);
int print_stats(univar_stat * stats);
-univar_stat *create_univar_stat_struct(int map_type, int size, int n_perc);
+int print_stats_table(univar_stat * stats);
+univar_stat *create_univar_stat_struct(int map_type, int n_perc);
void free_univar_stat_struct(univar_stat * stats);
#endif
Modified: grass/trunk/raster/r.univar/r.univar.html
--- grass/trunk/raster/r.univar/r.univar.html 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/r.univar.html 2010-10-07 10:28:04 UTC (rev 43812)
@@ -3,11 +3,16 @@
<em>r.univar</em> calculates the univariate statistics of a raster map.
This includes the number of cells counted, minimum and maximum cell values,
range, arithmetic mean, population variance, standard deviation, and
-coefficient of variation.
+coefficient of variation. Statistics are calculated separately for every
+category/zone found in the <b>zones</b> input map if given.
If the <b>-e</b> extended statistics flag is given the 1st quartile, median,
3rd quartile, and given <b>percentile</b> are calculated.
If the <b>-g</b> flag is given the results are presented in a format suitable
for use in a shell script.
+If the <b>-t</b> flag is given the results are presented in tabular format
+with "|" as field separator. The table can immediately be converted to a
+vector attribute table which can then be linked to a vector, e.g. the vector
+that was rasterized to create the <b>zones</b> input raster.
<h2>NOTES</h2>
@@ -20,22 +25,91 @@
region is too large the module should exit gracefully with a memory allocation
error. Basic statistics can be calculated using any size input region.
<p>
-The <em>r.quantile</em> module will be significantly more efficient for
-calculating percentiles with large maps.
+Without a <b>zones</b> input raster, the <em>r.quantile</em> module will
+be significantly more efficient for calculating percentiles with large maps.
+<h2>EXAMPLE</h2>
+Calculate the raster statistics for zones within a vector map coverage
+and upload the results for mean, min and max back to the vector map.
+<div class="code"><pre>
+#### set the raster region to match the map
+g.region vect=fields res=10 -ap
+#### create rasterized version of vector map
+v.to.rast in=fields out=fields.10m use=cat type=area labelcolumn=label
+r.colors fields.10m color=random
+#### perform analysis
+r.univar -t map=elevation.10m zones=fields.10m | \
+ cut -f1,5,6,8 -d'|' > fields_stats.txt
+#### populate vector DB with stats
+# create working copy of vector map
+g.copy vect=fields,fields_stats
+# create new attribute columns to hold output
+v.db.addcol map=fields_stats \
+ columns='mean_elev DOUBLE PRECISION, min_elev DOUBLE PRECISION, max_elev DOUBLE PRECISION'
+# create SQL command file, and execute it
+sed -e '1d' fields_stats.txt | awk -F'|' \
+ '{print "UPDATE fields_stats SET min_elev = "$2", max_elev = "$3", \
+ mean_elev = "$4" WHERE cat = "$1";"}' \
+ > fields_stats_sqlcmd.txt
+db.execute input=fields_stats_sqlcmd.txt
+###### alternate method with db.in.ogr: (needs work) ######
+#### convert text file table to a database table
+# not safe for commas in the label
+tr '|' ',' < fields_stats.txt > fields_stats.csv
+echo '"Integer","String","Real","Real","Real"' > fields_stats.csvt
+# import table
+db.in.ogr dsn=fields_stats.csv output=fields_data
+# view table
+db.select fields_data
+# remove temporary files
+rm fields_stats.csv fields_stats.csvt fields_stats.txt
+# perform DB step (broken)
+## how to automatically collate by key column, ie copy between tables?
+## SELECT INTO? JOIN?
+echo "INSERT INTO fields_stats (mean_elev,min_elev,max_elev) SELECT mean,min,max FROM fields_data" | db.execute
+#### view completed table
+v.db.select fields_stats
+</pre></div>
<h2>TODO</h2>
<i>mode, skewness, kurtosis</i>
<h2>SEE ALSO</h2>
<em>
<a href="g.region.html">g.region</a><br>
<a href="r3.univar.html">r3.univar</a><br>
-<a href="r.univar.sh.html">r.univar.sh</a><br>
<a href="r.average.html">r.average</a><br>
<a href="r.median.html">r.median</a><br>
<a href="r.mode.html">r.mode</a><br>
@@ -43,16 +117,17 @@
<a href="r.sum.html">r.sum</a><br>
<a href="r.series.html">r.series</a><br>
<a href="r.stats.html">r.stats</a><br>
+<a href="v.rast.stats.html">v.rast.stats</a><br>
<a href="r.statistics.html">r.statistics</a><br>
<a href="v.univar.html">v.univar</a><br>
-<a href="v.univar.sh.html">v.univar.sh</a><br>
</em>
<h2>AUTHORS</h2>
Hamish Bowman, Otago University, New Zealand<br>
-Extended statistics by Martin Landa
+Extended statistics by Martin Landa<br>
+Zonal loop by Markus Metz
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/r.univar_main.c 2010-10-07 10:28:04 UTC (rev 43812)
@@ -19,14 +19,26 @@
#include "globals.h"
param_type param;
+zone_type zone_info;
/* Set up the arguments we are expecting ********************************** */
-void set_params(void)
+void set_params()
param.inputfile = G_define_standard_option(G_OPT_R_MAPS);
+ param.zonefile = G_define_standard_option(G_OPT_R_MAP);
+ param.zonefile->key = "zones";
+ param.zonefile->required = NO;
+ param.zonefile->description =
+ _("Raster map used for zoning, must be of type CELL");
+ param.output_file = G_define_standard_option(G_OPT_F_OUTPUT);
+ param.output_file->required = NO;
+ param.output_file->description =
+ _("Name for output file (if omitted or \"-\" output to stdout)");
param.percentile = G_define_option();
param.percentile->key = "percentile";
param.percentile->type = TYPE_DOUBLE;
@@ -37,6 +49,9 @@
param.percentile->description =
_("Percentile to calculate (requires extended statistics flag)");
+ param.separator = G_define_standard_option(G_OPT_F_SEP);
+ param.separator->description = _("Special characters: space, comma, tab");
param.shell_style = G_define_flag();
param.shell_style->key = 'g';
param.shell_style->description =
@@ -46,12 +61,16 @@
param.extended->key = 'e';
param.extended->description = _("Calculate extended statistics");
+ param.table = G_define_flag();
+ param.table->key = 't';
+ param.table->description = _("Table output format instead of standard output format");
return;
static int open_raster(const char *infile);
-static univar_stat *univar_stat_with_percentiles(int map_type, int size);
-static void process_raster(univar_stat * stats, int fd,
+static univar_stat *univar_stat_with_percentiles(int map_type);
+static void process_raster(univar_stat * stats, int fd, int fdz,
const struct Cell_head *region);
@@ -65,8 +84,11 @@
struct Cell_head region;
struct GModule *module;
univar_stat *stats;
+ char **p, *z;
+ int fd, fdz, cell_type, min, max;
+ struct Range zone_range;
+ const char *mapset, *name;
G_gisinit(argv[0]);
module = G_define_module();
@@ -81,56 +103,101 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ name = param.output_file->answer;
+ if (name != NULL && strcmp(name, "-") != 0) {
+ if (NULL == freopen(name, "w", stdout)) {
+ G_fatal_error(_("Unable to open file <%s> for writing"), name);
G_get_window(®ion);
rows = region.rows;
cols = region.cols;
- /* count the rasters given */
- const char **p;
+ /* table field separator */
+ zone_info.sep = param.separator->answer;
+ if (strcmp(zone_info.sep, "\\t") == 0)
+ zone_info.sep = "\t";
+ if (strcmp(zone_info.sep, "tab") == 0)
+ if (strcmp(zone_info.sep, "space") == 0)
+ zone_info.sep = " ";
+ if (strcmp(zone_info.sep, "comma") == 0)
+ zone_info.sep = ",";
- for (p = (const char **)param.inputfile->answers, rasters = 0;
- *p; p++, rasters++) ;
+ zone_info.min = 0.0 / 0.0; /*set to nan as default */
+ zone_info.max = 0.0 / 0.0; /*set to nan as default */
+ zone_info.n_zones = 0;
+ fdz = -1;
+ /* open zoning raster */
+ if ((z = param.zonefile->answer)) {
+ mapset = G_find_raster2(z, "");
+ fdz = open_raster(z);
+ cell_type = Rast_get_map_type(fdz);
+ if (cell_type != CELL_TYPE)
+ G_fatal_error("Zoning raster must be of type CELL");
+ if (Rast_read_range(z, mapset, &zone_range) == -1)
+ G_fatal_error("Can not read range for zoning raster");
+ Rast_get_range_min_max(&zone_range, &min, &max);
+ if (Rast_read_cats(z, mapset, &(zone_info.cats)))
+ G_warning("no category support for zoning raster");
+ zone_info.min = min;
+ zone_info.max = max;
+ zone_info.n_zones = max - min + 1;
- /* process them all */
- size_t cells = rasters * cols * rows;
- int map_type = param.extended->answer ? -2 : -1;
- char **p;
+ /* count the input rasters given */
+ for (p = (char **)param.inputfile->answers, rasters = 0;
+ *p; p++, rasters++) ;
- stats = ((map_type == -1)
- ? create_univar_stat_struct(-1, cells, 0)
- : 0);
+ /* process all input rasters */
+ int map_type = param.extended->answer ? -2 : -1;
- for (p = param.inputfile->answers; *p; p++) {
- int fd = open_raster(*p);
+ stats = ((map_type == -1)
+ ? create_univar_stat_struct(-1, 0)
+ : 0);
- if (map_type != -1) {
- /* NB: map_type must match when doing extended stats */
- int this_type = Rast_get_map_type(fd);
+ for (p = param.inputfile->answers; *p; p++) {
+ fd = open_raster(*p);
- assert(this_type > -1);
- if (map_type < -1) {
- assert(stats == 0);
- map_type = this_type;
- stats = univar_stat_with_percentiles(map_type, cells);
- else if (this_type != map_type) {
- G_fatal_error(_("Raster <%s> type mismatch"), *p);
+ if (map_type != -1) {
+ /* NB: map_type must match when doing extended stats */
+ int this_type = Rast_get_map_type(fd);
+ assert(this_type > -1);
+ if (map_type < -1) {
+ /* extended stats */
+ assert(stats == 0);
+ map_type = this_type;
+ stats = univar_stat_with_percentiles(map_type);
+ else if (this_type != map_type) {
+ G_fatal_error(_("Raster <%s> type mismatch"), *p);
- process_raster(stats, fd, ®ion);
+ process_raster(stats, fd, fdz, ®ion);
+ /* close input raster */
+ Rast_close(fd);
- if (!(param.shell_style->answer))
- G_percent(rows, rows, 2); /* finish it off */
+ /* close zoning raster */
+ if (z)
+ Rast_close(fdz);
/* create the output */
- print_stats(stats);
+ if (param.table->answer)
+ print_stats_table(stats);
+ else
+ print_stats(stats);
/* release memory */
free_univar_stat_struct(stats);
@@ -139,20 +206,36 @@
- return Rast_open_old(infile, "");
+ const char *mapset;
+ int fd;
+ mapset = G_find_raster2(infile, "");
+ if (mapset == NULL) {
+ G_fatal_error(_("Raster map <%s> not found"), infile);
+ fd = Rast_open_old(infile, mapset);
+ return fd;
univar_stat *stats;
- int i;
+ int i, j;
+ int n_zones = zone_info.n_zones;
+ if (n_zones == 0)
+ n_zones = 1;
i = 0;
while (param.percentile->answers[i])
i++;
- stats = create_univar_stat_struct(map_type, size, i);
- for (i = 0; i < stats->n_perc; i++) {
- sscanf(param.percentile->answers[i], "%lf", &stats->perc[i]);
+ stats = create_univar_stat_struct(map_type, i);
+ for (i = 0; i < n_zones; i++) {
+ for (j = 0; j < stats[i].n_perc; j++) {
+ sscanf(param.percentile->answers[j], "%lf", &(stats[i].perc[j]));
@@ -160,72 +243,123 @@
static void
-process_raster(univar_stat * stats, int fd, const struct Cell_head *region)
+process_raster(univar_stat * stats, int fd, int fdz, const struct Cell_head *region)
- /* use Rast_window_rows(), Rast_window_cols() here? */
+ /* use G_window_rows(), G_window_cols() here? */
const int rows = region->rows;
const int cols = region->cols;
- int first = (stats->n < 1);
const RASTER_MAP_TYPE map_type = Rast_get_map_type(fd);
- void *nextp
- = ((!param.extended->answer) ? 0
- : (map_type == DCELL_TYPE) ? (void *)stats->dcell_array
- : (map_type == FCELL_TYPE) ? (void *)stats->fcell_array
- : (void *)stats->cell_array);
const size_t value_sz = Rast_cell_size(map_type);
unsigned int row;
void *raster_row;
+ CELL *zoneraster_row;
+ raster_row = Rast_allocate_buf(map_type);
+ if (n_zones)
+ zoneraster_row = Rast_allocate_c_buf();
- raster_row = G_calloc(cols, value_sz);
for (row = 0; row < rows; row++) {
void *ptr;
+ CELL *zptr;
unsigned int col;
Rast_get_row(fd, raster_row, row, map_type);
+ if (n_zones) {
+ Rast_get_c_row(fdz, zoneraster_row, row);
+ zptr = zoneraster_row;
ptr = raster_row;
for (col = 0; col < cols; col++) {
+ double val;
+ int zone = 0;
+ if (n_zones) {
+ /* skip NULL cells in zone map */
+ if (Rast_is_c_null_value(zptr)) {
+ ptr = G_incr_void_ptr(ptr, value_sz);
+ zptr++;
+ continue;
+ zone = *zptr - zone_info.min;
+ /* count all including NULL cells in input map */
+ stats[zone].size++;
+ /* can't do stats with NULL cells in input map */
if (Rast_is_null_value(ptr, map_type)) {
+ if (n_zones)
+ zptr++;
continue;
- if (nextp) {
+ if (param.extended->answer) {
+ /* check allocated memory */
+ if (stats[zone].n >= stats[zone].n_alloc) {
+ stats[zone].n_alloc += 1000;
+ size_t msize;
+ switch (map_type) {
+ case DCELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(DCELL);
+ stats[zone].dcell_array =
+ (DCELL *)G_realloc((void *)stats[zone].dcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].dcell_array[stats[zone].n]);
+ break;
+ case FCELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(FCELL);
+ stats[zone].fcell_array =
+ (FCELL *)G_realloc((void *)stats[zone].fcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].fcell_array[stats[zone].n]);
+ break;
+ case CELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(CELL);
+ stats[zone].cell_array =
+ (CELL *)G_realloc((void *)stats[zone].cell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].cell_array[stats[zone].n]);
+ break;
+ default:
+ break;
/* put the value into stats->XXXcell_array */
- memcpy(nextp, ptr, value_sz);
- nextp = G_incr_void_ptr(nextp, value_sz);
+ memcpy(stats[zone].nextp, ptr, value_sz);
+ stats[zone].nextp = G_incr_void_ptr(stats[zone].nextp, value_sz);
- double val = ((map_type == DCELL_TYPE) ? *((DCELL *) ptr)
- : (map_type == FCELL_TYPE) ? *((FCELL *) ptr)
- : *((CELL *) ptr));
+ val = ((map_type == DCELL_TYPE) ? *((DCELL *) ptr)
+ : (map_type == FCELL_TYPE) ? *((FCELL *) ptr)
+ : *((CELL *) ptr));
- stats->sum += val;
- stats->sumsq += val * val;
- stats->sum_abs += fabs(val);
+ stats[zone].sum += val;
+ stats[zone].sumsq += val * val;
+ stats[zone].sum_abs += fabs(val);
- if (first) {
- stats->max = val;
- stats->min = val;
- first = FALSE;
- else {
- if (val > stats->max)
- stats->max = val;
- if (val < stats->min)
- stats->min = val;
+ if (stats[zone].first) {
+ stats[zone].max = val;
+ stats[zone].min = val;
+ stats[zone].first = FALSE;
+ else {
+ if (val > stats[zone].max)
+ if (val < stats[zone].min)
- stats->n++;
+ if (n_zones)
+ zptr++;
+ stats[zone].n++;
G_percent(row, rows, 2);
+ if (!(param.shell_style->answer))
+ G_percent(rows, rows, 2); /* finish it off */
Modified: grass/trunk/raster/r.univar/r3.univar.html
--- grass/trunk/raster/r.univar/r3.univar.html 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/r3.univar.html 2010-10-07 10:28:04 UTC (rev 43812)
@@ -3,11 +3,16 @@
<em>r3.univar</em> calculates the univariate statistics for raster3d maps.
<h2>NOTES</h2>
@@ -19,6 +24,7 @@
extended statistics flag is used with a very large region setting. If the
<!-- no rast3D support?
<p>
@@ -36,7 +42,6 @@
<em>
<a href="r.univar.html">r.univar</a><br>
@@ -46,7 +51,6 @@
</em>
@@ -55,7 +59,8 @@
Soeren Gebbert<br>
Code is based on r.univar from<br>
-and Martin Landa
+and Martin Landa<br>
<p>
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/r3.univar_main.c 2010-10-07 10:28:04 UTC (rev 43812)
@@ -15,17 +15,31 @@
+#include <string.h>
+#include "grass/G3d.h"
param_type param;
+void set_params()
param.inputfile = G_define_standard_option(G_OPT_R3_INPUT);
+ param.zonefile = G_define_standard_option(G_OPT_R3_INPUT);
+ _("3D Raster map used for zoning, must be of type CELL");
@@ -36,6 +50,9 @@
@@ -45,6 +62,10 @@
return;
@@ -59,15 +80,19 @@
double val_d; /* for misc use */
int first = TRUE; /* min/max init flag */
- int map_type;
+ int map_type, zmap_type;
univar_stat *stats;
- char *infile;
- void *map;
+ char *infile, *zonemap;
+ void *map, *zmap = NULL;
G3D_Region region;
unsigned int i;
unsigned int rows, cols, depths;
unsigned int x, y, z;
+ double dmin, dmax;
+ int zone, use_zone = 0;
+ char *mapset, *name;
+ struct FPRange zone_range;
@@ -85,7 +110,6 @@
exit(EXIT_FAILURE);
/*Set the defaults */
G3d_initDefaults();
@@ -96,13 +120,77 @@
rows = region.rows;
depths = region.depths;
+ dmin = 0.0 / 0.0; /*set to nan as default */
+ dmax = 0.0 / 0.0; /*set to nan as default */
+ /* open 3D zoning raster with default region */
+ if ((zonemap = param.zonefile->answer) != NULL) {
+ if (NULL == (mapset = G_find_grid3(zonemap, "")))
+ G3d_fatalError(_("Requested g3d map <%s> not found"), zonemap);
+ zmap =
+ G3d_openCellOld(zonemap, G_find_grid3(zonemap, ""), ®ion,
+ G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT);
+ if (zmap == NULL)
+ G3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
+ if (G3d_tileTypeMap(zmap) != CELL_TYPE)
+ zmap_type = G3d_tileTypeMap(zmap);
+ if (zmap_type != CELL_TYPE)
+ if (G3d_readRange(zonemap, mapset, &zone_range) == -1)
+ G3d_range_min_max(zmap, &dmin, &dmax);
+ if (Rast_read_cats(zonemap, mapset, &(zone_info.cats)))
+ /* properly round dmin and dmax */
+ if (dmin < 0)
+ zone_info.min = dmin - 0.5;
+ else
+ zone_info.min = dmin + 0.5;
+ if (dmax < 0)
+ zone_info.max = dmax - 0.5;
+ else
+ zone_info.max = dmax + 0.5;
+ zone_info.n_zones = zone_info.max - zone_info.min + 1;
+ use_zone = 1;
+ /*Open 3D input raster with default region */
infile = param.inputfile->answer;
if (NULL == G_find_grid3(infile, ""))
G3d_fatalError(_("Requested g3d map <%s> not found"), infile);
- /*Open all maps with default region */
map =
G3d_openCellOld(infile, G_find_grid3(infile, ""), ®ion,
@@ -115,71 +203,102 @@
i = 0;
i++;
- stats = create_univar_stat_struct(map_type, cols * rows * depths, i);
+ for (i = 0; i < zone_info.n_zones; i++) {
+ unsigned int j;
- stats->n = 0;
for (z = 0; z < depths; z++) { /*From the bottom to the top */
G_percent(z, depths - 1, 10);
for (y = 0; y < rows; y++) {
for (x = 0; x < cols; x++) {
+ zone = 0;
+ if (zone_info.n_zones)
+ G3d_getValue(zmap, x, y, z, &zone, CELL_TYPE);
if (map_type == FCELL_TYPE) {
G3d_getValue(map, x, y, z, &val_f, map_type);
if (!G3d_isNullValueNum(&val_f, map_type)) {
- if (param.extended->answer)
- stats->fcell_array[stats->n] = val_f;
+ size_t msize;
- stats->sum += val_f;
- stats->sumsq += (val_f * val_f);
- stats->sum_abs += fabs(val_f);
+ stats[zone].fcell_array[stats[zone].n] = val_f;
- if (first) {
- stats->max = val_f;
- stats->min = val_f;
- first = FALSE;
+ stats[zone].sum += val_f;
+ stats[zone].sumsq += (val_f * val_f);
+ stats[zone].sum_abs += fabs(val_f);
+ stats[zone].max = val_f;
+ stats[zone].min = val_f;
else {
- if (val_f > stats->max)
- if (val_f < stats->min)
+ if (val_f > stats[zone].max)
+ if (val_f < stats[zone].min)
- stats->n++;
+ stats[zone].n++;
else if (map_type == DCELL_TYPE) {
G3d_getValue(map, x, y, z, &val_d, map_type);
if (!G3d_isNullValueNum(&val_d, map_type)) {
- stats->dcell_array[stats->n] = val_d;
+ size_t msize;
- stats->sum += val_d;
- stats->sumsq += val_d * val_d;
- stats->sum_abs += fabs(val_d);
+ stats[zone].dcell_array[stats[zone].n] = val_d;
+ stats[zone].sum += val_d;
+ stats[zone].sumsq += val_d * val_d;
+ stats[zone].sum_abs += fabs(val_d);
if (first) {
- stats->max = val_d;
- stats->min = val_d;
- first = FALSE;
+ stats[zone].max = val_d;
+ stats[zone].min = val_d;
else {
- if (val_d > stats->max)
- if (val_d < stats->min)
+ if (val_d > stats[zone].max)
+ if (val_d < stats[zone].min)
- stats->n++;
+ stats[zone].n++;
+ /* close maps */
+ G3d_closeCell(map);
+ G3d_closeCell(zmap);
+ else
Modified: grass/trunk/raster/r.univar/stats.c
--- grass/trunk/raster/r.univar/stats.c 2010-10-06 23:14:36 UTC (rev 43811)
+++ grass/trunk/raster/r.univar/stats.c 2010-10-07 10:28:04 UTC (rev 43812)
@@ -16,39 +16,55 @@
/* **** univar_stat constructor ********************************** */
univar_stat *stats;
+ int i;
- stats = (univar_stat *) G_calloc(1, sizeof(univar_stat));
+ if (n_zones == 0)
+ n_zones = 1;
- stats->sum = 0.0;
- stats->sumsq = 0.0;
- stats->min = 0.0 / 0.0; /*set to nan as default */
- stats->max = 0.0 / 0.0; /*set to nan as default */
- stats->n_perc = n_perc;
- if (n_perc > 0)
- stats->perc = (double *)G_malloc(n_perc * sizeof(double));
- else
- stats->perc = NULL;
- stats->sum_abs = 0.0;
- stats->n = 0;
- stats->size = size;
- stats->dcell_array = NULL;
- stats->fcell_array = NULL;
- stats->cell_array = NULL;
- stats->map_type = map_type;
+ stats = (univar_stat *) G_calloc(n_zones, sizeof(univar_stat));
- /* alloacte memory for extended computation */
- if (param.extended->answer) {
- if (map_type == DCELL_TYPE)
- (DCELL *) G_calloc(stats->size, sizeof(DCELL));
- if (map_type == FCELL_TYPE)
- (FCELL *) G_calloc(stats->size, sizeof(FCELL));
- if (map_type == CELL_TYPE)
- stats->cell_array = (CELL *) G_calloc(stats->size, sizeof(CELL));
+ stats[i].sum = 0.0;
+ stats[i].sumsq = 0.0;
+ stats[i].min = 0.0 / 0.0; /* set to nan as default */
+ stats[i].max = 0.0 / 0.0; /* set to nan as default */
+ stats[i].n_perc = n_perc;
+ if (n_perc > 0)
+ stats[i].perc = (double *)G_malloc(n_perc * sizeof(double));
+ else
+ stats[i].perc = NULL;
+ stats[i].sum_abs = 0.0;
+ stats[i].n = 0;
+ stats[i].size = 0;
+ stats[i].dcell_array = NULL;
+ stats[i].fcell_array = NULL;
+ stats[i].cell_array = NULL;
+ stats[i].map_type = map_type;
+ stats[i].n_alloc = 0;
+ stats[i].first = TRUE;
+ /* allocate memory for extended computation */
+ /* changed to on-demand block allocation */
+/* if (param.extended->answer) {
+ if (map_type == DCELL_TYPE) {
+ else if (map_type == FCELL_TYPE) {
+ stats[i].fcell_array =NULL;
+ else if (map_type == CELL_TYPE) {
return stats;
@@ -60,15 +76,23 @@
- if (stats->perc)
- G_free(stats->perc);
- if (stats->dcell_array)
- G_free(stats->dcell_array);
- if (stats->fcell_array)
- G_free(stats->fcell_array);
- if (stats->cell_array)
- G_free(stats->cell_array);
+ int i;
+ if (n_zones == 0)
+ n_zones = 1;
+ for (i = 0; i < n_zones; i++){
+ if (stats[i].perc)
+ G_free(stats[i].perc);
+ if (stats[i].dcell_array)
+ G_free(stats[i].dcell_array);
+ if (stats[i].fcell_array)
+ G_free(stats[i].fcell_array);
+ if (stats[i].cell_array)
+ G_free(stats[i].cell_array);
G_free(stats);
return;
@@ -80,187 +104,391 @@
- char sum_str[100];
- double mean, variance, stdev, var_coef;
+ int z, n_zones = zone_info.n_zones;
- /*for extendet stats */
- double quartile_25 = 0.0, quartile_75 = 0.0, *quartile_perc;
- double median = 0.0;
- unsigned int i;
- int qpos_25, qpos_75, *qpos_perc;
+ if (n_zones == 0)
+ n_zones = 1;
+ for (z = 0; z < n_zones; z++) {
+ char sum_str[100];
+ double mean, variance, stdev, var_coef;
- /* all these calculations get promoted to doubles, so any DIV0 becomes nan */
- mean = stats->sum / stats->n;
- variance = (stats->sumsq - stats->sum * stats->sum / stats->n) / stats->n;
- if (variance < GRASS_EPSILON)
- variance = 0.0;
- stdev = sqrt(variance);
- var_coef = (stdev / mean) * 100.; /* perhaps stdev/fabs(mean) ? */
+ /*for extendet stats */
+ double quartile_25 = 0.0, quartile_75 = 0.0, *quartile_perc;
+ double median = 0.0;
+ unsigned int i;
+ int qpos_25, qpos_75, *qpos_perc;
- sprintf(sum_str, "%.10f", stats->sum);
- G_trim_decimal(sum_str);
+ /* stats collected for this zone? */
+ if (stats[z].n == 0)
+ continue;
- if (!param.shell_style->answer) {
- fprintf(stdout, "total null and non-null cells: %d\n", stats->size);
- fprintf(stdout, "total null cells: %d\n\n", stats->size - stats->n);
- fprintf(stdout, "Of the non-null cells:\n----------------------\n");
+ /* all these calculations get promoted to doubles, so any DIV0 becomes nan */
+ mean = stats[z].sum / stats[z].n;
+ variance = (stats[z].sumsq - stats[z].sum * stats[z].sum / stats[z].n) / stats[z].n;
+ if (variance < GRASS_EPSILON)
+ variance = 0.0;
+ stdev = sqrt(variance);
+ var_coef = (stdev / mean) * 100.; /* perhaps stdev/fabs(mean) ? */
- if (param.shell_style->answer) {
- fprintf(stdout, "n=%d\n", stats->n);
- fprintf(stdout, "null_cells=%d\n", stats->size - stats->n);
- fprintf(stdout, "cells=%d\n", stats->size);
- fprintf(stdout, "min=%.15g\n", stats->min);
- fprintf(stdout, "max=%.15g\n", stats->max);
- fprintf(stdout, "range=%.15g\n", stats->max - stats->min);
- fprintf(stdout, "mean=%.15g\n", mean);
- fprintf(stdout, "mean_of_abs=%.15g\n", stats->sum_abs / stats->n);
- fprintf(stdout, "stddev=%.15g\n", stdev);
- fprintf(stdout, "variance=%.15g\n", variance);
- fprintf(stdout, "coeff_var=%.15g\n", var_coef);
- fprintf(stdout, "sum=%s\n", sum_str);
- else {
- fprintf(stdout, "n: %d\n", stats->n);
- fprintf(stdout, "minimum: %g\n", stats->min);
- fprintf(stdout, "maximum: %g\n", stats->max);
- fprintf(stdout, "range: %g\n", stats->max - stats->min);
- fprintf(stdout, "mean: %g\n", mean);
- fprintf(stdout, "mean of absolute values: %g\n",
- stats->sum_abs / stats->n);
- fprintf(stdout, "standard deviation: %g\n", stdev);
- fprintf(stdout, "variance: %g\n", variance);
- fprintf(stdout, "variation coefficient: %g %%\n", var_coef);
- fprintf(stdout, "sum: %s\n", sum_str);
+ sprintf(sum_str, "%.10f", stats[z].sum);
+ G_trim_decimal(sum_str);
+ if (zone_info.n_zones) {
+ int z_cat = z + zone_info.min;
+ fprintf(stdout, "\nzone %d %s\n\n", z_cat, Rast_get_c_cat(&z_cat, &(zone_info.cats)));
- /* TODO: mode, skewness, kurtosis */
- qpos_perc = (int *)G_calloc(stats->n_perc, sizeof(int));
- quartile_perc = (double *)G_calloc(stats->n_perc, sizeof(double));
- qpos_perc[i] = (int)(stats->n * 1e-2 * stats->perc[i] - 0.5);
+ if (!param.shell_style->answer) {
+ fprintf(stdout, "total null and non-null cells: %d\n", stats[z].size);
+ fprintf(stdout, "total null cells: %d\n\n", stats[z].size - stats[z].n);
+ fprintf(stdout, "Of the non-null cells:\n----------------------\n");
- qpos_25 = (int)(stats->n * 0.25 - 0.5);
- qpos_75 = (int)(stats->n * 0.75 - 0.5);
- switch (stats->map_type) {
- case CELL_TYPE:
- heapsort_int(stats->cell_array, stats->n);
+ if (param.shell_style->answer) {
+ fprintf(stdout, "n=%d\n", stats[z].n);
+ fprintf(stdout, "null_cells=%d\n", stats[z].size - stats[z].n);
+ fprintf(stdout, "cells=%d\n", stats->size);
+ fprintf(stdout, "min=%.15g\n", stats[z].min);
+ fprintf(stdout, "max=%.15g\n", stats[z].max);
+ fprintf(stdout, "range=%.15g\n", stats[z].max - stats[z].min);
+ fprintf(stdout, "mean=%.15g\n", mean);
+ fprintf(stdout, "mean_of_abs=%.15g\n", stats[z].sum_abs / stats[z].n);
+ fprintf(stdout, "stddev=%.15g\n", stdev);
+ fprintf(stdout, "variance=%.15g\n", variance);
+ fprintf(stdout, "coeff_var=%.15g\n", var_coef);
+ fprintf(stdout, "sum=%s\n", sum_str);
+ else {
+ fprintf(stdout, "n: %d\n", stats[z].n);
+ fprintf(stdout, "minimum: %g\n", stats[z].min);
+ fprintf(stdout, "maximum: %g\n", stats[z].max);
+ fprintf(stdout, "range: %g\n", stats[z].max - stats[z].min);
+ fprintf(stdout, "mean: %g\n", mean);
+ fprintf(stdout, "mean of absolute values: %g\n",
+ stats[z].sum_abs / stats[z].n);
+ fprintf(stdout, "standard deviation: %g\n", stdev);
+ fprintf(stdout, "variance: %g\n", variance);
+ fprintf(stdout, "variation coefficient: %g %%\n", var_coef);
+ fprintf(stdout, "sum: %s\n", sum_str);
- quartile_25 = (double)stats->cell_array[qpos_25];
- if (stats->n % 2) /* odd */
- median = (double)stats->cell_array[(int)(stats->n / 2)];
- else /* even */
- median =
- (double)(stats->cell_array[stats->n / 2 - 1] +
- stats->cell_array[stats->n / 2]) / 2.0;
- quartile_75 = (double)stats->cell_array[qpos_75];
- quartile_perc[i] = (double)stats->cell_array[qpos_perc[i]];
+ /* TODO: mode, skewness, kurtosis */
+ qpos_perc = (int *)G_calloc(stats[z].n_perc, sizeof(int));
+ quartile_perc = (double *)G_calloc(stats[z].n_perc, sizeof(double));
+ for (i = 0; i < stats[z].n_perc; i++) {
+ qpos_perc[i] = (int)(stats[z].n * 1e-2 * stats[z].perc[i] - 0.5);
- break;
+ qpos_25 = (int)(stats[z].n * 0.25 - 0.5);
+ qpos_75 = (int)(stats[z].n * 0.75 - 0.5);
- case FCELL_TYPE:
- heapsort_float(stats->fcell_array, stats->n);
+ switch (stats[z].map_type) {
+ case CELL_TYPE:
+ heapsort_int(stats[z].cell_array, stats[z].n);
- quartile_25 = (double)stats->fcell_array[qpos_25];
- median = (double)stats->fcell_array[(int)(stats->n / 2)];
- else /* even */
- median =
- (double)(stats->fcell_array[stats->n / 2 - 1] +
- stats->fcell_array[stats->n / 2]) / 2.0;
- quartile_75 = (double)stats->fcell_array[qpos_75];
- quartile_perc[i] = (double)stats->fcell_array[qpos_perc[i]];
+ quartile_25 = (double)stats[z].cell_array[qpos_25];
+ if (stats[z].n % 2) /* odd */
+ median = (double)stats[z].cell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (double)(stats[z].cell_array[stats[z].n / 2 - 1] +
+ stats[z].cell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = (double)stats[z].cell_array[qpos_75];
+ quartile_perc[i] = (double)stats[z].cell_array[qpos_perc[i]];
+ break;
+ case FCELL_TYPE:
+ heapsort_float(stats[z].fcell_array, stats[z].n);
+ quartile_25 = (double)stats[z].fcell_array[qpos_25];
+ median = (double)stats[z].fcell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (double)(stats[z].fcell_array[stats[z].n / 2 - 1] +
+ stats[z].fcell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = (double)stats[z].fcell_array[qpos_75];
+ quartile_perc[i] = (double)stats[z].fcell_array[qpos_perc[i]];
+ break;
+ case DCELL_TYPE:
+ heapsort_double(stats[z].dcell_array, stats[z].n);
+ quartile_25 = stats[z].dcell_array[qpos_25];
+ median = stats[z].dcell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (stats[z].dcell_array[stats[z].n / 2 - 1] +
+ stats[z].dcell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = stats[z].dcell_array[qpos_75];
+ quartile_perc[i] = stats[z].dcell_array[qpos_perc[i]];
+ break;
+ default:
+ break;
- break;
- case DCELL_TYPE:
- heapsort_double(stats->dcell_array, stats->n);
+ fprintf(stdout, "first_quartile=%g\n", quartile_25);
+ fprintf(stdout, "median=%g\n", median);
+ fprintf(stdout, "third_quartile=%g\n", quartile_75);
+ char buf[24];
+ sprintf(buf, "%.15g", stats[z].perc[i]);
+ G_strchg(buf, '.', '_');
+ fprintf(stdout, "percentile_%s=%g\n", buf,
+ quartile_perc[i]);
+ else {
+ fprintf(stdout, "1st quartile: %g\n", quartile_25);
+ fprintf(stdout, "median (odd number of cells): %g\n", median);
+ else
+ fprintf(stdout, "median (even number of cells): %g\n",
+ median);
+ fprintf(stdout, "3rd quartile: %g\n", quartile_75);
- quartile_25 = stats->dcell_array[qpos_25];
- median = stats->dcell_array[(int)(stats->n / 2)];
- else /* even */
- median =
- (stats->dcell_array[stats->n / 2 - 1] +
- stats->dcell_array[stats->n / 2]) / 2.0;
- quartile_75 = stats->dcell_array[qpos_75];
- quartile_perc[i] = stats->dcell_array[qpos_perc[i]];
+ if (stats[z].perc[i] == (int)stats[z].perc[i]) {
+ /* percentile is an exact integer */
+ if ((int)stats[z].perc[i] % 10 == 1 && (int)stats[z].perc[i] != 11)
+ fprintf(stdout, "%dst percentile: %g\n", (int)stats[z].perc[i],
+ else if ((int)stats[z].perc[i] % 10 == 2 && (int)stats[z].perc[i] != 12)
+ fprintf(stdout, "%dnd percentile: %g\n", (int)stats[z].perc[i],
+ else if ((int)stats[z].perc[i] % 10 == 3 && (int)stats[z].perc[i] != 13)
+ fprintf(stdout, "%drd percentile: %g\n", (int)stats[z].perc[i],
+ else
+ fprintf(stdout, "%dth percentile: %g\n", (int)stats[z].perc[i],
+ else {
+ /* percentile is not an exact integer */
+ fprintf(stdout, "%.15g percentile: %g\n", stats[z].perc[i],
- break;
- default:
- break;
+ G_free((void *)quartile_perc);
+ G_free((void *)qpos_perc);
- fprintf(stdout, "first_quartile=%g\n", quartile_25);
- fprintf(stdout, "median=%g\n", median);
- fprintf(stdout, "third_quartile=%g\n", quartile_75);
+ /* G_message() prints to stderr not stdout: disabled. this \n is printed above with zone */
+ /* if (!(param.shell_style->answer))
+ G_message("\n"); */
+ return 1;
+ unsigned int i;
+ if (n_zones == 0)
+ n_zones = 1;
+ /* print column headers */
+ fprintf(stdout, "zone%s", zone_info.sep);
+ fprintf(stdout, "label%s", zone_info.sep);
+ fprintf(stdout, "non_null_cells%s", zone_info.sep);
+ fprintf(stdout, "null_cells%s", zone_info.sep);
+ fprintf(stdout, "min%s", zone_info.sep);
+ fprintf(stdout, "max%s", zone_info.sep);
+ fprintf(stdout, "range%s", zone_info.sep);
+ fprintf(stdout, "mean%s", zone_info.sep);
+ fprintf(stdout, "mean_of_abs%s", zone_info.sep);
+ fprintf(stdout, "stddev%s", zone_info.sep);
+ fprintf(stdout, "variance%s", zone_info.sep);
+ fprintf(stdout, "coeff_var%s", zone_info.sep);
+ fprintf(stdout, "sum%s", zone_info.sep);
+ fprintf(stdout, "sum_abs");
+ fprintf(stdout, "%sfirst_quart", zone_info.sep);
+ fprintf(stdout, "%smedian", zone_info.sep);
+ fprintf(stdout, "%sthird_quart", zone_info.sep);
+ for (i = 0; i < stats[0].n_perc; i++) {
+ if (stats[0].perc[i] == (int)stats[0].perc[i]) {
+ fprintf(stdout, "%sperc_%d", zone_info.sep, (int)stats[0].perc[i]);
+ else {
char buf[24];
- sprintf(buf, "%.15g", stats->perc[i]);
+ sprintf(buf, "%.15g", stats[0].perc[i]);
- fprintf(stdout, "percentile_%s=%g\n", buf, quartile_perc[i]);
+ fprintf(stdout, "%sperc_%s", zone_info.sep, buf);
- else {
- fprintf(stdout, "1st quartile: %g\n", quartile_25);
- if (stats->n % 2)
- fprintf(stdout, "median (odd number of cells): %g\n", median);
- else
- fprintf(stdout, "median (even number of cells): %g\n",
- median);
- fprintf(stdout, "3rd quartile: %g\n", quartile_75);
+ fprintf(stdout, "\n");
+ /* print stats */
- if (stats->perc[i] == (int)stats->perc[i]) {
- /* percentile is an exact integer */
- if ((int)stats->perc[i] % 10 == 1 && (int)stats->perc[i] != 11)
- fprintf(stdout, "%dst percentile: %g\n", (int)stats->perc[i],
- quartile_perc[i]);
- else if ((int)stats->perc[i] % 10 == 2 && (int)stats->perc[i] != 12)
- fprintf(stdout, "%dnd percentile: %g\n", (int)stats->perc[i],
- else if ((int)stats->perc[i] % 10 == 3 && (int)stats->perc[i] != 13)
- fprintf(stdout, "%drd percentile: %g\n", (int)stats->perc[i],
- else
- fprintf(stdout, "%dth percentile: %g\n", (int)stats->perc[i],
+ continue;
+ i = 0;
+ variance = 0.0;
+ /* zone number */
+ fprintf(stdout, "%d%s", z + zone_info.min, zone_info.sep);
+ /* zone label */
+ fprintf(stdout,"%s%s", Rast_get_c_cat(&z_cat, &(zone_info.cats)), zone_info.sep);
+ /* non-null cells cells */
+ fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
+ /* null cells */
+ fprintf(stdout, "%d%s", stats[z].size - stats[z].n, zone_info.sep);
+ /* min */
+ fprintf(stdout, "%.15g%s", stats[z].min, zone_info.sep);
+ /* max */
+ fprintf(stdout, "%.15g%s", stats[z].max, zone_info.sep);
+ /* range */
+ fprintf(stdout, "%.15g%s", stats[z].max - stats[z].min, zone_info.sep);
+ /* mean */
+ fprintf(stdout, "%.15g%s", mean, zone_info.sep);
+ /* mean of abs */
+ fprintf(stdout, "%.15g%s", stats[z].sum_abs / stats[z].n, zone_info.sep);
+ /* stddev */
+ fprintf(stdout, "%.15g%s", stdev, zone_info.sep);
+ /* variance */
+ fprintf(stdout, "%.15g%s", variance, zone_info.sep);
+ /* coefficient of variance */
+ fprintf(stdout, "%.15g%s", var_coef, zone_info.sep);
+ /* sum */
+ fprintf(stdout, "%s%s", sum_str, zone_info.sep);
+ /* absolute sum */
+ sprintf(sum_str, "%.10f", stats[z].sum_abs);
+ fprintf(stdout, "%s", sum_str);
+ case CELL_TYPE:
+ else /* even */
+ median =
- else {
- /* percentile is not an exact integer */
- char buf[24], suffix[3];
- if (buf[strlen(buf)-1] == '1')
- strcpy(suffix, "st");
- else if (buf[strlen(buf)-1] == '2')
- strcpy(suffix, "nd");
- else if (buf[strlen(buf)-1] == '3')
- strcpy(suffix, "rd");
- else
- strcpy(suffix, "th");
- fprintf(stdout, "%.15g percentile: %g\n", stats->perc[i],
+ break;
+ case FCELL_TYPE:
+ else /* even */
+ median =
+ break;
+ case DCELL_TYPE:
+ else /* even */
+ median =
+ break;
+ default:
+ break;
+ /* first quartile */
+ fprintf(stdout, "%s%g", zone_info.sep, quartile_25);
+ /* median */
+ fprintf(stdout, "%s%g", zone_info.sep, median);
+ /* third quartile */
+ fprintf(stdout, "%s%g", zone_info.sep, quartile_75);
+ /* percentiles */
+ fprintf(stdout, "%s%g", zone_info.sep ,
- G_free((void *)quartile_perc);
- G_free((void *)qpos_perc);
+ /* zone z finished */
- G_message("\n");
return 1;
