[GRASS-SVN] r43827 -
	grass/branches/develbranch_6/scripts/g.extension
    svn_grass at osgeo.org
    Sat Oct  9 06:33:20 EDT 2010
Author: hamish
Date: 2010-10-09 10:33:20 +0000 (Sat, 09 Oct 2010)
New Revision: 43827
   grass/branches/develbranch_6/scripts/g.extension/g.extension
- wget needs output filename,
- don't list Makefiles,
- fix bashism string compare,
- note if GRASS_ADDON_PATH will be needed
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension	2010-10-08 13:01:36 UTC (rev 43826)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension	2010-10-09 10:33:20 UTC (rev 43827)
@@ -43,7 +43,7 @@
 #% key_desc: url
 #% description: SVN Addons repository URL
 #% required: yes
-#% answer: https://svn.osgeo.org/grass/grass-addons/
+#% answer: https://svn.osgeo.org/grass/grass-addons
 #%end
 #%option
 #% key: prefix
@@ -172,7 +172,7 @@
      cd "$TMPDIR"
      rm -f index.html
      if [ "$USE_WGET" ] ; then
-        wget --quiet -nv "$SVNURL_ADDONS/$MODCLASS"
+        wget --quiet -nv "$SVNURL_ADDONS/$MODCLASS" -O index.html
      else
         curl -silent --location "$SVNURL_ADDONS/$MODCLASS" -o index.html
      fi
@@ -180,7 +180,7 @@
         cut -d'"' -f2 | sed 's+/$++g' >> list_$$.txt
      rm -f index.html
  done
- cat list_$$.txt
+ grep -v 'Makefile' list_$$.txt
  rm -f list_$$.txt
  # so why save to a file at all instead of cat'ing directly?
@@ -204,14 +204,15 @@
 fi
-if [ "$PREFIX" == '$GRASS_ADDON_PATH' ] ; then
+if [ "$PREFIX" = '$GRASS_ADDON_PATH' ] ; then
     if [ -z "$GRASS_ADDON_PATH" ] ; then
-        g.message -w message="GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/"
-        #g.message message="Suggest you set GRASS_ADDON_PATH and GRASS_ADDON_ETC to ..."
-        ## will GRASS_ADDON_ETC help for man/ and docs/ ?
+	g.message -w message="GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/"
+	ADDON_PATH_EMPTY=true
+	#g.message message="Suggest you set GRASS_ADDON_PATH and GRASS_ADDON_ETC to ..."
+	## will GRASS_ADDON_ETC help for man/ and docs/ ?
 	## maybe have g.manual search in GRASS_ADDON_ETC/../ ?  :-/
-        mkdir -p ~/.grass6/addons
-        GRASS_ADDON_PATH=~/.grass6/addons
+	mkdir -p ~/.grass6/addons
+	GRASS_ADDON_PATH=~/.grass6/addons
     fi
     PREFIX="$GRASS_ADDON_PATH"
 elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] ; then
@@ -327,9 +328,15 @@
    fi
 fi
+#TODO: implement the $GIS_FLAG_S flag using sudo.
 cleanup
 g.message message=""
 g.message message="Installation of <$MODULE> in <$MYINST_DIR> successfully finished."
+if [ -n "$ADDON_PATH_EMPTY" ] && [ "$GIS_FLAG_S" -eq 0 ] ; then
+   g.message -w message='This add-on module will not function until you set the GRASS_ADDON_PATH environment variable (see "g.manual variables")'
+fi
 exit 0
