[GRASS-SVN] r43830 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Sat Oct 9 14:24:44 EDT 2010
Author: martinl
Date: 2010-10-09 18:24:44 +0000 (Sat, 09 Oct 2010)
New Revision: 43830
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/layertree.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: v.build.all added to the menu
fix running commands when module has no required parameter
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-10-09 18:20:48 UTC (rev 43829)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-10-09 18:24:44 UTC (rev 43830)
@@ -160,9 +160,9 @@
location = None, id = wx.ID_ANY):
ElementDialog.__init__(self, parent, title, label = _("Name of mapset:"))
if location:
- self.SetTitle(self.GetTitle() + '<%s>' % location)
+ self.SetTitle(self.GetTitle() + ' <%s>' % location)
else:
- self.SetTitle(self.GetTitle() + '<%s>' % grass.gisenv()['LOCATION_NAME'])
+ self.SetTitle(self.GetTitle() + ' <%s>' % grass.gisenv()['LOCATION_NAME'])
self.element = gselect.MapsetSelect(parent = self.panel, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-10-09 18:20:48 UTC (rev 43829)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-10-09 18:24:44 UTC (rev 43830)
@@ -443,7 +443,7 @@
except IOError, e:
self.WriteError(str(e))
fileHistory = None
cmdString = ' '.join(cmdlist)
if fileHistory:
try:
@@ -521,11 +521,18 @@
tmpreg = os.getenv("GRASS_REGION")
if os.environ.has_key("GRASS_REGION"):
del os.environ["GRASS_REGION"]
+ if len(cmdlist) == 1:
+ import menuform
+ task = menuform.GUI().ParseInterface(cmdlist)
+ if not task.has_required():
+ task = None # run command
+ else:
+ task = None
- if len(cmdlist) == 1 and cmdlist[0] not in ('v.krige'):
- import menuform
+ if task and cmdlist[0] not in ('v.krige'):
# process GRASS command without argument
- menuform.GUI().ParseCommand(cmdlist, parentframe=self)
+ menuform.GUI().ParseCommand(cmdlist, parentframe = self)
else:
# process GRASS command with argument
self.cmdThread.RunCmd(GrassCmd,
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2010-10-09 18:20:48 UTC (rev 43829)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2010-10-09 18:24:44 UTC (rev 43830)
@@ -255,6 +255,7 @@
self.popupID13 = wx.NewId()
self.popupID14 = wx.NewId()
self.popupID15 = wx.NewId()
+ self.popupID16 = wx.NewId()
self.popupMenu = wx.Menu()
@@ -324,10 +325,14 @@
internal=True) == layer.GetName():
self.popupMenu.Check(self.popupID14, True)
+ self.popupMenu.Append(self.popupID16, text=_("Rebuild topology"))
+ self.Bind(wx.EVT_MENU, self.OnTopology, id=self.popupID16)
if layer.GetMapset() != grass.gisenv()['MAPSET']:
# only vector map in current mapset can be edited
self.popupMenu.Enable (self.popupID5, False)
self.popupMenu.Enable (self.popupID6, False)
+ self.popupMenu.Enable (self.popupID16, False)
elif digitToolbar and digitToolbar.GetLayer():
# vector map already edited
vdigitLayer = digitToolbar.GetLayer()
@@ -340,6 +345,8 @@
self.popupMenu.Enable(self.popupID1, False)
# disable 'bgmap'
self.popupMenu.Enable(self.popupID14, False)
+ # disable 'topology'
else:
# disable 'start editing'
self.popupMenu.Enable(self.popupID5, False)
@@ -388,6 +395,13 @@
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
+ def OnTopology(self, event):
+ """!Rebuild topology of selected vector map"""
+ mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ cmd = ['v.build',
+ 'map=%s' % mapLayer.GetName()]
+ self.lmgr.goutput.RunCmd(cmd, switchPage = True)
def OnMetadata(self, event):
"""!Print metadata of raster/vector map layer
TODO: Dialog to modify metadata
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-09 18:20:48 UTC (rev 43829)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-09 18:24:44 UTC (rev 43830)
@@ -356,7 +356,7 @@
parser and use by the interface constructor.
Use as either grassTask() for empty definition or
- grassTask('grass.command' ) for parsed filling.
+ grassTask('grass.command') for parsed filling.
def __init__(self, grassModule = None):
self.path = grassModule
@@ -513,6 +513,14 @@
return { 'flags' : self.flags,
'params' : self.params }
+ def has_required(self):
+ """!Check if command has at least one required paramater"""
+ for p in self.params:
+ if p.get('required', False) == True:
+ return True
+ return False
class processTask:
"""!A ElementTree handler for the --interface-description output,
as defined in grass-interface.dtd. Extend or modify this and the
@@ -882,7 +890,7 @@
@param returncode command's return code (0 for success)
- if self.parent.GetName() != 'LayerTree' or \
+ if self.parent and self.parent.GetName() != 'LayerTree' or \
returncode != 0:
return
@@ -918,24 +926,23 @@
"""!Run the command"""
cmd = self.createCmd()
- if cmd == None or len(cmd) < 2:
+ if not cmd or len(cmd) < 1:
return
if self.standalone or cmd[0][0:2] != "d.":
# Send any non-display command to parent window (probably wxgui.py)
- # put to parents
- # switch to 'Command output'
+ # put to parents switch to 'Command output'
if self.notebookpanel.notebook.GetSelection() != self.notebookpanel.goutputId:
self.notebookpanel.notebook.SetSelection(self.notebookpanel.goutputId)
try:
if self.task.path:
cmd[0] = self.task.path # full path
self.goutput.RunCmd(cmd, onDone = self.OnDone)
except AttributeError, e:
print >> sys.stderr, "%s: Propably not running in wxgui.py session?" % (e)
print >> sys.stderr, "parent window is: %s" % (str(self.parent))
- # Send any other command to the shell.
else:
gcmd.Command(cmd)
@@ -945,8 +952,7 @@
self.btn_clipboard,
self.btn_help):
btn.Enable(False)
- ### self.btn_abort.Enable(True)
def OnAbort(self, event):
"""!Abort running command"""
event = goutput.wxCmdAbort(aborted=True)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-10-09 18:20:48 UTC (rev 43829)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-10-09 18:24:44 UTC (rev 43830)
@@ -1855,6 +1855,13 @@
<command>v.build</command>
</menuitem>
<menuitem>
+ <label>Rebuild topology on all vector maps</label>
+ <help>Rebuilds topology on all vector maps in the current mapset..</help>
+ <keywords>vector,topology</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>v.build.all</command>
+ </menuitem>
+ <menuitem>
<label>Clean vector map</label>
<help>Toolset for cleaning topology of vector map.</help>
