[GRASS-SVN] r43835 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 9 14:35:12 EDT 2010
Author: martinl
Date: 2010-10-09 18:35:12 +0000 (Sat, 09 Oct 2010)
New Revision: 43835
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: various minor changes
(merge r43832 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-10-09 18:33:44 UTC (rev 43834)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-10-09 18:35:12 UTC (rev 43835)
@@ -564,7 +564,7 @@
ps.stdin = None
stdout, stderr = ps.communicate()
ret = ps.returncode
if ret != 0 and parent:
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2010-10-09 18:33:44 UTC (rev 43834)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2010-10-09 18:35:12 UTC (rev 43835)
@@ -2732,8 +2732,7 @@
def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
- Set display extents to match selected raster
+ """!Set display extents to match selected raster
or vector map(s).
@param layer list of layers to be zoom to
@@ -2754,7 +2753,7 @@
for l in layers:
# only raster/vector layers are currently supported
if l.type == 'raster':
- rast.append(l.name)
+ rast.append(l.GetName())
elif l.type == 'vector':
digitToolbar = self.parent.toolbars['vdigit']
if digitToolbar and digitToolbar.GetLayer() == l:
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2010-10-09 18:33:44 UTC (rev 43834)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2010-10-09 18:35:12 UTC (rev 43835)
@@ -61,7 +61,7 @@
def __init__(self, type, cmd, name=None,
active=True, hidden=False, opacity=1.0):
@todo pass cmd as tuple instead of list
@param type layer type ('raster', 'vector', 'overlay', 'command', etc.)
@@ -80,7 +80,7 @@
for c in cmd:
self.cmd.append(utils.CmdToTuple(c))
else:
- self.cmd = utils.CmdToTuple(cmd)
+ self.cmd = utils.CmdToTuple(cmd)
self.active = active
self.hidden = hidden
@@ -936,7 +936,6 @@
# l_opacity must be <0;1>
if l_opacity < 0: l_opacity = 0
elif l_opacity > 1: l_opacity = 1
layer = MapLayer(type=type, name=name, cmd=command,
active=l_active, hidden=l_hidden, opacity=l_opacity)
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2010-10-09 18:33:44 UTC (rev 43834)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2010-10-09 18:35:12 UTC (rev 43835)
@@ -62,8 +62,8 @@
except:
return None
-def GetLayerNameFromCmd(dcmd, fullyQualified=False, param=None,
- layerType=None):
+def GetLayerNameFromCmd(dcmd, fullyQualified = False, param = None,
+ layerType = None):
"""!Get map name from GRASS command
@param dcmd GRASS command (given as list)
@@ -87,7 +87,7 @@
elif 'd.rhumbline' in dcmd[0]:
mapname = 'rhumb'
elif 'labels=' in dcmd[0]:
- mapname = dcmd[idx].split('=')[1]+' labels'
+ mapname = dcmd[idx].split('=')[1] + ' labels'
else:
params = list()
for idx in range(len(dcmd)):
@@ -107,8 +107,11 @@
params.append((idx, p, v))
if len(params) < 1:
- return mapname
+ if len(dcmd) > 1 and '=' not in dcmd[1]:
+ params.append((1, None, dcmd[1]))
+ else:
+ return mapname
mapname = params[0][2]
mapset = ''
if fullyQualified and '@' not in mapname:
@@ -133,7 +136,7 @@
if p == 'layer':
continue
dcmd[i] = p + '=' + v + '@' + mapset
maps = list()
ogr = False
for i, p, v in params:
@@ -142,6 +145,7 @@
if p == 'layer' and not ogr:
continue
maps.append(dcmd[i].split('=', 1)[1])
mapname = '\n'.join(maps)
return mapname
