[GRASS-SVN] r43865 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Mon Oct 11 12:27:15 EDT 2010
Author: martinl
Date: 2010-10-11 09:27:14 -0700 (Mon, 11 Oct 2010)
New Revision: 43865
grass/trunk/raster/r.colors/main.c
r.colors: flag for printing color table (-p) added
(merge r43863 from devbr6)
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c 2010-10-11 16:26:45 UTC (rev 43864)
+++ grass/trunk/raster/r.colors/main.c 2010-10-11 16:27:14 UTC (rev 43865)
@@ -4,6 +4,7 @@
* AUTHOR(S): Michael Shapiro - CERL
* David Johnson
+ * Print color table by Martin Landa <landa.martin gmail.com>
* PURPOSE: Allows creation and/or modification of the color table
* for a raster map layer.
@@ -130,7 +131,7 @@
int overwrite;
int is_from_stdin;
- int remove;
+ int remove, print;
int have_colors;
struct Colors colors, colors_tmp;
struct Cell_stats statf;
@@ -144,7 +145,7 @@
struct GModule *module;
struct
- struct Flag *r, *w, *l, *g, *a, *e, *n;
+ struct Flag *r, *w, *l, *g, *a, *e, *n, *p;
} flag;
struct
@@ -226,6 +227,10 @@
flag.e->description = _("Histogram equalization");
flag.e->guisection = _("Define");
+ flag.p = G_define_flag();
+ flag.p->key = 'p';
+ flag.p->description = _("Print current color table and exit");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -236,7 +241,8 @@
overwrite = !flag.w->answer;
remove = flag.r->answer;
+ print = flag.p->answer;
name = opt.map->answer;
style = opt.colr->answer;
cmap = opt.rast->answer;
@@ -244,10 +250,10 @@
if (!name)
G_fatal_error(_("No raster map specified"));
+ if (!cmap && !style && !rules && !remove && !print)
+ G_fatal_error(_("One of \"-r\", \"-p\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
- if (!cmap && !style && !rules && !remove)
- G_fatal_error(_("One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
if (!!style + !!cmap + !!rules > 1)
G_fatal_error(_("\"color\", \"rules\", and \"raster\" options are mutually exclusive"));
@@ -262,6 +268,11 @@
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), name);
+ if (print) {
+ Rast_print_colors(name, mapset, stdout);
+ return EXIT_SUCCESS;
if (remove) {
int stat = Rast_remove_colors(name, mapset);
@@ -274,9 +285,11 @@
G_suppress_warnings(1);
have_colors = Rast_read_colors(name, mapset, &colors);
- /*if (have_colors >= 0)
- Rast_free_colors(&colors); */
+ if (have_colors >= 0)
+ Rast_free_colors(&colors);
if (have_colors > 0 && !overwrite)
exit(EXIT_SUCCESS);
