[GRASS-SVN] r43880 - in grass/branches/releasebranch_6_4/display:
d.rast d.rgb d.vect
svn_grass at osgeo.org
Tue Oct 12 08:13:33 EDT 2010
Author: martinl
Date: 2010-10-12 05:13:28 -0700 (Tue, 12 Oct 2010)
New Revision: 43880
grass/branches/releasebranch_6_4/display/d.rast/main.c
grass/branches/releasebranch_6_4/display/d.rgb/main.c
grass/branches/releasebranch_6_4/display/d.vect/main.c
sync d.rast/d.vect/d.rgb descriptions
(merge r43879 from devbr6)
Modified: grass/branches/releasebranch_6_4/display/d.rast/main.c
--- grass/branches/releasebranch_6_4/display/d.rast/main.c 2010-10-12 12:11:34 UTC (rev 43879)
+++ grass/branches/releasebranch_6_4/display/d.rast/main.c 2010-10-12 12:13:28 UTC (rev 43880)
@@ -49,10 +49,9 @@
module = G_define_module();
module->keywords = _("display, raster");
- module->description =
- _("Displays and overlays raster map layers "
- "in the active display frame on the graphics monitor.");
+ module->description = _("Displays user-specified raster map in the active "
+ "graphics frame.");
/* set up command line */
map = G_define_standard_option(G_OPT_R_MAP);
map->description = _("Raster map to be displayed");
Modified: grass/branches/releasebranch_6_4/display/d.rgb/main.c
--- grass/branches/releasebranch_6_4/display/d.rgb/main.c 2010-10-12 12:11:34 UTC (rev 43879)
+++ grass/branches/releasebranch_6_4/display/d.rgb/main.c 2010-10-12 12:13:28 UTC (rev 43880)
@@ -1,4 +1,3 @@
* MODULE: d.rgb
@@ -8,9 +7,9 @@
* Hamish Bowman <hamish_nospam yahoo.com>,
* Markus Neteler <neteler itc.it>,
* Radim Blazek <radim.blazek gmail.com>
- * PURPOSE: combine three rasters to form a colour image using red, green,
+ * PURPOSE: Combine three rasters to form a colour image using red, green,
* and blue display channels
- * COPYRIGHT: (C) 2001-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2007, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -52,15 +51,15 @@
G_gisinit(argv[0]);
- module->keywords = _("display");
+ module->keywords = _("display, raster, RGB");
- _("Displays three user-specified raster map layers "
+ _("Displays three user-specified raster maps "
"as red, green, and blue overlays in the active graphics frame.");
flag_o = G_define_flag();
flag_o->key = 'o';
flag_o->description = _("Overlay (non-null values only)");
flag_x = G_define_flag();
flag_x->key = 'x';
flag_x->description = _("Don't add to list of commands in monitor");
@@ -68,17 +67,12 @@
for (i = 0; i < 3; i++) {
char buff[80];
- sprintf(buff, _("Name of raster map to be used for <%s>"),
+ sprintf(buff, _("Name of raster map to be used for '%s'"),
color_names[i]);
- B[i].opt = G_define_option();
+ B[i].opt = G_define_standard_option(G_OPT_R_MAP);
B[i].opt->key = G_store(color_names[i]);
- B[i].opt->type = TYPE_STRING;
- B[i].opt->answer = NULL;
- B[i].opt->required = YES;
- B[i].opt->gisprompt = "old,cell,raster";
B[i].opt->description = G_store(buff);
- B[i].opt->key_desc = "name";
if (G_parser(argc, argv))
@@ -87,7 +81,7 @@
/* Do screen initializing stuff */
if (R_open_driver() != 0)
G_fatal_error(_("No graphics device selected"));
D_get_screen_window(&t, &b, &l, &r);
D_set_overlay_mode(flag_o->answer);
D_cell_draw_setup(t, b, l, r);
Modified: grass/branches/releasebranch_6_4/display/d.vect/main.c
--- grass/branches/releasebranch_6_4/display/d.vect/main.c 2010-10-12 12:11:34 UTC (rev 43879)
+++ grass/branches/releasebranch_6_4/display/d.vect/main.c 2010-10-12 12:13:28 UTC (rev 43880)
@@ -122,10 +122,9 @@
module->keywords = _("display, vector");
- _("Displays vector data in the active "
- "frame on the graphics monitor.");
+ module->description = _("Displays user-specified vector map "
+ "in the active graphics frame.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
display_opt = G_define_option();
