[GRASS-SVN] r43882 - grass/branches/develbranch_6/lib/vector/dglib
svn_grass at osgeo.org
Tue Oct 12 10:51:29 EDT 2010
Author: mmetz
Date: 2010-10-12 07:51:29 -0700 (Tue, 12 Oct 2010)
New Revision: 43882
grass/branches/develbranch_6/lib/vector/dglib/sp-template.c
update comment (backport from trunk r43881)
Modified: grass/branches/develbranch_6/lib/vector/dglib/sp-template.c
--- grass/branches/develbranch_6/lib/vector/dglib/sp-template.c 2010-10-12 14:50:26 UTC (rev 43881)
+++ grass/branches/develbranch_6/lib/vector/dglib/sp-template.c 2010-10-12 14:51:29 UTC (rev 43882)
@@ -25,15 +25,20 @@
* SHORTEST PATH CACHE
* components:
+ * - start node id
* - visited network: a node is marked as visited when its departing
* edges have been added to the cache
* - predist network: node distances from start node
* - NodeHeap: holds unvisited nodes, the next node extracted is the
- * one closest to SP start
+ * unvisited node closest to SP start
- * not all nodes in the cache have been visited, but distances from
- * SP start are known for all nodes in the cache
+ * not all nodes in the predist network have been visited, SP from start
+ * is known only for visited nodes
+ * unvisited nodes can be reached, but not necessarily on the shortest
+ * possible path
+ * important for DGL_SP_CACHE_DISTANCE_FUNC and DGL_SP_CACHE_REPORT_FUNC
#if !defined(DGL_DEFINE_TREE_PROCS) && !defined(DGL_DEFINE_FLAT_PROCS)
int DGL_SP_CACHE_INITIALIZE_FUNC(dglGraph_s * pgraph, dglSPCache_s * pCache,
