[GRASS-SVN] r43892 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 13 14:58:47 EDT 2010
Author: martinl
Date: 2010-10-13 11:58:47 -0700 (Wed, 13 Oct 2010)
New Revision: 43892
grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
wxGUI: avoid gettext warnings
(merge r43891 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmanager.py 2010-10-13 18:55:11 UTC (rev 43891)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmanager.py 2010-10-13 18:58:47 UTC (rev 43892)
@@ -1108,11 +1108,15 @@
else:
currloc = _("target")
ret = wx.MessageBox(parent=self,
- caption=_("Set GCP coordinates"),
- message=_('Set %s coordinates for GCP No. %s? \n\n'
- 'East: %s \n'
- 'North: %s') % (currloc, str(key), str(coord0), str(coord1)),
- style=wx.ICON_QUESTION | wx.YES_NO | wx.CENTRE)
+ caption=_("Set GCP coordinates"),
+ message=_('Set %(coor)s coordinates for GCP No. %(key)s? \n\n'
+ 'East: %(coor0)s \n'
+ 'North: %(coor1)s') % \
+ { 'coor' : currloc,
+ 'key' : str(key),
+ 'coor0' : str(coord0),
+ 'coor1' : str(coord1) },
+ style=wx.ICON_QUESTION | wx.YES_NO | wx.CENTRE)
# for wingrass
if os.name == 'nt':
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2010-10-13 18:55:11 UTC (rev 43891)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2010-10-13 18:58:47 UTC (rev 43892)
@@ -846,8 +846,9 @@
self.StatusbarEnableLongHelp(False)
elif self.statusbarWin['toggle'].GetSelection() == 8: # RMS error
- self.statusbar.SetStatusText(_("Forward: %s, Backward: %s") %
- (self.fwd_rmserror, self.bkw_rmserror))
+ self.statusbar.SetStatusText(_("Forward: %(forw)s, Backward: %(back)s") %
+ { 'forw' : self.fwd_rmserror,
+ 'back' : self.bkw_rmserror })
# disable long help
# self.StatusbarEnableLongHelp(False)
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-10-13 18:55:11 UTC (rev 43891)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-10-13 18:58:47 UTC (rev 43892)
@@ -819,8 +819,9 @@
self.modelFile = filename
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile))
- self.SetStatusText(_('%d items (%d actions) loaded into model') % \
- (self.model.GetNumItems(), self.model.GetNumItems(actionOnly = True)), 0)
+ self.SetStatusText(_('%(items)d items (%(actions)d actions) loaded into model') % \
+ { 'items' : self.model.GetNumItems(),
+ 'actions' : self.model.GetNumItems(actionOnly = True) }, 0)
def OnModelSave(self, event = None):
"""!Save model to file"""
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-13 18:55:11 UTC (rev 43891)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-10-13 18:58:47 UTC (rev 43892)
@@ -2121,7 +2121,9 @@
element = self.grass_task.get_param(key, raiseError = False)
if not element:
- err.append(_("%s: parameter '%s' not available") % (cmd[0], key))
+ err.append(_("%(cmd)s: parameter '%(key)s' not available") % \
+ { 'cmd' : cmd[0],
+ 'key' : key })
continue
element = element['element']
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-10-13 18:55:11 UTC (rev 43891)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-10-13 18:58:47 UTC (rev 43892)
@@ -893,14 +893,14 @@
try:
dict[group][key][subkey[0]][subkey[1]] = value
except TypeError:
- print >> sys.stderr, _("Unable to parse settings '%s' (%s:%s:%s:%s)") % \
- (value, group, key, subkey[0], subkey[1])
+ print >> sys.stderr, _("Unable to parse settings '%s'") % value + \
+ ' (' + group + ':' + key + ':' + subkey[0] + ':' + subkey[1] + ')'
else:
try:
dict[group][key][subkey] = value
except TypeError:
- print >> sys.stderr, _("Unable to parse settings '%s' (%s:%s:%s)") % \
- (value, group, key, subkey)
+ ' (' + group + ':' + key + ':' + subkey + ')'
def GetDefaultSettings(self):
"""!Get default user settings"""
@@ -2171,13 +2171,12 @@
sizer = wx.BoxSizer(wx.VERTICAL)
label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_("Check a mapset to make it accessible, uncheck it to hide it.%s"
- " Notes:%s"
- " - The current mapset is always accessible.%s"
- " - You may only write to the current mapset.%s"
- " - You may only write to mapsets which you own.") %
- (os.linesep, os.linesep, os.linesep, os.linesep))
+ label=_("Check a mapset to make it accessible, uncheck it to hide it.\n"
+ " Notes:\n"
+ " - The current mapset is always accessible.\n"
+ " - You may only write to the current mapset.\n"
+ " - You may only write to mapsets which you own."))
sizer.Add(item=label, proportion=0,
flag=wx.ALL, border=5)
