[GRASS-SVN] r43894 - grass/branches/develbranch_6/imagery/i.atcorr
svn_grass at osgeo.org
Wed Oct 13 15:32:57 EDT 2010
Author: martinl
Date: 2010-10-13 12:32:56 -0700 (Wed, 13 Oct 2010)
New Revision: 43894
grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
i.atcorr: cosmetics in descriptions
Modified: grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
--- grass/branches/develbranch_6/imagery/i.atcorr/main.cpp 2010-10-13 19:24:34 UTC (rev 43893)
+++ grass/branches/develbranch_6/imagery/i.atcorr/main.cpp 2010-10-13 19:32:56 UTC (rev 43894)
@@ -76,14 +76,14 @@
int mis = 0;
/* function prototypes */
-static void adjust_region (char *, const char *);
-static CELL round_c (FCELL);
-static void write_fp_to_cell (int, FCELL *);
-static void process_raster (int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
-static void copy_colors (char *, const char *, char *);
-static void define_module (void);
-static struct Options define_options (void);
-static void read_scale (Option *, ScaleRange &);
+static void adjust_region(char *, const char *);
+static CELL round_c(FCELL);
+static void write_fp_to_cell(int, FCELL *);
+static void process_raster(int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
+static void copy_colors(char *, const char *, char *);
+static void define_module(void);
+static struct Options define_options(void);
+static void read_scale(Option *, ScaleRange &);
@@ -91,7 +91,7 @@
Atmospheric corrections should be done on the whole
satelite image, not just portions.
-static void adjust_region (char *name, const char *mapset)
+static void adjust_region(char *name, const char *mapset)
struct Cell_head iimg_head; /* the input image header file */
@@ -105,9 +105,9 @@
/* Rounds a floating point cell value */
-static CELL round_c (FCELL x)
+static CELL round_c(FCELL x)
- if (x >= 0.0)
+ if(x >= 0.0)
return (CELL)(x + .5);
return (CELL)(-(-x + .5));
@@ -115,7 +115,7 @@
/* Converts the buffer to cell and write it to disk */
-static void write_fp_to_cell (int ofd, FCELL* buf)
+static void write_fp_to_cell(int ofd, FCELL* buf)
CELL* cbuf;
int col;
@@ -237,7 +237,7 @@
typedef std::map<IntPair, TransformInput> CacheMap;
-const TransformInput& optimize_va (const FCELL& vis, const FCELL& alt)
+const TransformInput& optimize_va(const FCELL& vis, const FCELL& alt)
static CacheMap timap;
static TransformInput ti;
@@ -274,7 +274,7 @@
oflt: if true use FCELL_TYPE for output
oscale: output file's range (default is min = 0, max = 255)
-static void process_raster (int ifd, InputMask imask, ScaleRange iscale,
+static void process_raster(int ifd, InputMask imask, ScaleRange iscale,
int ialt_fd, int ivis_fd, int ofd, bool oflt,
ScaleRange oscale, bool optimize)
@@ -400,7 +400,7 @@
buf[col] = buf[col] * ((float)oscale.max - (float)oscale.min) + oscale.min;
if(~oflt && (buf[col] > (float)oscale.max))
- G_warning (_("The output data will overflow. Reflectance > 100%%"));
+ G_warning(_("The output data will overflow. Reflectance > 100%%"));
/* write output */
@@ -417,7 +417,7 @@
/* Copy the colors from map named iname to the map named oname */
-static void copy_colors (char *iname, const char *imapset, char *oname)
+static void copy_colors(char *iname, const char *imapset, char *oname)
struct Colors colors;
@@ -427,7 +427,7 @@
/* Define our module so that Grass can print it if the user wants to know more. */
struct GModule *module;
@@ -457,42 +457,41 @@
/* Define the options and flags */
struct Options opts;
- opts.iimg = G_define_standard_option (G_OPT_R_INPUT);
- opts.iimg->key = "iimg";
+ opts.iimg = G_define_standard_option(G_OPT_R_INPUT);
+ opts.iimg->key = "iimg";
opts.iscl = G_define_option();
opts.iscl->key = "iscl";
opts.iscl->type = TYPE_INTEGER;
opts.iscl->key_desc = "min,max";
opts.iscl->required = NO;
opts.iscl->answer = "0,255";
- opts.iscl->description = _("Input imagery range [0,255]");
+ opts.iscl->description = _("Input range");
opts.iscl->guisection = _("Input");
- opts.ialt = G_define_standard_option (G_OPT_R_INPUT);
- opts.ialt->key = "ialt";
+ opts.ialt = G_define_standard_option(G_OPT_R_ELEV);
opts.ialt->required = NO;
- opts.ialt->answer = "dem_float";
- opts.ialt->description = _("Input altitude raster map in m (optional)");
+ opts.ialt->description = _("Name of input elevation raster map (in m)");
opts.ialt->guisection = _("Input");
- opts.ivis = G_define_standard_option (G_OPT_R_INPUT);
+ opts.ialt->key = "ialt";
+ opts.ivis = G_define_standard_option(G_OPT_R_INPUT);
opts.ivis->key = "ivis";
opts.ivis->required = NO;
- opts.ivis->description = _("Input visibility raster map in km (optional)");
+ opts.ivis->description = _("Name of input visibility raster map (in km)");
opts.ivis->guisection = _("Input");
- opts.icnd = G_define_standard_option (G_OPT_F_INPUT);
+ opts.icnd = G_define_standard_option(G_OPT_F_INPUT);
opts.icnd->key = "icnd";
opts.icnd->required = YES;
opts.icnd->description = _("Name of input text file");
- opts.oimg = G_define_standard_option (G_OPT_R_OUTPUT);
- opts.oimg->key = "oimg";
+ opts.oimg = G_define_standard_option(G_OPT_R_OUTPUT);
+ opts.oimg->key = "oimg";
opts.oscl = G_define_option();
opts.oscl->key = "oscl";
@@ -500,17 +499,17 @@
opts.oscl->key_desc = "min,max";
opts.oscl->answer = "0,255";
opts.oscl->required = NO;
- opts.oscl->description = _("Rescale output raster map [0,255]");
+ opts.oscl->description = _("Rescale output raster map");
opts.oscl->guisection = _("Output");
opts.oflt = G_define_flag();
opts.oflt->key = 'f';
- opts.oflt->description = _("Output raster is floating point");
+ opts.oflt->description = _("Output raster map as floating point");
opts.oflt->guisection = _("Output");
opts.irad = G_define_flag();
opts.irad->key = 'r';
- opts.irad->description = _("Input map converted to reflectance (default is radiance)");
+ opts.irad->description = _("Input raster map converted to reflectance (default is radiance)");
opts.irad->guisection = _("Input");
opts.etmafter = G_define_flag();
@@ -531,7 +530,7 @@
/* Read the min and max values from the iscl and oscl options */
-void read_scale (Option *scl, ScaleRange &range)
+void read_scale(Option *scl, ScaleRange &range)
/* set default values */
range.min = 0;
@@ -544,7 +543,7 @@
if(range.min==range.max)
- G_warning (_("Scale range length should be > 0; Using default values: [0,255]"));
+ G_warning(_("Scale range length should be > 0; Using default values: [0,255]"));
range.min = 0;
range.max = 255;
@@ -582,14 +581,14 @@
/**** Start ****/
G_gisinit(argv[0]);
- if (G_parser(argc, argv) < 0)
- exit (EXIT_FAILURE);
+ if(G_parser(argc, argv) < 0)
+ exit(EXIT_FAILURE);
/* open input raster */
if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
- G_fatal_error (_("Unable to open raster map <%s>"),
+ G_fatal_error(_("Unable to open raster map <%s>"),
G_fully_qualified_name(opts.iimg->answer, iimg_mapset));
adjust_region(opts.iimg->answer, iimg_mapset);
@@ -598,7 +597,7 @@
if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
G_fatal_error ( _("Raster map <%s> not found"), opts.ialt->answer);
if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
G_fully_qualified_name(opts.ialt->answer, ialt_mapset));
@@ -606,7 +605,7 @@
if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
G_fully_qualified_name(opts.ivis->answer, iviz_mapset));
@@ -614,13 +613,13 @@
if(opts.oflt->answer)
if((oimg_fd = G_open_fp_cell_new(opts.oimg->answer)) < 0)
- G_fatal_error (_("Unable to create raster map <%s>"),
+ G_fatal_error(_("Unable to create raster map <%s>"),
opts.oimg->answer);
else
if((oimg_fd = G_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
opts.oimg->answer);
@@ -657,5 +656,5 @@
Scaling is ignored and color ranges might not be correct. */
copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
- exit (EXIT_SUCCESS);
+ exit(EXIT_SUCCESS);
