[GRASS-SVN] r43905 - in grass/trunk: . include/Make lib/proj
Thu Oct 14 05:43:38 EDT 2010
Author: glynn
Date: 2010-10-14 02:43:38 -0700 (Thu, 14 Oct 2010)
New Revision: 43905
   grass/trunk/Makefile
   grass/trunk/include/Make/Docs.make
   grass/trunk/include/Make/Install.make
   grass/trunk/lib/proj/Makefile
Build system clean-up, mainly installation
Modified: grass/trunk/Makefile
--- grass/trunk/Makefile	2010-10-14 07:59:19 UTC (rev 43904)
+++ grass/trunk/Makefile	2010-10-14 09:43:38 UTC (rev 43905)
@@ -126,7 +126,6 @@
 include $(MODULE_TOPDIR)/include/Make/Install.make
 include $(MODULE_TOPDIR)/include/Make/Docs.make
-include $(MODULE_TOPDIR)/include/Make/Doxygen.make
 .PHONY: default libs
 .PHONY: cleandistdirs cleanscriptstrings clean libsclean distclean
Modified: grass/trunk/include/Make/Docs.make
--- grass/trunk/include/Make/Docs.make	2010-10-14 07:59:19 UTC (rev 43904)
+++ grass/trunk/include/Make/Docs.make	2010-10-14 09:43:38 UTC (rev 43905)
@@ -28,8 +28,7 @@
 	lib/vector \
 	lib/vector/dglib \
 	gui/wxpython \
-	rfc \
-	swig
+	rfc
 htmldocs_dirs := $(patsubst %,%/html,$(docs_dirs))
 latexdocs_dirs := $(patsubst %,%/latex,$(docs_dirs))
Modified: grass/trunk/include/Make/Install.make
--- grass/trunk/include/Make/Install.make	2010-10-14 07:59:19 UTC (rev 43904)
+++ grass/trunk/include/Make/Install.make	2010-10-14 09:43:38 UTC (rev 43905)
@@ -17,112 +17,145 @@
 # Shell commands
 MAKE_DIR_CMD	= $(MKDIR) -m 755
-strip:
-	@ if [ ! -f $(ARCH_BINDIR)/$(GRASS_NAME) ] ; then \
-		echo "ERROR: GRASS has not been compiled. Try \"make\" first."; \
-		echo "  Strip aborted, exiting Make."; \
-		exit; \
-	fi; \
-	cd $(ARCH_DISTDIR) ; find . -type f -perm +111 -exec strip {} \;
+strip: strip-check
+	find $(ARCH_DISTDIR) -type f -perm +111 -print0 | xargs -0 strip
+strip-check:
+	@ if [ ! -f "$(ARCH_BINDIR)/$(GRASS_NAME)" ] ; then \
+		echo "ERROR: GRASS has not been compiled. Try \"make\" first." >&2 ; \
+		echo "  Strip aborted, exiting Make." >&2 ; \
+		exit 1; \
+	fi
 install:
-	@ # The following action MUST be a single action. That is, all lines
-	@ # except the last line must have a backslash (\) at the end to
-	@ # continue the statement. The reason for this is that Make does not
-	@ # have an exit command thus, exit terminates the shell. However,
-	@ # Make creates a new shell for each action listed for a target.
-	@ # Therefore, the only way exit will quit Make is if there is only
-	@ # a single action for the target.
-	@ # Check if grass has been compiled, if INST_DIR is writable, and if
-	@ # grass is part of INST_DIR
-	echo $(ARCH_BINDIR)/$(GRASS_NAME)
+	@ echo $(ARCH_BINDIR)/$(GRASS_NAME)
+	$(MAKE) install-check-built
+ifeq ($(strip $(MACOSX_APP)),1)
+	$(MAKE) install-macosx
+else
+	$(MAKE) install-check-parent
+	$(MAKE) install-check-writable
+	$(MAKE) install-check-prefix
+	$(MAKE) real-install
+endif
+install-check-built:
 		echo "  Installation aborted, exiting Make."; \
 		exit; \
-	fi; \
-	if [ "$(MACOSX_APP)" = "1" ] ; then \
-		$(MAKE) install-macosx; \
-		exit; \
-	fi; \
-	INST_PATH=`dirname $(INST_DIR)`; \
-	while [ ! -d $$INST_PATH ]; do \
+	fi
+install-check-parent:
+	@ INST_PATH=`dirname $(INST_DIR)`; \
+	while [ ! -d "$$INST_PATH" ]; do \
 		INST_PATH=`dirname $$INST_PATH`; \
 	done; \
 	if [ ! -d "$(INST_DIR)" -a ! -w "$$INST_PATH" ] ; then \
-		echo "ERROR: Directory $$INST_PATH is a parent directory of your"; \
-		echo "  install directory $(INST_DIR) and is not writable."; \
-		echo "  Perhaps you need root access."; \
-		echo "  Installation aborted, exiting Make."; \
-		exit; \
-	fi; \
-	if [ -d $(INST_DIR) -a ! -w "$(INST_DIR)" ] ; then \
-		echo "ERROR: Your install directory $(INST_DIR) is not writable."; \
-		exit; \
-	fi; \
-	result=`echo "$(INST_DIR)" | awk '{ if ($$1 ~ /grass/) print $$1 }'`; \
+		echo "ERROR: Directory $$INST_PATH is a parent directory of your" >&2 ; \
+		echo "  install directory $(INST_DIR) and is not writable." >&2 ; \
+		echo "  Perhaps you need root access." >&2 ; \
+		echo "  Installation aborted, exiting Make." >&2 ; \
+		exit 1; \
+	fi
+install-check-writable:
+	@ if [ -d "$(INST_DIR)" -a ! -w "$(INST_DIR)" ] ; then \
+		echo "ERROR: Your install directory $(INST_DIR) is not writable." >&2 ; \
+		exit 1; \
+	fi
+install-check-prefix:
+	@ result=`echo "$(INST_DIR)" | awk '{ if ($$1 ~ /grass/) print $$1 }'`; \
 	if [ "$$result" = "" ] ; then \
-		echo "WARNING: Your install directory $(INST_DIR)"; \
-		echo "  does not contain the word 'grass'."; \
-		echo "  It is highly recommended that the word 'grass' be part"; \
-		echo "  of your install directory to avoid conflicts."; \
-		echo "  Do you want to continue? [y/n]"; \
+		echo "WARNING: Your install directory $(INST_DIR)" >&2 ; \
+		echo "  does not contain the word 'grass'." >&2 ; \
+		echo "  It is highly recommended that the word 'grass' be part" >&2 ; \
+		echo "  of your install directory to avoid conflicts." >&2 ; \
+		echo "  Do you want to continue? [y/n]" >&2 ; \
 		read ans; \
-		ans=`echo "$$ans" | tr A-Z a-z`; \
-		if [ "$$ans" != "y" ] ; then \
-			echo "Installation aborted, exiting Make."; \
-			exit; \
+		if [ "$$ans" != "y" -a "$$ans" != "Y" ] ; then \
+			echo "Installation aborted, exiting Make." >&2 ; \
+			exit 1; \
 		fi; \
-	fi; \
-	$(MAKE) real-install
+	fi
-real-install:
-	test -d $(INST_DIR) || $(MAKE_DIR_CMD) $(INST_DIR)
-	test -d $(UNIX_BIN) || $(MAKE_DIR_CMD) $(UNIX_BIN)
 ifneq ($(strip $(MINGW)),)
-	-sed -e 's#'@GISBASE@'#'$(INST_DIR)'#g' \
-	     -e 's#'@LD_LIBRARY_PATH_VAR@'#'$(LD_LIBRARY_PATH_VAR)'#g' \
-	     -e 's#'@CONFIG_PROJSHARE@'#'$(PROJSHARE)'#g' \
-	     $(ARCH_DISTDIR)/$(GRASS_NAME).tmp > $(UNIX_BIN)/$(GRASS_NAME).py
-	-chmod a+x $(UNIX_BIN)/$(GRASS_NAME).py
+STARTUP = $(UNIX_BIN)/$(GRASS_NAME).py
 else
 endif
+FONTCAP = etc/fontcap
+TMPGISRC = demolocation/.grassrc$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)
+PLATMAKE = include/Make/Platform.make
+real-install: | $(INST_DIR) $(UNIX_BIN)
+	$(MAKE) $(STARTUP)
 	-tar cBCf $(GISBASE) - . | tar xBCf $(INST_DIR) - 2>/dev/null
 	-rm $(INST_DIR)/$(GRASS_NAME).tmp
-	-sed 's#'$(GISBASE)'#'$(INST_DIR)'#g' $(GISBASE)/etc/fontcap > $(INST_DIR)/etc/fontcap
+	-rm $(INST_DIR)/$(FONTCAP)
+	$(MAKE) $(INST_DIR)/$(FONTCAP)
+	-rm $(INST_DIR)/$(TMPGISRC)
+	$(MAKE) $(INST_DIR)/$(TMPGISRC)
+	-rm $(INST_DIR)/$(PLATMAKE)
+	$(MAKE) $(INST_DIR)/$(PLATMAKE)
 	-$(INSTALL) config.status $(INST_DIR)/config.status
-	-chmod -R a+rX $(INST_DIR) 2>/dev/null
+	-$(CHMOD) -R a+rX $(INST_DIR) 2>/dev/null
+ifneq ($(findstring darwin,$(ARCH)),)
 	@# enable OSX Help Viewer
-	@if [ "`grep -i '^ARCH.*darwin' < include/Make/Platform.make`" ] ; then /bin/ln -sfh "$(INST_DIR)/docs/html" /Library/Documentation/Help/GRASS-$(GRASS_VERSION_MAJOR).$(GRASS_VERSION_MINOR) ; fi
+	@/bin/ln -sfh "$(INST_DIR)/docs/html" /Library/Documentation/Help/GRASS-$(GRASS_VERSION_MAJOR).$(GRASS_VERSION_MINOR)
+endif
+$(INST_DIR) $(UNIX_BIN):
+	$(MAKE_DIR_CMD) $@
+$(STARTUP): $(ARCH_DISTDIR)/$(GRASS_NAME).tmp
+	sed -e 's#'@GISBASE@'#'$(INST_DIR)'#g' \
+	    -e 's#'@LD_LIBRARY_PATH_VAR@'#'$(LD_LIBRARY_PATH_VAR)'#g' \
+	    -e 's#'@CONFIG_PROJSHARE@'#'$(PROJSHARE)'#g' \
+	-$(CHMOD) a+x $@
+define fix_gisbase
+sed -e 's#$(GISBASE)#$(INST_DIR)#g' $< > $@
+endef
+$(INST_DIR)/$(FONTCAP): $(GISBASE)/$(FONTCAP)
+	$(call fix_gisbase)
+$(INST_DIR)/$(TMPGISRC): $(GISBASE)/$(TMPGISRC)
+$(INST_DIR)/$(PLATMAKE): $(GISBASE)/$(PLATMAKE)
+install-macosx:
+	$(MAKE) -C macosx install-macosx
 install-strip:
 	$(MAKE) strip
 	$(MAKE) install
-install-macosx:
-	$(MAKE) -C macosx install-macosx
 bindist:
-		$(MAKE) bindist-macosx; \
-		exit; \
-	fi; \
+	$(MAKE) bindist-macosx
+else
 	$(MAKE) real-bindist
+endif
+BINDISTNAME = grass-$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE)
 real-bindist:
-	mkdir -p $(ARCH_DISTDIR)/etc/nad/src ; \
-	    cp -f $(MODULE_TOPDIR)/lib/proj/*.lla $(ARCH_DISTDIR)/etc/nad/src ; true
-	-cd $(ARCH_DISTDIR); tar cBf - $(BIN_DIST_FILES) | gzip -fc > ../grass-$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE).tar.gz
-	-name=grass-$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE).tar.gz; \
-	    size=`ls -l $$name | awk '{print $$5}'`; \
+	-tar cCBf $(ARCH_DISTDIR) - $(BIN_DIST_FILES) | gzip -fc > $(BINDISTNAME).tar.gz
+	-size=`ls -l $(BINDISTNAME).tar.gz | awk '{print $$5}'`; \
 	    sed -e "s/BIN_DIST_VERSION/$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE)/" \
 	    -e "s/GRASSPRG_NAME/$(GRASS_NAME)/" \
 	    -e "s/SIZE_TAR_FILE/$$size/" -e "s#BIN_DIST_DIR#'$(INST_DIR)'#" \
@@ -131,8 +164,8 @@
 	    -e "s/TEST_STR=/TEST_STR=executable/" \
 	    -e "s#IMPORTANT.*#Generated from the binaryInstall.src file using the command make bindist#" \
 	    -e "s/# executable shell.*//" -e "s/# make bindist.*//" \
-	    binaryInstall.src > grass-$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE)-install.sh ; \
-	    chmod a+x grass-$(GRASS_VERSION_NUMBER)-$(ARCH)-$(DATE)-install.sh 2>/dev/null
+	    binaryInstall.src > $(BINDISTNAME)-install.sh ; \
+	    chmod a+x $(BINDISTNAME)-install.sh 2>/dev/null
 bindist-macosx:
 	$(MAKE) -C macosx bindist-macosx
@@ -146,7 +179,7 @@
 	@ # do not include the debian control files:
 	-mv ./grass-$(GRASS_VERSION_NUMBER)/debian .
 	@ #we use -h to get the linked files into as real files:
-	tar cvfzh grass-$(GRASS_VERSION_NUMBER).tar.gz ./grass-$(GRASS_VERSION_NUMBER)/* --exclude=CVS
+	tar cvfzh grass-$(GRASS_VERSION_NUMBER).tar.gz ./grass-$(GRASS_VERSION_NUMBER)/* --exclude=.svn
 	@ # restore src code location:
 	-mv ./grass-$(GRASS_VERSION_NUMBER)/* .
 	-rmdir ./grass-$(GRASS_VERSION_NUMBER)
@@ -174,5 +207,7 @@
 	-rm -r ./grass-lib-$(GRASS_VERSION_NUMBER)
 	@ echo "Distribution source package: grass-lib-$(GRASS_VERSION_NUMBER).tar.gz ready."
-.PHONY: strip install real-install install-strip install-macosx
+.PHONY: strip strip-check
+.PHONY: install-check-built install-check-parent install-check-writable install-check-prefix
+.PHONY: install real-install install-strip install-macosx
 .PHONY: bindist real-bindist bindist-macosx srcdist srclibsdist
Modified: grass/trunk/lib/proj/Makefile
--- grass/trunk/lib/proj/Makefile	2010-10-14 07:59:19 UTC (rev 43904)
+++ grass/trunk/lib/proj/Makefile	2010-10-14 09:43:38 UTC (rev 43905)
@@ -21,21 +21,27 @@
 NT_DSTFILES  := $(patsubst %,$(NAD_DIR)/%,$(NT_TABLES))
 CSV_DSTFILES := $(patsubst %,$(CSV_DIR)/%,$(CSV_FILES))
+NAD_SRCDIR = $(ETC)/nad/src
+NAD_SRCFILES := $(patsubst %.lla,$(NAD_SRCDIR)/%.lla,$(NAD_TABLES))
 PROJ_TABLES := proj-desc.table proj-parms.table proj-units.table
 PROJ_DSTFILES := $(patsubst %,$(ETC)/%,$(PROJ_TABLES))
 default: lib
-	$(MAKE) $(NAD_DSTFILES) $(CSV_DSTFILES) $(PROJ_DSTFILES)
+	$(MAKE) $(NAD_DSTFILES) $(CSV_DSTFILES) $(PROJ_DSTFILES) $(NAD_SRCFILES)
-$(NAD_DIR)/%: %.lla | $(NAD_DIR)
+$(NAD_DSTFILES): $(NAD_DIR)/%: %.lla | $(NAD_DIR)
 	$(NAD2BIN) < $< $@
 $(NT_DSTFILES): $(NAD_DIR)/%: % | $(NAD_DIR)
 	$(INSTALL_DATA) $< $@
-$(CSV_DIR)/%.csv: %.csv | $(CSV_DIR)
+$(CSV_DSTFILES): $(CSV_DIR)/%.csv: %.csv | $(CSV_DIR)
+$(NAD_SRCFILES): $(NAD_SRCDIR)/%.lla: %.lla | $(NAD_SRCDIR)
+	$(INSTALL_DATA) $< $@
 $(ETC)/proj-%.table: proj-%.table
@@ -45,6 +51,9 @@
 $(CSV_DIR):
 	$(MKDIR) $@
+$(NAD_SRCDIR):
+	$(MKDIR) $@
 # Note for future improvement:
 # To allow for cross-compilation, the above NAD_TABLES files should be
 # created during installation rather than compilation
