[GRASS-SVN] r43921 - grass/branches/develbranch_6/lib/python/ctypes
Thu Oct 14 14:25:25 EDT 2010
Author: martinl
Date: 2010-10-14 11:25:24 -0700 (Thu, 14 Oct 2010)
New Revision: 43921
Removed:
   grass/branches/develbranch_6/lib/python/ctypes/ctypesheader.py
remove unused file
Deleted: grass/branches/develbranch_6/lib/python/ctypes/ctypesheader.py
--- grass/branches/develbranch_6/lib/python/ctypes/ctypesheader.py	2010-10-14 17:32:26 UTC (rev 43920)
+++ grass/branches/develbranch_6/lib/python/ctypes/ctypesheader.py	2010-10-14 18:25:24 UTC (rev 43921)
@@ -1,567 +0,0 @@
-# Begin preamble
-import ctypes, os, sys
-from ctypes import *
-_int_types = (c_int16, c_int32)
-if hasattr(ctypes, 'c_int64'):
-    # Some builds of ctypes apparently do not have c_int64
-    # defined; it's a pretty good bet that these builds do not
-    # have 64-bit pointers.
-    _int_types += (c_int64,)
-for t in _int_types:
-    if sizeof(t) == sizeof(c_size_t):
-        c_ptrdiff_t = t
-del t
-del _int_types
-class c_void(Structure):
-    # c_void_p is a buggy return type, converting to int, so
-    # POINTER(None) == c_void_p is actually written as
-    # POINTER(c_void), so it can be treated as a real pointer.
-    _fields_ = [('dummy', c_int)]
-def POINTER(obj):
-    p = ctypes.POINTER(obj)
-    # Convert None to a real NULL pointer to work around bugs
-    # in how ctypes handles None on 64-bit platforms
-    if not isinstance(p.from_param, classmethod):
-        def from_param(cls, x):
-            if x is None:
-                return cls()
-            else:
-                return x
-        p.from_param = classmethod(from_param)
-    return p
-class UserString:
-    def __init__(self, seq):
-        if isinstance(seq, basestring):
-            self.data = seq
-        elif isinstance(seq, UserString):
-            self.data = seq.data[:]
-        else:
-            self.data = str(seq)
-    def __str__(self): return str(self.data)
-    def __repr__(self): return repr(self.data)
-    def __int__(self): return int(self.data)
-    def __long__(self): return long(self.data)
-    def __float__(self): return float(self.data)
-    def __complex__(self): return complex(self.data)
-    def __hash__(self): return hash(self.data)
-    def __cmp__(self, string):
-        if isinstance(string, UserString):
-            return cmp(self.data, string.data)
-        else:
-            return cmp(self.data, string)
-    def __contains__(self, char):
-        return char in self.data
-    def __len__(self): return len(self.data)
-    def __getitem__(self, index): return self.__class__(self.data[index])
-    def __getslice__(self, start, end):
-        start = max(start, 0); end = max(end, 0)
-        return self.__class__(self.data[start:end])
-    def __add__(self, other):
-        if isinstance(other, UserString):
-            return self.__class__(self.data + other.data)
-        elif isinstance(other, basestring):
-            return self.__class__(self.data + other)
-        else:
-            return self.__class__(self.data + str(other))
-    def __radd__(self, other):
-        if isinstance(other, basestring):
-            return self.__class__(other + self.data)
-        else:
-            return self.__class__(str(other) + self.data)
-    def __mul__(self, n):
-        return self.__class__(self.data*n)
-    __rmul__ = __mul__
-    def __mod__(self, args):
-        return self.__class__(self.data % args)
-    # the following methods are defined in alphabetical order:
-    def capitalize(self): return self.__class__(self.data.capitalize())
-    def center(self, width, *args):
-        return self.__class__(self.data.center(width, *args))
-    def count(self, sub, start=0, end=sys.maxint):
-        return self.data.count(sub, start, end)
-    def decode(self, encoding=None, errors=None): # XXX improve this?
-        if encoding:
-            if errors:
-                return self.__class__(self.data.decode(encoding, errors))
-            else:
-                return self.__class__(self.data.decode(encoding))
-        else:
-            return self.__class__(self.data.decode())
-    def encode(self, encoding=None, errors=None): # XXX improve this?
-        if encoding:
-            if errors:
-                return self.__class__(self.data.encode(encoding, errors))
-            else:
-                return self.__class__(self.data.encode(encoding))
-        else:
-            return self.__class__(self.data.encode())
-    def endswith(self, suffix, start=0, end=sys.maxint):
-        return self.data.endswith(suffix, start, end)
-    def expandtabs(self, tabsize=8):
-        return self.__class__(self.data.expandtabs(tabsize))
-    def find(self, sub, start=0, end=sys.maxint):
-        return self.data.find(sub, start, end)
-    def index(self, sub, start=0, end=sys.maxint):
-        return self.data.index(sub, start, end)
-    def isalpha(self): return self.data.isalpha()
-    def isalnum(self): return self.data.isalnum()
-    def isdecimal(self): return self.data.isdecimal()
-    def isdigit(self): return self.data.isdigit()
-    def islower(self): return self.data.islower()
-    def isnumeric(self): return self.data.isnumeric()
-    def isspace(self): return self.data.isspace()
-    def istitle(self): return self.data.istitle()
-    def isupper(self): return self.data.isupper()
-    def join(self, seq): return self.data.join(seq)
-    def ljust(self, width, *args):
-        return self.__class__(self.data.ljust(width, *args))
-    def lower(self): return self.__class__(self.data.lower())
-    def lstrip(self, chars=None): return self.__class__(self.data.lstrip(chars))
-    def partition(self, sep):
-        return self.data.partition(sep)
-    def replace(self, old, new, maxsplit=-1):
-        return self.__class__(self.data.replace(old, new, maxsplit))
-    def rfind(self, sub, start=0, end=sys.maxint):
-        return self.data.rfind(sub, start, end)
-    def rindex(self, sub, start=0, end=sys.maxint):
-        return self.data.rindex(sub, start, end)
-    def rjust(self, width, *args):
-        return self.__class__(self.data.rjust(width, *args))
-    def rpartition(self, sep):
-        return self.data.rpartition(sep)
-    def rstrip(self, chars=None): return self.__class__(self.data.rstrip(chars))
-    def split(self, sep=None, maxsplit=-1):
-        return self.data.split(sep, maxsplit)
-    def rsplit(self, sep=None, maxsplit=-1):
-        return self.data.rsplit(sep, maxsplit)
-    def splitlines(self, keepends=0): return self.data.splitlines(keepends)
-    def startswith(self, prefix, start=0, end=sys.maxint):
-        return self.data.startswith(prefix, start, end)
-    def strip(self, chars=None): return self.__class__(self.data.strip(chars))
-    def swapcase(self): return self.__class__(self.data.swapcase())
-    def title(self): return self.__class__(self.data.title())
-    def translate(self, *args):
-        return self.__class__(self.data.translate(*args))
-    def upper(self): return self.__class__(self.data.upper())
-    def zfill(self, width): return self.__class__(self.data.zfill(width))
-class MutableString(UserString):
-    """mutable string objects
-    Python strings are immutable objects.  This has the advantage, that
-    strings may be used as dictionary keys.  If this property isn't needed
-    and you insist on changing string values in place instead, you may cheat
-    and use MutableString.
-    But the purpose of this class is an educational one: to prevent
-    people from inventing their own mutable string class derived
-    from UserString and than forget thereby to remove (override) the
-    __hash__ method inherited from UserString.  This would lead to
-    errors that would be very hard to track down.
-    A faster and better solution is to rewrite your program using lists."""
-    def __init__(self, string=""):
-        self.data = string
-        raise TypeError("unhashable type (it is mutable)")
-    def __setitem__(self, index, sub):
-        if index < 0:
-            index += len(self.data)
-        if index < 0 or index >= len(self.data): raise IndexError
-        self.data = self.data[:index] + sub + self.data[index+1:]
-    def __delitem__(self, index):
-        if index < 0:
-        self.data = self.data[:index] + self.data[index+1:]
-    def __setslice__(self, start, end, sub):
-        if isinstance(sub, UserString):
-            self.data = self.data[:start]+sub.data+self.data[end:]
-        elif isinstance(sub, basestring):
-            self.data = self.data[:start]+sub+self.data[end:]
-        else:
-            self.data =  self.data[:start]+str(sub)+self.data[end:]
-    def __delslice__(self, start, end):
-        self.data = self.data[:start] + self.data[end:]
-    def immutable(self):
-        return UserString(self.data)
-    def __iadd__(self, other):
-            self.data += other.data
-        else:
-            self.data += str(other)
-        return self
-    def __imul__(self, n):
-        self.data *= n
-        return self
-class String(MutableString, Union):
-    _fields_ = [('raw', POINTER(c_char)),
-                ('data', c_char_p)]
-    def __init__(self, obj=""):
-        if isinstance(obj, (str, unicode, UserString)):
-            self.data = str(obj)
-        else:
-            self.raw = obj
-        return self.data and len(self.data) or 0
-    def from_param(cls, obj):
-        # Convert None or 0
-        if obj is None or obj == 0:
-            return cls(POINTER(c_char)())
-        # Convert from String
-        elif isinstance(obj, String):
-            return obj
-        # Convert from str
-        elif isinstance(obj, str):
-            return cls(obj)
-        # Convert from c_char_p
-        elif isinstance(obj, c_char_p):
-            return obj
-        # Convert from POINTER(c_char)
-        elif isinstance(obj, POINTER(c_char)):
-            return obj
-        # Convert from raw pointer
-        elif isinstance(obj, int):
-            return cls(cast(obj, POINTER(c_char)))
-        # Convert from object
-        else:
-            return String.from_param(obj._as_parameter_)
-    from_param = classmethod(from_param)
-def ReturnString(obj, func, arguments):
-    return String.from_param(obj)
-# As of ctypes 1.0, ctypes does not support custom error-checking
-# functions on callbacks, nor does it support custom datatypes on
-# callbacks, so we must ensure that all callbacks return
-# primitive datatypes.
-# Non-primitive return values wrapped with UNCHECKED won't be
-# typechecked, and will be converted to c_void_p.
-def UNCHECKED(type):
-    if (hasattr(type, "_type_") and isinstance(type._type_, str)
-        and type._type_ != "P"):
-        return type
-    else:
-        return c_void_p
-# ctypes doesn't have direct support for variadic functions, so we have to write
-# our own wrapper class
-class _variadic_function(object):
-    def __init__(self,func,restype,argtypes):
-        self.func=func
-        self.func.restype=restype
-        self.argtypes=argtypes
-    def _as_parameter_(self):
-        # So we can pass this variadic function as a function pointer
-        return self.func
-    def __call__(self,*args):
-        fixed_args=[]
-        i=0
-        for argtype in self.argtypes:
-            # Typecheck what we can
-            fixed_args.append(argtype.from_param(args[i]))
-            i+=1
-        return self.func(*fixed_args+list(args[i:]))
-# End preamble
-# Begin loader
-# Copyright (c) 2008 David James
-# Copyright (c) 2006-2008 Alex Holkner
-# All rights reserved.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions
-# are met:
-#  * Redistributions of source code must retain the above copyright
-#    notice, this list of conditions and the following disclaimer.
-#  * Redistributions in binary form must reproduce the above copyright
-#    notice, this list of conditions and the following disclaimer in
-#    the documentation and/or other materials provided with the
-#    distribution.
-#  * Neither the name of pyglet nor the names of its
-#    contributors may be used to endorse or promote products
-#    derived from this software without specific prior written
-#    permission.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-# FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-# COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-# INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-# BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
-# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
-# CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
-# ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-import os.path, re, sys, glob
-import ctypes
-import ctypes.util
-def _environ_path(name):
-    if name in os.environ:
-        return os.environ[name].split(":")
-    else:
-        return []
-class LibraryLoader(object):
-    def __init__(self):
-        self.other_dirs=[]
-    def load_library(self,libname):
-        """Given the name of a library, load it."""
-        paths = self.getpaths(libname)
-        for path in paths:
-            if os.path.exists(path):
-                return self.load(path)
-        raise ImportError("%s not found." % libname)
-    def load(self,path):
-        """Given a path to a library, load it."""
-        try:
-            # Darwin requires dlopen to be called with mode RTLD_GLOBAL instead
-            # of the default RTLD_LOCAL.  Without this, you end up with
-            # libraries not being loadable, resulting in "Symbol not found"
-            # errors
-            if sys.platform == 'darwin':
-                return ctypes.CDLL(path, ctypes.RTLD_GLOBAL)
-            else:
-                return ctypes.cdll.LoadLibrary(path)
-        except OSError,e:
-            raise ImportError(e)
-    def getpaths(self,libname):
-        """Return a list of paths where the library might be found."""
-        if os.path.isabs(libname):
-            yield libname
-        else:
-            for path in self.getplatformpaths(libname):
-                yield path
-            path = ctypes.util.find_library(libname)
-            if path: yield path
-    def getplatformpaths(self, libname):
-        return []
-# Darwin (Mac OS X)
-class DarwinLibraryLoader(LibraryLoader):
-    name_formats = ["lib%s.dylib", "lib%s.so", "lib%s.bundle", "%s.dylib",
-                "%s.so", "%s.bundle", "%s"]
-    def getplatformpaths(self,libname):
-        if os.path.pathsep in libname:
-            names = [libname]
-        else:
-            names = [format % libname for format in self.name_formats]
-        for dir in self.getdirs(libname):
-            for name in names:
-                yield os.path.join(dir,name)
-    def getdirs(self,libname):
-        '''Implements the dylib search as specified in Apple documentation:
-        http://developer.apple.com/documentation/DeveloperTools/Conceptual/
-            DynamicLibraries/Articles/DynamicLibraryUsageGuidelines.html
-        Before commencing the standard search, the method first checks
-        the bundle's ``Frameworks`` directory if the application is running
-        within a bundle (OS X .app).
-        dyld_fallback_library_path = _environ_path("DYLD_FALLBACK_LIBRARY_PATH")
-        if not dyld_fallback_library_path:
-            dyld_fallback_library_path = [os.path.expanduser('~/lib'),
-                                          '/usr/local/lib', '/usr/lib']
-        dirs = []
-        if '/' in libname:
-            dirs.extend(_environ_path("DYLD_LIBRARY_PATH"))
-        else:
-            dirs.extend(_environ_path("LD_LIBRARY_PATH"))
-        dirs.extend(self.other_dirs)
-        dirs.append(".")
-        if hasattr(sys, 'frozen') and sys.frozen == 'macosx_app':
-            dirs.append(os.path.join(
-                os.environ['RESOURCEPATH'],
-                'Frameworks'))
-        dirs.extend(dyld_fallback_library_path)
-        return dirs
-# Posix
-class PosixLibraryLoader(LibraryLoader):
-    _ld_so_cache = None
-    def _create_ld_so_cache(self):
-        # Recreate search path followed by ld.so.  This is going to be
-        # slow to build, and incorrect (ld.so uses ld.so.cache, which may
-        # not be up-to-date).  Used only as fallback for distros without
-        # /sbin/ldconfig.
-        # We assume the DT_RPATH and DT_RUNPATH binary sections are omitted.
-        directories = []
-        for name in ("LD_LIBRARY_PATH",
-                     "SHLIB_PATH", # HPUX
-                     "LIBPATH", # OS/2, AIX
-                     "LIBRARY_PATH", # BE/OS
-                directories.extend(os.environ[name].split(os.pathsep))
-        directories.extend(self.other_dirs)
-        directories.append(".")
-        try: directories.extend([dir.strip() for dir in open('/etc/ld.so.conf')])
-        except IOError: pass
-        directories.extend(['/lib', '/usr/lib', '/lib64', '/usr/lib64'])
-        cache = {}
-        lib_re = re.compile(r'lib(.*)\.s[ol]')
-        ext_re = re.compile(r'\.s[ol]$')
-        for dir in directories:
-            try:
-                for path in glob.glob("%s/*.s[ol]*" % dir):
-                    file = os.path.basename(path)
-                    # Index by filename
-                    if file not in cache:
-                        cache[file] = path
-                    # Index by library name
-                    match = lib_re.match(file)
-                    if match:
-                        library = match.group(1)
-                        if library not in cache:
-                            cache[library] = path
-            except OSError:
-                pass
-        self._ld_so_cache = cache
-        if self._ld_so_cache is None:
-            self._create_ld_so_cache()
-        result = self._ld_so_cache.get(libname)
-        if result: yield result
-        if path: yield os.path.join("/lib",path)
-# Windows
-class _WindowsLibrary(object):
-    def __init__(self, path):
-        self.cdll = ctypes.cdll.LoadLibrary(path)
-        self.windll = ctypes.windll.LoadLibrary(path)
-    def __getattr__(self, name):
-        try: return getattr(self.cdll,name)
-        except AttributeError:
-            try: return getattr(self.windll,name)
-                raise
-class WindowsLibraryLoader(LibraryLoader):
-    name_formats = ["%s.dll", "lib%s.dll", "%slib.dll"]
-    def load_library(self, libname):
-        try:
-            result = LibraryLoader.load_library(self, libname)
-        except ImportError:
-            result = None
-            if os.path.sep not in libname:
-                for name in self.name_formats:
-                    try:
-                        result = getattr(ctypes.cdll, name % libname)
-                        if result:
-                            break
-                    except WindowsError:
-                        result = None
-            if result is None:
-                try:
-                    result = getattr(ctypes.cdll, libname)
-                    result = None
-        return result
-    def load(self, path):
-        return _WindowsLibrary(path)
-                path = ctypes.util.find_library(name % libname)
-                if path:
-                    yield path
-# Platform switching
-# If your value of sys.platform does not appear in this dict, please contact
-# the Ctypesgen maintainers.
-loaderclass = {
-    "darwin":   DarwinLibraryLoader,
-    "cygwin":   WindowsLibraryLoader,
-    "win32":    WindowsLibraryLoader
-loader = loaderclass.get(sys.platform, PosixLibraryLoader)()
-def add_library_search_dirs(other_dirs):
-    loader.other_dirs = other_dirs
-load_library = loader.load_library
-del loaderclass
-# End loader
