[GRASS-SVN] r43937 - in grass/branches/releasebranch_6_4: gui/tcltk/gis.m gui/wxpython/xml scripts
Sun Oct 17 02:22:01 EDT 2010
Author: hamish
Date: 2010-10-16 23:22:00 -0700 (Sat, 16 Oct 2010)
New Revision: 43937
Added:
   grass/branches/releasebranch_6_4/scripts/v.in.lines/
   grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
   grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
   grass/branches/releasebranch_6_4/scripts/Makefile
add v.in.lines from devbr6
Modified: grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl	2010-10-16 16:50:35 UTC (rev 43936)
+++ grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl	2010-10-17 06:22:00 UTC (rev 43937)
@@ -112,6 +112,7 @@
 		{command {[G_msg "Multiple formats using OGR"]} {} "v.in.ogr: Import multiple formats using OGR" {} -command { execute v.in.ogr }}
 		{separator}
 		{command {[G_msg "ASCII points or GRASS ASCII vector"]} {} "v.in.ascii: Import ASCII points file or GRASS ASCII vector file" {} -command { execute v.in.ascii }}
+		{command {[G_msg "ASCII points as vector lines"]} {} "v.in.lines: Creates a lines vector map from an ASCII x,y points file." {} -command { execute v.in.lines }}
 		{command {[G_msg "Old GRASS vector"]} {} "v.convert: Import old GRASS vector format" {} -command { execute v.convert }}
 		{separator}
 		{command {[G_msg "DXF"]} {} "v.in.dxf: Import DXF file" {} -command { execute v.in.dxf }}
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-10-16 16:50:35 UTC (rev 43936)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-10-17 06:22:00 UTC (rev 43937)
@@ -196,7 +196,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>ASCII points as a vector lines</label>
-	      <help>Import ASCII x,y[,z] coordinates as a series of lines.</help>
+	      <help>Creates a lines vector map from an ASCII x,y points file.</help>
 	      <keywords>vector,import</keywords>
 	      <handler>OnMenuCmd</handler>
 	      <command>v.in.lines</command>
Modified: grass/branches/releasebranch_6_4/scripts/Makefile
--- grass/branches/releasebranch_6_4/scripts/Makefile	2010-10-16 16:50:35 UTC (rev 43936)
+++ grass/branches/releasebranch_6_4/scripts/Makefile	2010-10-17 06:22:00 UTC (rev 43937)
@@ -73,6 +73,7 @@
 	v.in.geonames \
 	v.in.gns \
 	v.in.gpsbabel \
+	v.in.lines \
 	v.in.mapgen \
 	v.in.sites.all \
 	v.in.wfs \
