[GRASS-SVN] r43940 - grass/trunk/raster/r.proj
svn_grass at osgeo.org
Sun Oct 17 03:01:41 EDT 2010
Author: hamish
Date: 2010-10-17 00:01:41 -0700 (Sun, 17 Oct 2010)
New Revision: 43940
grass/trunk/raster/r.proj/r.proj.html
doc tweaks (merge from devbr6)
Modified: grass/trunk/raster/r.proj/r.proj.html
--- grass/trunk/raster/r.proj/r.proj.html 2010-10-17 06:59:12 UTC (rev 43939)
+++ grass/trunk/raster/r.proj/r.proj.html 2010-10-17 07:01:41 UTC (rev 43940)
@@ -147,16 +147,17 @@
<p>
A simple way to do this is to check the projected bounds of the input map
-in the current location's projection using the <b>-p</b> flag. The <b>-g</b>
+in the current location's projection using the <b>-p</b> flag. The <b>-g</b>
flag reports the same thing, but in a form which can be directly cut and
pasted into a <em>g.region</em> command. After setting the region in that
way you might check the cell resolution with "<em>g.region -p</em>" then
snap it to a regular grid with <em>g.region</em>'s -a flag. E.g.
-<tt>g.region -a res=5 -p</tt>.
+<tt>g.region -a res=5 -p</tt>. Note that this is just a rough guide.
<p>
-A more involved way to do this is to generate a vector "box" map of the region in
-the source location using <em><a href="v.in.region.html">v.in.region</a></em>.
+A more involvedi, but more accurate, way to do this is to generate a vector
+"box" map of the region in the source location using
+ <em><a href="v.in.region.html">v.in.region</a></em>.
This "box" map is then reprojected into the target location with
<em><a href="v.proj.html">v.proj</a></em>.
Next the region in the target location is set to the extent of the new vector
