[GRASS-SVN] r43956 -
grass/branches/releasebranch_6_4/raster/r.proj.seg
svn_grass at osgeo.org
Sun Oct 17 15:09:13 EDT 2010
Author: neteler
Date: 2010-10-17 12:09:13 -0700 (Sun, 17 Oct 2010)
New Revision: 43956
grass/branches/releasebranch_6_4/raster/r.proj.seg/bilinear.c
grass/branches/releasebranch_6_4/raster/r.proj.seg/cubic.c
glynn: Don't store pointer to cache blocks which may be replaced (backport of r43944)
Modified: grass/branches/releasebranch_6_4/raster/r.proj.seg/bilinear.c
--- grass/branches/releasebranch_6_4/raster/r.proj.seg/bilinear.c 2010-10-17 19:05:45 UTC (rev 43955)
+++ grass/branches/releasebranch_6_4/raster/r.proj.seg/bilinear.c 2010-10-17 19:09:13 UTC (rev 43956)
@@ -22,46 +22,38 @@
struct Cell_head *cellhd /* information of output map */
- int row0, /* lower row index for interp */
- row1, /* upper row index for interp */
- col0, /* lower column index for interp */
- col1; /* upper column index for interp */
- FCELL t, u, /* intermediate slope */
- tu, /* t * u */
- result; /* result of interpolation */
- FCELL *c00, *c01, *c10, *c11;
+ int row; /* row indices for interp */
+ int col; /* column indices for interp */
+ int i, j;
+ FCELL t, u; /* intermediate slope */
+ FCELL result; /* result of interpolation */
+ FCELL c[2][2];
/* cut indices to integer */
- row0 = (int)floor(*row_idx - 0.5);
- col0 = (int)floor(*col_idx - 0.5);
- row1 = row0 + 1;
- col1 = col0 + 1;
+ row = (int)floor(*row_idx - 0.5);
+ col = (int)floor(*col_idx - 0.5);
/* check for out of bounds - if out of bounds set NULL value and return */
- if (row0 < 0 || row1 >= cellhd->rows || col0 < 0 || col1 >= cellhd->cols) {
+ if (row < 0 || row + 1 >= cellhd->rows || col < 0 || col + 1 >= cellhd->cols) {
G_set_null_value(obufptr, 1, cell_type);
return;
- c00 = CPTR(ibuffer, row0, col0);
- c01 = CPTR(ibuffer, row0, col1);
- c10 = CPTR(ibuffer, row1, col0);
- c11 = CPTR(ibuffer, row1, col1);
+ for (i = 0; i < 2; i++)
+ for (j = 0; j < 2; j++) {
+ const FCELL *cellp = CPTR(ibuffer, row + i, col + j);
+ if (G_is_f_null_value(cellp)) {
+ G_set_null_value(obufptr, 1, cell_type);
+ return;
+ c[i][j] = *cellp;
- /* check for NULL values */
- if (G_is_f_null_value(c00) ||
- G_is_f_null_value(c01) ||
- G_is_f_null_value(c10) || G_is_f_null_value(c11)) {
- G_set_null_value(obufptr, 1, cell_type);
- return;
/* do the interpolation */
- t = *col_idx - 0.5 - col0;
- u = *row_idx - 0.5 - row0;
- tu = t * u;
+ t = *col_idx - 0.5 - col;
+ u = *row_idx - 0.5 - row;
- result = G_interp_bilinear(t, u, *c00, *c01, *c10, *c11);
+ result = G_interp_bilinear(t, u, c[0][0], c[0][1], c[1][0], c[1][1]);
G_set_raster_value_f(obufptr, result, cell_type);
Modified: grass/branches/releasebranch_6_4/raster/r.proj.seg/cubic.c
--- grass/branches/releasebranch_6_4/raster/r.proj.seg/cubic.c 2010-10-17 19:05:45 UTC (rev 43955)
+++ grass/branches/releasebranch_6_4/raster/r.proj.seg/cubic.c 2010-10-17 19:09:13 UTC (rev 43956)
@@ -25,13 +25,13 @@
- int row, /* row indices for interp */
- col; /* column indices for interp */
int i, j;
- result, /* result of interpolation */
- val[4]; /* buffer for temporary values */
- FCELL *cellp[4][4];
+ FCELL val[4]; /* buffer for temporary values */
+ FCELL cell[4][4];
@@ -45,16 +45,13 @@
for (i = 0; i < 4; i++)
- for (j = 0; j < 4; j++)
- cellp[i][j] = CPTR(ibuffer, row - 1 + i, col - 1 + j);
- /* check for NULL value */
- for (i = 0; i < 4; i++)
for (j = 0; j < 4; j++) {
- if (G_is_f_null_value(cellp[i][j])) {
+ const FCELL *cellp = CPTR(ibuffer, row - 1 + i, col - 1 + j);
return;
+ cell[i][j] = *cellp;
@@ -62,9 +59,8 @@
for (i = 0; i < 4; i++) {
- FCELL **tmp = cellp[i];
- val[i] = G_interp_cubic(t, *tmp[0], *tmp[1], *tmp[2], *tmp[3]);
+ const FCELL *tmp = cell[i];
+ val[i] = G_interp_cubic(t, tmp[0], tmp[1], tmp[2], tmp[3]);
result = G_interp_cubic(u, val[0], val[1], val[2], val[3]);
